Results 1 to 6 of 6
Thread: CEL Help
    Oct 28 2008
    Virginia
    CEL Help
    Hello all. I have a 04' a6 2.7 and recently my CEL came on. I went to Autozone to have the codes spit out and this is what came out.
    P0421
    P0159
    P2098
    The only modification done to my car is Piggies, which I did 2 months ago. I kept the stock locations for the o2 sensors. I used defoulers from one of the DIY on piggies. The only thing else that is not stock on the car would be a K & N filter. (not cone style) and Darintake.
    Is there anyone in the Northern Virginia or D.C area that can help me? Thanks for any help.
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Re: CEL Help
    Quote Originally Posted by Stockblacka6 View Post
    P0421
    P0159
    P2098
    Sounds like your defoulers are not working properly, they are a fix but do not necessilary work for all people.
    Your best best would be to either move the 02 sensor behind the main cats or have your ecu recoded.
    B5 S4 AWE Stage 3 - sold
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: CEL Help
    or just ignore the cel. are you on a stock tune?
    Oct 28 2008
    Virginia
    Re: CEL Help
    Is that what those codes pretty much mean? I am getting my exhaust done soon, so should I have them plug the stock o2 sensors right before the main cat and relocate them to after the main cat? On one of the autozone print outs of those codes it mentioned a cause could be that a boost leak or that it was runnin lean. Is there anyone in the area that has VAG and can help me see whats going on.
    Rajan147 - thanks for your help.
    Thirdstrike - I'm on a stock tune. I was just about to pull the plug too on a chip, but I want to fix this before.
    Nov 23 2007
    Columbus, OH
    Re: CEL Help
    bingo, have then plug the stock locations and relocate to behind the main cats.
    p0159- o2 open circuit.
    don't know what the other codes are.
    Personally, I would just by a ~$12.00 cable from ebay and vag-it yourself. Its a cable worth its weight in gold.
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Re: CEL Help
    http://www.bentleypublishers.com/tec....dtc.table.htm
    check out your codes here. It doesn't have everything but it can help if you just get the codes read.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
