Thread: CEL
    Registered Member Two Rings
    Apr 19 2007
    Eugene, OR
    CEL
    So I was just driving home last night, no change in performance and the CEL came on, not blinking just solid. I'm going to go out to autozone for a VAG-COM but is it okay to drive with a solid, I know the blinking is bad. Or is there anything I should check first?
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    Re: CEL
    it's anything between your gas cap being loose to your engine is going to explode
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Re: CEL
    blinking oil pressure light = exploding engine
    solid mil is ok to drive with, but is recommended to check the fault before further driving. it could be an emissions issue, or possibly a vacuum leak causing a lean condition.
    blinking mil represents misfiring cylinders. often this is caused by ignition coils or ignition modules/spark plugs/wires on some vehicles. you pretty much only want to drive up the road or onto a trailer/flatbed so you can get to the dealer or parts store. its good to keep a spare coil in your car.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Apr 19 2007
    Eugene, OR
    Re: CEL
    So I went to autozone and it pulled that the system is running lean. Had it cleared and it runs great unless pushed harder than typical driving in which case CEL comes back on. Guy at autozone recommended scrubbing the o2 sensor with a wire brush to remove carbon. Any other suggestions? Cleaning? places to check before I bring her to a mechanic....
    Dec 04 2007
    New York, NY
    Re: CEL
    what was the code he pulled.
