Results 1 to 13 of 13
Thread: +45 offset
    Jan 09 2009
    1of50
    +45 offset
    will 18x8 +45 offset wheels on a stock 08 S4? If I get spacers for them would 8mm or 10mm be a better look?
    Thanks...sorry for the newbie Q's.
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Re: +45 offset
    Quote Originally Posted by cheewy16 View Post
    A 10mm spacer will bring you to a ET35 which is
    the offset that most people run on their aftermarket wheels for their s4.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: +45 offset
    ^x2, he is correct
    Jan 09 2009
    1of50
    Re: +45 offset
    what if I don't run spacers? Will they still work? using them for winter set-up
    Mar 12 2007
    Boston
    Re: +45 offset
    Stock is +43 so I would think you'd be OK.
    SOLD 4/16/15- '08 Daytona Gray RS4/Black leather/CF trim/35% tint/MTM 10mm spacers/Euro steering wheel/GMG catback w/ Magnaflow DPs
    SOLD 9/4/11- '04 Nogaro Blue S4 w/ LaBree Resonated Fullback/ Vogtland Coils/ ECS Snub Mount/18x8.5" et32 Diamond Black RS-GTs
    Sep 23 2006
    Houston TX
    Re: +45 offset
    On an 8" wheel you can go more aggressive than 10mm, which would correlate to about +41 on an 8.5 width wheel. Still kind of set-in the fender. Honestly I'd just look for different wheels with more appropriate offset.
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Re: +45 offset
    go more than 10, probably 15 mm all around is good. +35 on x8.5 is flush in front and tucked abotu 2-3 mm in back.
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Re: +45 offset
    I think the stock AVUS are 18x8 and et45.
    Veteran Member Three Rings V8weight's Avatar
    Nov 16 2008
    Hudson, WI
    Re: +45 offset
    actually, being inset a ways inside the fender might be to your advantage in the winter. Keeps the winter slime from slinging down the side of you car.
    Mar 12 2007
    Boston
    Re: +45 offset
    Quote Originally Posted by B18b1ex View Post
    Stock is ET +43.
    Jan 09 2009
    1of50
    Re: +45 offset
    thanks all for your input. I might just try to test fit the wheels to see if they will work, if not get some spacers so that they will clear the brakes.
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    Re: +45 offset
    What would be the best size spacer for stock to sit flush
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    Re: +45 offset
    Quote Originally Posted by tadhgbrosnan View Post
    Stock is ET +43.
    x 100000000000 Where the hell do these people get all this miss-information?!
    Can we set this in stone yet?
    Stock wheel is ET +43...it says it on the wheel. Take it off and take a look.
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
