Results 1 to 12 of 12
    Nov 22 2008
    01.5 S4
    Michigan
    Clutch Slave Cylinder
    So im driving and stop at a light and i go to put it in 1st...would not go in so shut my car off and started it back up and then went into gear. I just changed my clutch to rs4 custom stage 1 used a vast clutch plate instead of the stock rs4 crap...has anyone had this problem so im pretty sure its the Clutch Slave Cylinder
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Re: Clutch Slave Cylinder
    does your clutch pedal feel fine when you press down? any leaking fluid? can you shift gears when the car is off? It sounds like the pressure plate to me
    Nov 22 2008
    01.5 S4
    Michigan
    yeah clutch feels fine and yeah i can go into every gear perfect when cars off i put a new pressure plate and everything....no fluid leaking i think i didnt check that yet
    Established Member Two Rings ewuzh's Avatar
    Jan 02 2008
    CA
    Could be slave cylinder or broken pressure plate. Same thing happened to me and it was a broken pressure plate. But since you have a brand new pp, it's probably (hopefully) the slave cyl.
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Did you bleed the clutch system enough? It doesnt sound like a slave tho. If it just doesnt work and now it does, that weird. Let us know of some more symptoms.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Sounds like a bad pressure plate. Exactly what my car did. Who did your clutch install and how long ago? Do you have any problems putting the clutch to the floor?
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Nov 22 2008
    01.5 S4
    Michigan
    I just put it in about a month ago my brother and his freind did it cause I was at school at the time shit I hope its not the presure plate fcukkkkkkkk err it stopped doing it and yeh the clutch goes all the way works fine
    Veteran Member Four Rings Slave IV's Avatar
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    Quote Originally Posted by lucajS4 View Post
    Doesn't Vast use the RS4 PP too? This is what their site says:
    "All pressure plates used will be a genuine Audi RS4."
    Nov 22 2008
    01.5 S4
    Michigan
    I'ma find out what's going then get back to you thanks for advice guys but I don't think its the plate hopefully man it'd not problem to take the tranny out cause got a lift in the garage I'll get back to u guys thanks again and sorry for any miss spells I'm on the damn iphone
    Veteran Member Three Rings jeproks's Avatar
    Jul 14 2004
    Bahay Kubo
    You probably didn't set the SAC correctly on the PP.
    Nov 22 2008
    01.5 S4
    Michigan
    im not sure ill get back.....
    Nov 22 2008
    01.5 S4
    Michigan
    bored just posting some pics
