Thread: any advice?
    Oct 28 2008
    Virginia
    any advice?
    I am also posting this is Tech talk to see if I can get any more help. Please follow link.
    http://www.audizine.com/forum/showthread.php?t=257508
    Basically I am trying to get help with some codes thrown by CEL.
    Thanks
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Re: any advice?
    PO421 Warm up catalyst,Bank 1 Efficiency Below Threshold
    PO159 O2 Sensor Cir, Bank 2 Sensor2 Slow response
    P2098 Post Catalyst Fuel Trim System to lean Bank 2
    The first two codes are for your After cat O2 sensors which you just need to relocate and you should be fine after that. Third code is for a vauume leak. Pressurize your system and look for leaks it's not good to be running lean. Bank 2 is the drivers side.
    Oct 28 2008
    Virginia
    Re: any advice?
    Quote Originally Posted by GetAwayFromMe View Post
    thanks for the input but if I had a vacuum leak wouldn't the car run rich rather lean?
    Jan 03 2008
    Iowa
    Re: any advice?
    iT COULD BE EITHER ONE DEPENDING WHERE THE VACUUM LEAK IS COMMING FROM.
    Veteran Member Three Rings seadoo4563's Avatar
    Aug 10 2007
    Annapolis,MD
    Re: any advice?
    iT COULD BE EITHER ONE DEPENDING WHERE THE VACUUM LEAK IS CUMMING FROM.
    I DONT KNOW WHAT WERE YELLING ABOUT!
