Results 1 to 2 of 2
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Head Unit Harness Help
    So I just picked up Pioneer Avic F90BT and now I need a wiring harness to hook it up. What they gave me at Circuit City is wrong and from what I'm seeing on Crutchfield and Installer the harness looks about the same as what I got. Now, I know few members here have Avic units installed so if you installed it yourself which harness did you buy? I have stock Bose non-nav headunit.
    Also, which mounting kit are you using? The ones I've seen looked a bit off except one member on here but he didn't know which kit it was.
    On the side note, do speed and reverse wires have to be connected in order for unit to function?
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Mar 24 2008
    khgkhg
    Re: Head Unit Harness Help
    Or does anyone have a stock harness pinout map?
    |^^^^^^^^^^^\||____
