Results 1 to 40 of 45
    Jan 01 2008
    Long Island NY
    Just a little heads up for everyone with a Revision A cam
    If you upgrade the fuel pump don't take any chances buy a new cam from audi. I had a whole in my cam follower and some wear on my fuel pump retainer cap. I mean within 6 months from install my cam was shot. Change the cam or don't upgrade your fp. I think the reason I was getting fuel cut, check engine lights and low trap speeds at the track is because of this.
    Nov 12 2007
    Grand Junction, CO
    Re: Just a little heads up for everyone with a Revision A cam
    It's recommended that when you install the pump you check both. And that you keep checking every 5k miles or so to make sure everything is good. I wouldn't say don't do it, just check it.
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    How do I know if I have a revision B cam, or an A cam?
    2015 Audi S4 Prem+ Sepang Blue/Magma, 6MT, Eurocode Alu Kreuz, Eurocode Transmission Brace, Eurocode Sway Bars and Endlinks, RocEuro Intake, AWE Touring Exhaust
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    um...def going to look into this :/
    Im lookin to upgrade my fuel pump and pcv fix ASAP i get my car bk.
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    I had a B cam and it still went band, you have to keep a close eye on the caps.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    May 03 2008
    Monterey, CA, 93940
    So how do we know which cam we got? is it a YR' thing or what?
    Stage 2 Banner Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    Everything you guys need to know about fuel pumps and cam revsions is in the following document.
    Enjoy!
    http://www.goapr.com/VW/support/fsi_...stallation.pdf
    May 03 2008
    Monterey, CA, 93940
    Intake Camshaft and Cam Follower thru AUDI, how much does it ussually run installed? and if mine was worn at 26k, would I be covered under warranty, any clue?
    Thks apr for the document. I got my question from there :P
    Jan 01 2008
    Long Island NY
    Keith thanks I recieved the stuff.
    May 03 2008
    Monterey, CA, 93940
    Quote Originally Posted by Auditude2.0T View Post
    the stuff..lol
    Sent u an pm auditude...get bk to me if possible
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by 06B7audiA4 View Post
    the stuff..lol
    If you need PCV help let me know, I'm very experienced with it since that happened to me.
    DUH! an Audi
    los angeles, CA
    with any fuel pump, you will experience excess cam lobe wear and/or follower. As one mentioned, it has to be checked ever so often. If you never checked in the 6 months you had your HFP, thats pretty epic =P
    Nov 12 2007
    Grand Junction, CO
    Makes me not want to get one now....Seems like they may be more trouble then they are worth.
    DUH! an Audi
    los angeles, CA
    well, for some its worth it, others it's not. I personally dont like mods that require extra care or maintenance.
    HFP, will give you the added fuel you need to post higher. If you go bt, you need it regardless!
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    I just did the cam follower and the fuel pump on my GLI. My cam and follower looked good but KMD has stronger follower so I had it done anyway. KMD FTMFW
    _______
    Artic White B7 S4 Fully Loaded
    Mods= Titanuim RS4 Grill
    Salsa Red MKV GLI Fully Loaded
    Mods= Revo Stage III KO4, Carbonio, AWE Full Exhaust, AWE FMIC, H&R spring & Sways, AWE Vent Guage,
    ECS Blacked Out Coners, ECS Snub Mount, KMD Fuel Pump, KMD Cam Follower
    Jan 01 2008
    Long Island NY
    Quote Originally Posted by turbo4s View Post
    I was thinking of doing the KMD follower but it might damage the cam since the follower may be to hard.
    Mar 27 2006
    nah not at all. Not only is it a better follower but it will last another 20,000 miles longer than OEM.
    _______
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Someone needs to adapt a roller to these like the B8 uses.
    -Kris
    Veteran Member Three Rings golfvdude's Avatar
    Mar 11 2008
    2006 Audi A4 2.0T
    Abbeville, LA
    Quote Originally Posted by IceMole View Post
    That would be a REAL fix instead of band-aids. I'm sure it would not be cheap. Hence why no one has done it yet.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Quattro View Post
    A real fix needs to be put in place. Esp as more and more of you guys are upgrading to much bigger turbos.
    I foresee many failed highly modified 2.0TSIs due to this cam lobe problem.
    It would behoove the aftermarket to come up with a permanent fix. (read: aftermarket cam vendor and some other vendor for the fuel pump).
    -Doug
    Jan 01 2008
    Long Island NY
    Would a aftermarket cam fix this problem for good. I will do one eventually i just dont have the money for it now.
    Eventually Cam, Heads, Rods, Pistons and 30PSI:)
    Oct 09 2007
    E46 M3
    PA
    When I was digging for info on how the B8 roller is setup I thought, would it be possible if you just capped off the hole for the existing FP and ran an inline electric pump? I know it would require huge pressure and that is possibly not made by something like that, but it's just a thought. Maybe someone with knowledge can chime in with something.
    -Kris
    Jan 01 2008
    Long Island NY
    I don't think an electric pump would work because of the high pressure that goes through this system.
    Oct 09 2007
    E46 M3
    PA
    After reading some more I realize that no electric can hit 1600, anyway this is for everyone who has a B cam and thinks they may be safe, remember to check it.
    Quoted from vortex:
    Quote Originally Posted by OOOO-A3
    Back in May of this year, I took the vacuum pump cover off to determine which camshaft I have. This is the "good" 'B' cam. You can see the line between the two pieces that make it up.
    Since I found that I had the 'B' cam, and had no symptoms, I didn't worry about it.
    Now (December):
    I decided that since I have 53,000 miles on the original cam follower, I should go ahead and replace it. I figured it would have the black coating worn a bit, and maybe a mark on the inside.... You know, nothing major since the engine has the 'B' cam, NO aftermarket fuel pump, NO chip, oil changes every 5000 miles with Castrol 5w40 VW 502.00 oil, not beaten-on.... NO fuel cuts, NO CEL.
    I bought a new follower Friday, thinking that it was probably a waste of money since the original was probably just fine.... but it wouldn't hurt to replace it "just in case"....
    When I pulled the pump out Saturday to change the follower, I was like "Oh, **** me!" I wasn't prepared for this:
    "Wait..." you might say. "Where's the ****ing clip from the bottom of the follower?!?"
    Well, if you look back up at the pics of the pump, you might just see it hanging on the pump spring.... I retrieved it with a pair of needle-nose pliers, and it's all stretched out.
    I couldn't see any pieces of the old follower anywhere, so I had nothing else to do but put in the brand new follower that I just spent $60+ on, and reassemble everything. I cranked it afterwards, let it idle to warmup, rev'd it and didn't hear any odd noises or see any fuel leakage from the fittings, so it's at least as drivable as it has been.
    Due to a settlement with Audi over my A/C compressor, my warranty goes to 62k. Monday morning first thing I'll be going to the dealer (who hates me, I'm sure), and politely but firmly insisting on it being repaired ASAFP and me having a loaner in the mean time, since I need to do some roadtrips over the holidays.
    I ****ing hate this engine. I hate it, I hate it, I hate it..... It is the biggest steaming pile of scheisse. I've wasted a metric assload of money on this car, and I'd like nothing better than to feed it into a crusher. I'm done with VW/Audi. I'm serious this time. Unless I can find a way to do a TDI swap, it's time for a Subaru.
    -Kris
    Established Member Two Rings stupidfast31's Avatar
    Jun 24 2008
    Stamford/CT
    good find, even though it brings pretty bad news
    Jul 11 2005
    Auburn
    If anyone is interested in a little bit of light reading.......
    Here's 24 pages of debate and horror pics of failed cam followers on vwvortex.
    http://forums.vwvortex.com/zerothread?id=3750088
    For me, the moral of the story is to check your cam follower every 5-10k miles especially if you are out of warranty!
    Jul 11 2005
    Auburn
    and if necessary I can explain why aftermarket fuel pumps and other modifications have no bearing on cam follower life.
    Jun 24 2008
    Stamford/CT
    I wouldn't mind if you would care to explain. The more info the better.
    Jul 11 2005
    Auburn
    You would be looking at about $600 in parts and then whatever the labor is, I think they quote 4 hours.
    I'm pretty sure they won't begin to cover it until you get a fuel cut cel. Depends on the dealership though.
    Jul 11 2005
    Auburn
    Quote Originally Posted by stupidfast31 View Post
    No sweat, I'll tackle this in the morning though.
    Jun 24 2008
    Stamford/CT
    Quote Originally Posted by Keith@APR View Post
    thanks its much appreciated
    Jan 13 2008
    2008 A4 2.0t Avant 6spd
    Boston MA
    Please do, my last A4 looked the the pictures posted above...
    2008 A4 2.0T Avant 6spd. Black on Black Ti S-Line
    Jan 01 2008
    Long Island NY
    I swapped the button on the top of the fsi pump from my stock one that should do
    Nov 05 2007
    Auburn, AL
    Pete:
    That "button" on the end of the piston assembly has to be pressed into the spring retaining collar until is stops (bottoms out). If you did this at home, please make sure that it is fully pressed in.
    Also, if you replaced the button it means you had to remove the piston from the pump housing and press on the end of the piston to push the old button out of the spring retaining collar, correct? I really hope you were careful with the piston as far as cleanliness and scratches. You also needed to be careful when pushing the piston assembly back into the pump. There are some seals that the piston goes through and they only way I have ever seen them damaged is due to improper assembly or disassembly...basically people being rough and careless when pushing the piston through the seal assembly (inside the pump).
    Mike
    Veteran Member Three Rings Nico's Avatar
    Mar 02 2007
    Sydney, Australia
    A new cam will not fix this problem. The main issue is the cam follower! You must check the follower of a modified HPFP every 5-7500 miles (this is also dependant on how hard you drive, there have been highly modified cars with 500WHP that have gone 20000 miles on one follower) and replace if it is worn. If you do this you will never need a new cam.
    | APR KO4 | APR TP | APR FUEL PUMP | CARBONIO | AWE CBE | S4 DOORBLADES | BBS Ch | TINT | KW V1 | BSH PCV STAGE II | HOTCHKIS F/R SWAYS |
    Mar 02 2007
    Sydney, Australia
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Wow this really sucks, no one here or on any other forums has high milage b7 with the 2.0t. I have a feeling that this engine will fail very early yet out of warranty as a result of this fuel pump cam problem. how ridiculous, i guess time to start looking for another car that wont have a stupid problem as a result of absolutely poor engineering.
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Auditude, i respect you giving people a heads up but unfortunately, it doesnt mean much. As other people have stated and as witnessed on vortex, both A and B cams have shown wear. The cam follower is what to watch for. I asked you if you checked yours in your "my cam is shot" thread-
    Me- "did you check your cam and follower before adding the apr pump? if so, how many miles have you put on since then? I hear its 2-3k from another forum. btw i like kmd but that follower also gets some harsh words on another forum because it does not have the DLC coating which protects it."
    Im still wondering if you checked it as you did NOT reply. The last statement i made in your thread explains why people have said that the KMD follower is WEAKER, not stronger, than stock. So turbo4s, i wish you luck with yours but let us know what it looks like next time you check it.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    this thread scares me, but its a great reference.
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    Quote Originally Posted by a4dc89 View Post
    I have a 05.5 B7 A4 with 104,000 miles on my car ( im original owner of car) and have had no codes or anything and have some mods on my car for a little over 50,000 miles. The last time i checked the cam follower was at roughly at 75,000 miles and it had some wear but nothing to bad. I will pull the HPFP to check the follower and try to remember to take pics of it and post them up maybe this weekend.
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
