Results 1 to 8 of 8
Thread: Loping in Idle
    Registered Member One Ring mariah's Avatar
    Jan 11 2009
    Audi TT 225 roadster
    Alpharetta, GA
    Loping in Idle
    Hey Guys,
    I just bought a 2002 audi tt quattro roadster. I took it to the Audi dealer because it was loping in idle. It idles at 740 when it isnt loping. When it does lope it drops to just about 500 rpm and jumps above 1000. The dealer said it was the MAF sensor but I am not sure that is correct.
    I had a friend VAG the car and I got some data which I am posting below. Please let me know if you can tell what is happening. I also have the codes it is pulling as well.
    Mariah
    HERE ARE THE CODES-
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8N - Audi TT
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 01 -------------------------------------------------------
    Controller: 8N0 906 018 AN
    Component: 1.8L R4/5VT G 0004
    Coding: 06710
    Shop #: WSC 01236
    TRUUT28N021041400 AUZ5Z0B6306117
    1 Fault Found:
    17545 - Fuel Trim: Bank 1 (Add): System too Rich
    P1137 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03 -------------------------------------------------------
    Controller: 8N0 907 379 H
    Component: ESP ALLRAD MK60 0101
    Coding: 0022544
    Shop #: WSC 01236
    No fault code found.
    Address 08 -------------------------------------------------------
    Controller: 8N0 820 043 A
    Component: TT-KLIMAVOLLAUTOMAT D03
    Coding: 00140
    Shop #: WSC 01236
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 8N1 920 980 E
    Component: KOMBI+WEGFAHRS. M73 D14
    Coding: 07244
    Shop #: WSC 05141
    Address 22 -------------------------------------------------------
    Controller: 02D 900 554 C
    Component: HALDEX LSC ECC 0010
    1 Fault Found:
    00526 - Brake Light Switch-F
    27-10 - Implausible Signal - Intermittent
    Address 35 -------------------------------------------------------
    Controller: 8N7 962 267 A
    Component: Central Lock/Alarm D06
    Coding: 15900
    Shop #: WSC 01236
    1 Fault Found:
    01371 - Alarm triggered by Door Contact Switch: Driver's Side
    35-00 - -
    Address 55 -------------------------------------------------------
    Controller: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00010
    Shop #: WSC 01236
    Address 56 -------------------------------------------------------
    Controller: 4B0 035 186 H
    Component: concert II NP2 0050
    Coding: 00202
    Shop #: WSC 00000
    End -------------------------------------------------------
    Jan 11 2009
    Alpharetta, GA
    Re: Loping in Idle
    HERE ARE SOME NUMBERS FROM DRIVING -
    Tuesday 13 January 2009 12:27:47
    8N0 906 018 AN 1.8L R4/5VT G 0004
    Group A: '115 Group B: '002 Group C: '020
    Engine Speed Load Cmd Pressure Press @ Intercool Engine RPM Engine Load Ave. Inj. Period Air Mass Flow Cyl #1 Cyl #2 Cyl #3 Cyl #4
    TIME TIME TIME
    MARKER STAMP /min % mbar mbar STAMP /min % ms g/s STAMP CF CF CF CF
    0.66 720 20.3 960 970 0.01 720 20.3 2.05 2.97 0.26 0 0 0 0
    1.56 760 20.3 960 970 0.96 720 20.3 2.05 2.97 1.26 0 0 0 0
    2.46 720 20.3 960 970 1.86 720 20.3 2.05 2.97 2.15 0 0 0 0
    3.35 720 20.3 960 970 2.75 720 20.3 2.05 2.97 3.05 0 0 0 0
    4.25 760 20.3 960 970 3.65 720 20.3 2.05 2.97 3.95 0 0 0 0
    5.15 720 20.3 960 970 4.55 720 20.3 2.05 2.97 4.85 0 0 0 0
    6.15 720 20.3 960 970 5.55 720 20.3 2.05 2.97 5.85 0 0 0 0
    7.05 720 20.3 960 970 6.45 720 20.3 2.05 2.97 6.75 0 0 0 0
    7.95 720 20.3 960 970 7.35 720 20.3 2.05 2.97 7.65 0 0 0 0
    8.85 720 20.3 960 970 8.25 720 20.3 2.05 2.97 8.55 0 0 0 0
    9.75 720 20.3 960 970 9.15 720 20.3 2.05 2.97 9.45 0 0 0 0
    10.65 760 20.3 960 970 10.05 720 20.3 2.05 2.97 10.35 0 0 0 0
    11.65 720 20.3 960 970 10.95 720 20.3 2.05 3 11.35 0 0 0 0
    12.55 680 22.6 960 970 11.95 720 20.3 2.05 2.97 12.25 0 0 0 0
    13.45 760 21.1 960 970 12.85 720 22.6 2.05 2.97 13.15 0 0 0 0
    14.35 720 21.1 960 970 13.75 720 21.1 2.05 3.06 14.05 0 0 0 0
    15.25 720 21.1 960 970 14.65 760 21.1 2.05 3.17 14.95 0 0 0 0
    16.25 720 21.1 960 970 15.55 760 21.1 2.05 3.08 15.85 0 0 0 0
    17.15 760 21.1 960 960 16.55 720 21.1 2.05 3.11 16.85 0 0 0 0
    18.05 720 21.1 960 970 17.45 720 21.1 2.05 3.06 17.75 0 0 0 0
    18.95 720 21.1 960 970 18.35 720 21.8 2.05 3.14 18.65 0 0 0 0
    19.85 720 21.1 960 970 19.25 720 21.1 2.05 3.14 19.55 0 0 0 0
    20.75 720 21.1 960 970 20.15 720 21.1 2.05 3.08 20.45 0 0 0 0
    21.75 720 21.1 960 970 21.15 720 21.1 2.05 3.17 21.45 0 0 0 0
    22.65 720 21.8 960 970 22.05 720 21.1 2.05 3.14 22.35 0 0 0 0
    23.55 720 21.8 960 970 22.95 720 21.8 2.05 3.14 23.24 0 0 0 0
    24.44 760 21.1 960 970 23.84 760 21.8 2.05 3.19 24.14 0 0 0 0
    25.34 720 21.1 960 970 24.74 760 21.1 2.05 3.11 25.04 0 0 0 0
    26.24 680 31.6 960 960 25.64 760 20.3 2.05 3.03 25.94 0 0 0 0
    27.24 1400 29.3 960 970 26.54 1000 36.1 3.69 5.69 26.94 0 0 0 0
    28.14 1120 33.1 960 970 27.54 1640 37.6 3.28 12.22 27.84 0 0 0 0
    29.04 840 36.1 960 970 28.44 1040 37.6 3.28 6.25 28.74 0 0 0 0
    29.94 840 34.6 960 970 29.34 680 35.3 3.28 3.44 29.64 0 0 0 0
    30.84 760 36.8 960 970 30.24 760 33.1 2.46 3.22 30.54 0 0 0 0
    31.84 680 45.1 960 970 31.14 680 36.1 2.87 4.67 31.44 0 0 0 0
    32.74 720 36.1 960 970 32.14 800 42.1 2.87 3.19 32.44 0 0 0 0
    33.64 720 36.1 960 970 33.04 720 35.3 2.46 3.44 33.34 0 0 0 0
    34.54 720 36.8 960 970 33.94 720 36.8 2.87 3.86 34.24 0 0 0 0
    35.44 720 35.3 960 970 34.84 720 36.1 2.87 3.78 35.14 0 0 0 0
    36.34 720 36.1 960 970 35.74 720 36.1 2.46 3.81 36.04 0 0 0 0
    37.24 1160 45.9 960 970 36.64 720 38.3 3.28 6.53 36.94 0 0 0 0
    38.14 1560 39.1 960 970 37.54 1560 36.8 2.87 9.47 37.84 0 0 0 0
    39.04 1320 45.9 960 980 38.44 1440 45.1 4.1 14.08 38.74 0 0 0 0
    39.94 1400 59.4 960 990 39.34 1200 51.9 5.74 14.25 39.64 0 0 0 0
    40.84 1280 57.9 960 1000 40.24 1200 61.7 6.15 15.28 40.54 0 0 0 0
    41.74 1640 41.4 960 1010 41.14 1440 56.4 5.33 16.53 41.44 0 0 0 0
    42.74 1760 39.8 960 990 42.04 1720 41.4 3.69 13.72 42.44 0 0 0 0
    43.64 1800 33.8 960 990 43.04 1800 35.3 2.87 10.86 43.34 0 0 0 0
    44.54 1840 38.3 960 980 43.94 1800 32.3 2.87 11.61 44.23 0 0 0 0
    45.44 1960 37.6 960 990 44.83 1840 38.3 3.69 13.86 45.13 0 0 0 0
    46.33 2120 35.3 960 990 45.74 2000 36.1 3.28 14.22 46.03 0 0 0 0
    47.23 2320 33.8 960 990 46.63 2200 35.3 3.28 14.83 46.93 0 0 0 0
    48.24 2480 21.8 960 990 47.63 2400 30.8 2.87 14.22 47.94 0 0 0 0
    49.23 2440 21.8 960 980 48.54 2480 21.1 2.05 9.94 48.93 0 0 0 0
    50.13 2520 21.8 960 970 49.53 2440 21.8 2.05 10.64 49.83 0 0 0 0
    51.13 2640 26.3 960 970 50.44 2560 25.6 2.46 12.67 50.83 0 0 0 0
    52.14 2840 24.1 960 980 51.44 2720 27.1 2.46 14.36 51.74 0 0 0 0
    53.04 2840 13.5 960 990 52.43 2880 23.3 2.46 13.08 52.73 0 0 0 0
    54.03 2680 11.3 960 980 53.34 2800 10.5 1.23 5.67 53.73 0 0 0 0
    54.94 1880 11.3 960 970 54.34 2360 11.3 1.64 5.33 54.63 0 0 0 0
    55.93 1040 15 960 970 55.33 1440 12 1.23 3.25 55.63 0 0 0 0
    56.83 720 26.3 960 970 56.23 1000 20.3 2.05 2.94 56.53 0 0 0 0
    57.73 680 33.1 960 970 57.13 680 35.3 4.1 5.61 57.43 0 0 0 0
    58.73 720 33.8 960 970 58.13 720 33.8 2.87 3.28 58.43 0 0 0 0
    59.63 720 31.6 960 970 59.03 720 33.1 2.87 3.25 59.33 0 0 0 0
    60.53 760 25.6 960 970 59.93 760 27.1 2.05 3.75 60.23 0 0 0 0
    61.43 1520 51.9 960 960 60.83 840 39.8 4.1 8.06 61.13 0 0 0 0
    62.33 1400 54.1 960 1000 61.73 1680 51.9 4.51 19.08 62.03 0 0 0 0
    63.33 1520 47.4 960 1000 62.63 1280 55.6 5.33 14.58 63.03 0 0 0 0
    64.23 1680 44.4 960 1000 63.63 1600 45.1 4.1 13.78 63.93 0 0 0 0
    65.13 1880 43.6 960 1000 64.53 1760 44.4 4.1 15.11 64.83 0 0 0 0
    66.02 2040 49.6 960 1010 65.42 1920 43.6 4.1 16.19 65.72 0 0 0 0
    66.92 2280 48.1 960 1020 66.32 2120 48.9 4.51 20.31 66.62 0 0 0 0
    68.02 2480 37.6 960 1020 67.23 2360 48.1 4.51 22.06 67.63 0 0 0 0
    68.92 2240 24.8 960 990 68.32 2400 27.8 2.46 9.28 68.62 0 0 0 0
    69.82 2000 22.6 960 980 69.22 2160 21.1 1.64 6.28 69.53 0 0 0 0
    70.72 1240 11.3 960 970 70.12 1800 17.3 1.64 3.89 70.42 0 0 0 0
    71.62 920 17.3 960 970 71.02 1040 15.8 1.64 4.22 71.32 0 0 0 0
    72.52 800 29.3 960 970 71.92 840 18 2.05 3.22 72.22 0 0 0 0
    73.42 1600 66.2 960 980 72.82 1160 55.6 5.74 12.39 73.12 0 0 0 0
    74.42 1840 59.4 960 1020 73.82 1360 67.7 6.97 17.72 74.12 0 0 0 0
    75.32 2640 57.1 960 1120 74.72 2080 57.9 6.15 28.78 75.02 0 0 0 0
    76.23 3400 53.4 960 1170 75.62 2920 57.1 5.74 32.97 75.93 0 0 0 0
    77.13 4040 49.6 960 1170 76.53 3600 51.9 4.92 36.78 76.83 0 0 3 0
    78.12 3840 11.3 960 1050 77.43 4200 36.8 3.28 26 77.73 0 0 0 0
    79.13 2600 16.5 960 990 78.43 3440 13.5 1.23 6.53 78.83 0 0 0 0
    80.03 2880 42.1 960 960 79.42 2640 15.8 1.64 6.33 79.72 0 0 0 0
    81.03 3240 53.4 960 1140 80.43 2960 60.9 5.74 35.72 80.73 0 0 0.8 0
    81.93 3520 39.1 960 1090 81.32 3360 45.1 4.1 26.22 81.62 0 0 0 0
    82.83 3360 13.5 960 1050 82.23 3600 32.3 2.87 21.89 82.53 0 0 0 0
    83.72 2400 15.8 960 1000 83.13 3040 15 1.64 6.14 83.42 0 0 0 0
    84.82 2680 14.3 960 980 84.02 2280 15 1.64 4.69 84.43 0 0 0 0
    85.73 2720 16.5 960 970 85.12 2680 12.8 1.23 6.53 85.42 0 0 0 0
    86.72 2800 21.1 960 970 86.03 2720 22.6 2.05 11.89 86.32 0 0 0 0
    87.62 2560 15 960 980 87.02 2840 15 1.64 6.58 87.31 0 0 0 0
    88.61 1560 16.5 960 970 88.02 2160 15.8 1.64 5.31 88.31 0 0 0 0
    89.61 960 18.8 960 970 88.91 1280 16.5 1.64 2.53 89.31 0 0 0 0
    90.51 760 20.3 960 970 89.91 880 18 1.64 3.19 90.21 0 0 0 0
    91.41 760 21.1 960 970 90.81 720 21.1 2.05 3.22 91.11 0 0 0 0
    92.31 760 21.1 960 970 91.71 760 21.1 2.05 3.22 92.01 0 0 0 0
    93.21 760 21.1 960 970 92.61 760 21.1 2.05 3.17 92.91 0 0 0 0
    94.11 720 22.6 960 970 93.51 720 21.1 2.05 3.11 93.81 0 0 0 0
    95.11 760 26.3 960 970 94.51 760 24.8 2.46 3.67 94.81 0 0 0 0
    96.01 1320 31.6 960 970 95.41 760 27.8 2.87 4.33 95.71 0 0 0 0
    96.91 2280 69.2 1050 970 96.31 2200 33.1 3.28 16.89 96.61 0 0 0 0
    97.82 2680 101.5 1640 1220 97.21 2320 82.7 7.79 39.97 97.52 0 0 0 0
    98.82 3480 145.9 1800 1830 98.12 2880 116.5 10.25 69.61 98.52 0 0 0 0
    99.72 4240 142.1 1720 1740 99.12 3720 141.4 12.71 98.83 99.42 0 0 0 0
    100.72 5080 136.8 1540 1610 100.12 4600 138.3 12.71 120.31 100.42 0 0 0 0
    101.62 5520 59.4 960 1250 101.02 5280 110.5 10.25 117.25 101.32 0 0 0 0
    102.52 4400 11.3 960 1080 101.92 5360 12.8 1.23 7.06 102.22 0 0 0 0
    103.42 3840 59.4 960 1010 102.82 4000 12 1.23 6.64 103.12 0 0 0 0
    104.32 4080 103.8 1420 1360 103.72 3920 107.5 9.84 88.53 104.02 0 0 0 0
    105.42 4480 120.3 1470 1480 104.62 4160 110.5 9.84 89.94 105.02 0 0 0 0
    106.32 4800 123.3 1500 1480 105.72 4560 120.3 11.07 106.06 106.02 0 0 0 0
    107.22 5040 64.7 960 1380 106.62 4920 124.1 11.07 117.86 106.92 0 0 0 0
    108.11 4480 10.5 960 1150 107.51 5080 57.1 5.33 59.61 107.81 0 0 0 0
    109.01 3640 70.7 1020 960 108.41 4040 11.3 1.23 4.36 108.71 0 0 0 0
    110.01 3840 130.8 1670 1630 109.31 3720 105.3 8.61 81.47 109.61 0 0 0 0
    110.91 4040 143.6 1820 1790 110.31 3920 133.1 11.89 101.28 110.61 0 0 0 0
    111.81 4240 144.4 1810 1790 111.21 4120 143.6 13.53 114.11 111.51 0 0 0 3
    112.71 4440 137.6 1380 1720 112.11 4320 143.6 13.94 119.11 112.41 0 0 0 3
    113.61 4440 81.2 1380 1300 113.01 4440 73.7 6.97 40.75 113.31 0 0 0 2.3
    114.51 4520 56.4 960 1230 113.91 4480 109.8 10.66 98.78 114.21 0 0 0 0.8
    115.41 4440 22.6 960 1220 114.81 4520 68.4 6.15 60.36 115.11 0 0 0 0
    116.41 4320 13.5 960 1050 115.81 4440 27.1 2.46 20.44 116.11 0 0 0 0
    117.31 4200 10.5 960 1000 116.7 4320 11.3 0 8.25 117 0 0 0 0
    118.3 4040 10.5 960 990 117.7 4160 9.8 0 8.08 118 0 0 0 0
    119.2 3920 10.5 960 990 118.61 4000 10.5 0 8.25 118.91 0 0 0 0
    120.11 3760 10.5 960 990 119.5 3880 10.5 0 8.08 119.81 0 0 0 0
    121.11 3680 59.4 960 980 120.51 3720 14.3 1.64 11.03 120.81 0 0 0 0
    122.01 3680 38.3 960 1200 121.41 3680 92.5 8.61 72.69 121.71 0 0 0 0
    122.91 3560 15 960 1040 122.31 3640 30.8 2.46 15.14 122.61 0 0 0 0
    123.8 3480 14.3 960 1000 123.2 3560 11.3 1.23 6.56 123.5 0 0 0 0
    124.71 3400 18 960 980 124.11 3440 12.8 1.23 8.28 124.41 0 0 0 0
    125.71 3280 19.5 960 980 125.01 3360 18 2.05 12.06 125.31 0 0 0 0
    126.71 3160 12.8 960 980 126.01 3240 16.5 1.64 9.33 126.31 0 0 0 0
    127.7 2440 13.5 960 980 127.1 3040 13.5 1.64 8.19 127.41 0 0 0 0
    128.59 1600 16.5 960 980 127.99 2200 12.8 1.23 5.44 128.29 0 0 0 0
    129.49 960 24.1 960 970 128.89 1320 17.3 2.05 2.86 129.19 0 0 0 0
    130.39 720 33.8 960 970 129.79 840 25.6 2.46 3.08 130.09 0 0 0 0
    131.39 720 34.6 960 970 130.69 720 34.6 3.28 3 130.99 0 0 0 0
    132.29 720 33.8 960 970 131.69 720 34.6 2.87 3.28 131.99 0 0 0 0
    133.19 760 27.1 960 970 132.59 720 33.8 2.87 3.42 132.89 0 0 0 0
    134.09 760 24.1 960 970 133.49 800 24.8 2.05 3.61 133.79 0 0 0 0
    134.99 800 24.1 960 970 134.39 760 24.1 2.05 3.61 134.69 0 0 0 0
    135.89 760 22.6 960 970 135.29 800 23.3 2.05 3.58 135.59 0 0 0 0
    136.89 760 21.8 960 970 136.29 760 21.8 2.05 3.39 136.59 0 0 0 0
    137.79 760 21.1 960 960 137.19 760 21.8 2.05 3.28 137.49 0 0 0 0
    138.69 760 21.1 960 960 138.09 760 21.1 2.05 3.19 138.39 0 0 0 0
    139.59 760 20.3 960 960 138.99 760 20.3 2.05 3.11 139.29 0 0 0 0
    140.49 760 20.3 960 960 139.89 760 20.3 2.05 2.97 140.19 0 0 0 0
    141.49 760 20.3 960 970 140.79 760 20.3 2.05 3.03 141.19 0 0 0 0
    142.39 720 20.3 960 960 141.79 760 20.3 2.05 2.97 142.09 0 0 0 0
    143.29 760 20.3 960 960 142.69 720 20.3 2.05 2.94 142.99 0 0 0 0
    144.19 760 20.3 960 960 143.59 760 20.3 2.05 3 143.89 0 0 0 0
    145.09 720 20.3 960 960 144.49 720 20.3 2.05 3 144.79 0 0 0 0
    145.99 720 20.3 960 960 145.39 720 20.3 2.05 2.94 145.69 0 0 0 0
    146.89 720 20.3 960 960 146.29 760 20.3 2.05 2.97 146.59 0 0 0 0
    147.79 720 20.3 960 960 147.19 760 20.3 2.05 2.97 147.49 0 0 0 0
    148.69 720 20.3 960 960 148.09 720 20.3 2.05 2.94 148.39 0 0 0 0
    149.58 720 21.1 960 960 148.98 720 20.3 2.05 2.94 149.28 0 0 0 0
    150.48 720 21.1 960 960 149.88 720 21.1 1.64 2.97 150.18 0 0 0 0
    151.38 720 21.1 960 960 150.78 720 21.1 1.64 2.94 151.08 0 0 0 0
    152.48 720 21.1 960 960 151.78 720 21.1 1.64 2.97 152.18 0 0 0 0
    153.38 760 21.1 960 960 152.78 760 21.1 1.64 3.03 153.08 0 0 0 0
    154.28 720 21.1 960 960 153.68 720 21.1 1.64 3 153.98 0 0 0 0
    155.18 720 21.1 960 960 154.58 720 21.1 1.64 3 154.88 0 0 0 0
    156.08 720 21.1 960 960 155.48 760 21.1 2.05 3.03 155.78 0 0 0 0
    157.08 760 21.1 960 960 156.38 760 21.1 2.05 3.11 156.78 0 0 0 0
    157.98 720 21.1 960 960 157.38 720 21.1 2.05 3.06 157.68 0 0 0 0
    158.88 720 21.1 960 960 158.28 720 21.1 2.05 3.08 158.58 0 0 0 0
    159.78 760 21.1 960 960 159.18 760 21.1 2.05 3.06 159.48 0 0 0 0
    160.68 760 21.1 960 960 160.08 720 21.1 2.05 3.08 160.38 0 0 0 0
    161.58 720 21.1 960 960 160.98 720 21.1 2.05 3.06 161.28 0 0 0 0
    162.58 760 21.1 960 970 161.88 720 21.1 2.05 3.03 162.18 0 0 0 0
    163.48 760 21.1 960 960 162.88 720 21.1 2.05 3.06 163.18 0 0 0 0
    164.38 720 21.1 960 960 163.78 720 21.1 2.05 3.06 164.08 0 0 0 0
    165.28 720 21.1 960 960 164.68 720 21.1 2.05 3.06 164.98 0 0 0 0
    166.18 760 21.1 960 960 165.58 760 21.1 2.05 3.08 165.88 0 0 0 0
    167.08 720 20.3 960 960 166.48 720 20.3 2.05 3.03 166.78 0 0 0 0
    168.08 720 20.3 960 960 167.48 720 21.1 2.05 3.06 167.78 0 0 0 0
    168.98 760 23.3 960 960 168.38 760 20.3 2.05 3.03 168.68 0 0 0 0
    169.88 680 36.1 960 970 169.28 680 28.6 3.28 3.11 169.57 0 0 0 0
    170.77 680 36.8 960 960 170.17 680 38.3 3.69 3.81 170.47 0 0 0 0
    171.67 720 36.8 960 970 171.07 680 37.6 3.28 3.94 171.37 0 0 0 0
    172.57 720 36.1 960 960 171.97 720 36.8 3.28 3.81 172.27 0 0 0 0
    173.57 760 29.3 960 970 172.87 720 36.1 2.87 3.78 173.27 0 0 0 0
    174.47 720 29.3 960 970 173.87 720 30.1 2.46 4.39 174.17 0 0 0 0
    175.37 760 29.3 960 970 174.77 760 29.3 2.46 4.33 175.07 0 0 0 0
    176.27 760 27.8 960 970 175.67 760 29.3 2.46 4.28 175.97 0 0 0 0
    177.17 760 26.3 960 970 176.57 760 27.8 2.46 4 176.87 0 0 0 0
    178.17 760 25.6 960 970 177.47 760 26.3 2.46 3.92 177.77 0 0 0 0
    179.07 760 24.1 960 970 178.47 760 24.8 2.05 3.69 178.77 0 0 0 0
    179.97 760 23.3 960 970 179.37 760 24.1 2.05 3.56 179.67 0 0 0 0
    180.87 760 22.6 960 970 180.27 760 23.3 2.05 3.5 180.57 0 0 0 0
    181.77 760 22.6 960 970 181.17 760 22.6 2.05 3.39 181.47 0 0 0 0
    182.67 760 21.8 960 970 182.07 760 21.8 2.05 3.25 182.37 0 0 0 0
    183.67 760 21.8 960 970 183.07 720 21.8 2.05 3.19 183.37 0 0 0 0
    184.57 720 21.8 960 960 183.97 760 21.8 2.05 3.19 184.27 0 0 0 0
    185.47 760 21.8 960 970 184.87 760 21.8 2.05 3.19 185.17 0 0 0 0
    186.37 720 21.1 960 970 185.77 720 21.8 2.05 3.17 186.07 0 0 0 0
    187.27 720 21.8 960 960 186.67 720 21.1 2.05 3.08 186.97 0 0 0 0
    188.17 720 21.8 960 960 187.57 760 21.8 2.05 3.19 187.87 0 0 0 0
    189.17 760 21.8 960 960 188.47 760 21.8 2.05 3.14 188.87 0 0 0 0
    190.07 720 21.8 960 960 189.47 720 21.8 2.05 3.14 189.77 0 0 0 0
    190.97 720 21.8 960 970 190.37 760 21.8 2.05 3.17 190.66 0 0 0 0
    191.86 720 21.8 960 970 191.26 760 21.8 2.05 3.14 191.56 0 0 0 0
    192.76 760 21.8 960 960 192.16 720 21.8 2.05 3.14 192.46 0 0 0 0
    193.76 720 21.8 960 960 193.06 720 21.8 2.05 3.11 193.36 0 0 0 0
    194.66 760 21.8 960 960 194.06 760 21.8 2.05 3.14 194.36 0 0 0 0
    195.56 760 21.8 960 960 194.96 720 21.8 2.05 3.14 195.26 0 0 0 0
    196.46 720 21.8 960 960 195.86 720 21.8 1.64 3.11 196.16 0 0 0 0
    197.36 720 22.6 960 960 196.76 760 22.6 2.05 3.11 197.06 0 0 0 0
    198.26 720 22.6 960 960 197.66 760 22.6 1.64 3.11 197.96 0 0 0 0
    199.26 760 22.6 960 960 198.56 720 22.6 1.64 3.08 198.96 0 0 0 0
    200.16 720 22.6 960 970 199.56 720 22.6 1.64 3.14 199.86 0 0 0 0
    201.06 760 22.6 960 960 200.46 720 22.6 1.64 3.08 200.76 0 0 0 0
    201.96 760 22.6 960 960 201.36 760 22.6 1.64 3.08 201.66 0 0 0 0
    202.86 760 22.6 960 960 202.26 720 22.6 1.64 3.08 202.56 0 0 0 0
    203.76 720 22.6 960 960 203.16 720 22.6 1.64 3.08 203.46 0 0 0 0
    204.76 760 22.6 960 960 204.06 720 22.6 1.64 3.06 204.46 0 0 0 0
    205.66 760 22.6 960 960 205.06 720 22.6 1.64 3.11 205.36 0 0 0 0
    206.56 720 22.6 960 960 205.96 720 22.6 1.64 3.08 206.26 0 0 0 0
    207.46 720 22.6 960 960 206.86 760 22.6 1.64 3.08 207.16 0 0 0 0
    208.36 760 22.6 960 960 207.76 760 22.6 1.64 3.11 208.06 0 0 0 0
    209.26 720 22.6 960 960 208.66 720 22.6 1.64 3.06 208.96 0 0 0 0
    210.26 720 23.3 960 970 209.66 720 22.6 1.64 3.06 209.96 0 0 0 0
    211.16 760 23.3 960 960 210.56 760 23.3 1.64 3.08 210.86 0 0 0 0
    212.05 760 23.3 960 960 211.46 720 23.3 1.64 3.06 211.76 0 0 0 0
    212.95 720 23.3 960 960 212.35 720 23.3 1.64 3.08 212.65 0 0 0 0
    213.86 720 23.3 960 960 213.25 720 23.3 1.64 3.08 213.55 0 0 0 0
    214.85 760 22.6 960 960 214.15 720 23.3 1.64 3.08 214.55 0 0 0 0
    215.75 1200 42.1 960 960 215.15 760 24.1 2.05 3.08 215.45 0 0 0 0
    216.65 1680 61.7 960 970 216.05 1440 40.6 4.1 11.47 216.35 0 0 0 0
    217.55 1400 66.9 960 1020 216.95 1600 64.7 6.15 22.33 217.25 0 0 0 0
    218.45 2240 57.9 960 1100 217.85 1680 70.7 6.97 24 218.15 0 0 0 0
    219.36 2920 54.9 960 1170 218.75 2440 57.9 5.74 31.06 219.05 0 0 0 0
    220.36 3400 39.1 960 1110 219.66 3120 48.9 4.51 28 220.05 0 0 0 0
    221.26 3600 35.3 960 1060 220.66 3480 36.8 3.28 23.83 220.96 0 0 0 0
    222.16 3600 17.3 960 1050 221.56 3640 32.3 3.28 21.89 221.86 0 0 0 0
    223.05 2440 15.8 960 1010 222.46 3280 16.5 1.64 9.58 222.75 0 0 0 0
    223.95 2200 31.6 960 980 223.35 2080 15.8 1.64 6 223.65 0 0 0 0
    224.95 2200 31.6 960 990 224.26 2120 33.1 3.28 13.92 224.55 0 0 0 0
    225.95 2280 18 960 990 225.35 2240 29.3 2.87 12.61 225.65 0 0 0 0
    226.95 2240 16.5 960 980 226.25 2280 16.5 1.64 5.86 226.56 0 0 0 0
    227.86 2120 12.8 960 970 227.26 2240 16.5 1.64 5.67 227.55 0 0 0 0
    228.85 1800 14.3 960 980 228.25 1960 13.5 0 3.56 228.55 0 0 0 0
    229.75 1560 16.5 960 970 229.15 1680 13.5 0 3 229.45 0 0 0 0
    230.75 1360 15 960 970 230.15 1480 15.8 1.64 3.08 230.45 0 0 0 0
    231.65 1080 16.5 960 970 231.05 1280 15 1.64 3.81 231.35 0 0 0 0
    232.55 760 21.8 960 970 231.95 920 18 1.64 3.42 232.24 0 0 0 0
    233.54 720 36.1 960 970 232.84 720 26.3 3.28 3.67 233.25 0 0 0 0
    234.44 720 43.6 960 970 233.84 760 36.1 3.28 5.67 234.14 0 0 0 0
    235.34 760 47.4 960 970 234.74 760 42.1 3.69 4.69 235.04 0 0 0 0
    236.34 920 58.6 960 970 235.74 800 54.1 4.51 8.92 236.04 0 0 0 0
    237.24 1120 61.7 960 990 236.64 960 64.7 5.74 12.47 236.94 0 0 0 0
    238.14 1320 51.1 960 1000 237.54 1200 58.6 5.74 13.25 237.84 0 0 0 0
    239.04 1440 48.1 960 1000 238.44 1360 48.1 4.51 12.5 238.74 0 0 0 0
    239.94 1520 36.1 960 990 239.34 1480 42.9 3.69 11.94 239.64 0 0 0 0
    241.04 1560 39.1 960 990 240.24 1560 39.8 3.69 12.08 240.64 0 0 0 0
    241.94 1520 21.1 960 980 241.34 1560 29.3 2.46 6.97 241.64 0 0 0 0
    242.84 1360 17.3 960 970 242.24 1480 21.1 2.05 4.42 242.54 0 0 0 0
    243.74 1280 21.1 960 970 243.14 1360 17.3 1.64 3 243.44 0 0 0 0
    244.64 1240 28.6 960 970 244.04 1240 25.6 2.46 6.56 244.34 0 0 0 0
    245.64 1240 29.3 960 970 244.94 1240 30.8 2.87 7.42 245.24 0 0 0 0
    246.54 1200 21.8 960 970 245.94 1240 24.1 2.05 4 246.24 0 0 0 0
    247.44 880 22.6 960 970 246.84 1160 21.1 1.64 3.06 247.14 0 0 0 0
    248.34 800 35.3 960 960 247.74 760 27.1 2.46 2.94 248.04 0 0 0 0
    249.24 1040 54.9 960 960 248.64 920 36.8 3.28 7.64 248.94 0 0 0 0
    250.14 1280 45.1 960 990 249.54 1120 62.4 5.33 15.67 249.84 0 0 0 0
    251.04 1000 19.5 960 990 250.44 1240 35.3 2.46 6.64 250.74 0 0 0 0
    Jan 11 2009
    Alpharetta, GA
    Re: Loping in Idle
    MORE #'S FROM RUNNING -
    Tuesday 13 January 2009 12:39:25
    TIME TIME TIME
    0.6 720 21.1 960 960 0.01 720 21.1 2.05 3.08 0.3 0 0 0 0
    1.5 720 21.1 960 960 0.9 720 21.1 2.05 3.06 1.2 0 0 0 0
    2.4 720 21.1 960 960 1.8 720 21.1 2.05 3.08 2.1 0 0 0 0
    3.4 720 21.1 960 960 2.8 720 21.1 2.05 3.08 3.1 0 0 0 0
    4.3 720 21.1 960 960 3.7 720 21.1 2.05 3.08 4 0 0 0 0
    5.2 720 21.1 960 960 4.6 720 21.1 2.05 3.08 4.9 0 0 0 0
    6.09 720 21.1 960 960 5.49 720 21.1 2.05 3.08 5.79 0 0 0 0
    6.99 720 21.1 960 960 6.39 720 21.1 2.05 3.06 6.69 0 0 0 0
    7.99 720 21.1 960 960 7.29 720 21.1 2.05 3.08 7.69 0 0 0 0
    8.89 720 21.1 960 960 8.29 720 21.1 2.05 3.08 8.59 0 0 0 0
    9.79 720 21.1 960 960 9.19 720 21.1 2.05 3.08 9.49 0 0 0 0
    10.69 720 21.1 960 960 10.09 720 21.1 2.05 3.08 10.39 0 0 0 0
    11.59 720 21.1 960 960 10.99 720 21.1 2.05 3.06 11.29 0 0 0 0
    12.59 720 21.1 960 960 11.89 720 21.1 2.05 3.06 12.19 0 0 0 0
    13.49 720 21.1 960 960 12.89 760 21.1 2.05 3.08 13.19 0 0 0 0
    14.39 720 21.1 960 960 13.79 720 21.1 2.05 3.06 14.09 0 0 0 0
    15.29 720 21.1 960 960 14.69 720 21.1 2.05 3.08 14.99 0 0 0 0
    16.19 760 21.1 960 960 15.59 720 21.1 2.05 3.08 15.89 0 0 0 0
    17.09 720 21.1 960 960 16.49 760 21.1 2.05 3.08 16.79 0 0 0 0
    17.99 720 21.1 960 960 17.39 720 21.1 2.05 3.08 17.69 0 0 0 0
    18.99 720 21.1 960 960 18.39 720 21.1 2.05 3.06 18.69 0 0 0 0
    19.89 720 21.1 960 960 19.29 720 21.1 2.05 3.08 19.59 0 0 0 0
    20.79 720 21.1 960 960 20.19 760 21.1 2.05 3.08 20.49 0 0 0 0
    21.69 720 21.1 960 960 21.09 720 21.1 2.05 3.08 21.39 0 0 0 0
    22.59 720 21.1 960 960 21.99 760 21.1 2.05 3.08 22.29 0 0 0 0
    23.59 720 21.1 960 970 22.89 720 21.1 2.05 3.08 23.29 0 0 0 0
    24.49 760 21.1 960 960 23.89 720 21.1 2.05 3.08 24.19 0 0 0 0
    25.39 720 21.1 960 960 24.79 720 21.1 2.05 3.08 25.09 0 0 0 0
    26.29 720 21.1 960 960 25.69 760 21.1 2.05 3.08 25.98 0 0 0 0
    27.18 720 21.1 960 960 26.58 720 21.1 2.05 3.08 26.88 0 0 0 0
    28.18 720 21.1 960 960 27.48 760 21.1 2.05 3.08 27.78 0 0 0 0
    29.08 720 21.1 960 960 28.48 720 21.1 2.05 3.08 28.78 0 0 0 0
    29.98 720 21.1 960 960 29.38 720 21.1 2.05 3.08 29.68 0 0 0 0
    30.88 720 21.1 960 960 30.28 720 21.1 2.05 3.08 30.58 0 0 0 0
    31.78 760 21.1 960 960 31.18 720 21.1 2.05 3.08 31.48 0 0 0 0
    32.68 720 21.1 960 960 32.08 720 21.1 2.05 3.03 32.38 0 0 0 0
    33.58 720 21.1 960 960 32.98 720 21.1 2.05 3.11 33.28 0 0 0 0
    34.58 720 21.1 960 960 33.98 720 21.1 2.05 3.06 34.28 0 0 0 0
    35.48 720 21.1 960 960 34.88 720 21.1 2.05 3.08 35.18 0 0 0 0
    36.38 760 21.1 960 960 35.78 720 21.1 2.05 3.08 36.08 0 0 0 0
    37.28 720 21.1 960 960 36.68 720 21.1 2.05 3.08 36.98 0 0 0 0
    38.28 760 21.1 960 960 37.68 720 21.1 2.05 3.08 37.98 0 0 0 0
    39.18 1760 48.9 960 960 38.58 760 21.1 2.05 3.36 38.88 0 0 0 0
    40.08 1320 69.2 1030 1010 39.48 1800 58.6 6.15 23.14 39.78 0 0 0 0
    40.98 1920 75.2 1300 1060 40.38 1320 69.2 6.56 17.92 40.68 0 0 0 0
    41.99 3200 103 1320 1350 41.28 2240 82 7.79 37.14 41.59 0 0 0 0
    42.99 4280 51.9 960 1240 42.39 3800 88.7 7.79 62.42 42.69 0 0 0 0
    43.89 3920 12.8 960 1060 43.29 4400 30.8 2.46 19.14 43.59 0 0 0 0
    44.89 3000 63.9 1320 960 44.19 3560 15 1.23 8.36 44.59 0 0 0 0
    45.89 3400 97 1200 1320 45.28 2960 82.7 7.38 56.08 45.59 0 0 0 0
    46.79 3880 116.5 1440 1360 46.19 3520 71.4 6.56 42.92 46.49 0 0 0 0
    47.69 4440 100 1320 1430 47.09 4080 111.3 10.25 87.83 47.38 0 0 0 0
    48.58 4760 65.4 960 1270 47.98 4560 81.2 7.38 68.36 48.28 0 0 0 0
    49.58 4920 35.3 960 1180 48.88 4840 68.4 6.56 66.47 49.18 0 0 0 0
    50.48 4800 18 960 1040 49.88 4880 23.3 2.05 14.31 50.18 0 0 0 0
    51.38 3800 12.8 960 1000 50.78 4560 12 1.23 7.83 51.08 0 0 0 0
    52.27 2720 18.8 960 990 51.68 3440 15 1.64 7.83 51.97 0 0 0 0
    53.17 2520 81.2 1410 1020 52.57 2400 39.1 3.69 18.97 52.87 0 0 0 0
    54.07 2640 106.8 960 1360 53.47 2560 88.7 8.2 45.97 53.77 0 0 0 0
    54.98 2760 88.7 1810 1170 54.37 2680 68.4 6.56 27.25 54.67 0 0 0 0
    55.97 2960 97 1840 1280 55.27 2840 91 8.61 50.17 55.58 0 0 0 0
    56.88 3200 144.4 1760 1860 56.27 3040 130.8 11.89 78.58 56.58 0 0 0 0
    57.98 3480 85 1230 1490 57.28 3320 133.1 12.3 82.81 57.68 0 0 0 0
    58.88 3600 83.5 1260 1300 58.28 3520 75.2 6.97 48.78 58.58 0 0 0 0
    59.88 3760 82 960 1340 59.28 3640 78.9 7.79 57.64 59.58 0 0 0 0
    60.88 3800 92.5 1130 1290 60.18 3720 39.8 3.28 21 60.58 0 0 0 0
    61.78 3800 24.8 960 1140 61.18 3840 56.4 5.33 31.39 61.47 0 0 0 0
    62.67 3680 10.5 960 1020 62.07 3760 16.5 1.64 7.5 62.38 0 0 0 0
    63.58 3560 11.3 960 1000 62.97 3680 11.3 0 6.67 63.28 0 0 0 0
    64.57 3400 12 960 1000 63.97 3480 11.3 0 6.67 64.27 0 0 0 0
    65.57 3200 9.8 960 1000 64.87 3320 9.8 0 6.47 65.27 0 0 0 0
    66.47 3040 9.8 960 990 65.87 3160 9.8 0 6.03 66.17 0 0 0 0
    67.37 2040 10.5 960 990 66.77 2840 10.5 0 5.92 67.07 0 0 0 0
    68.27 1240 12.8 960 980 67.67 1720 12.8 1.64 4.33 67.97 0 0 0 0
    69.16 920 18.8 960 970 68.56 1120 12.8 1.64 2.97 68.86 0 0 0 0
    70.16 720 20.3 960 970 69.46 840 18.8 1.64 3.28 69.76 0 0 0 0
    71.06 760 21.8 960 970 70.46 720 21.8 2.05 3.31 70.76 0 0 0 0
    71.96 760 21.1 960 970 71.36 760 21.1 2.05 3.19 71.66 0 0 0 0
    72.86 760 21.1 960 960 72.26 760 21.1 2.05 3.19 72.56 0 0 0 0
    73.76 760 20.3 960 960 73.16 760 21.1 2.05 3.11 73.46 0 0 0 0
    74.66 720 23.3 960 960 74.06 720 21.1 2.05 3.14 74.36 0 0 0 0
    75.66 760 28.6 960 960 75.06 760 22.6 2.46 3.36 75.36 0 0 0 0
    76.56 1000 33.8 960 960 75.96 720 28.6 2.87 4.03 76.26 0 0 0 0
    77.46 1600 69.2 960 970 76.86 1680 42.1 4.1 16.56 77.16 0 0 0 0
    78.36 1960 81.2 1170 1050 77.76 1720 69.9 6.56 23.53 78.06 0 0 0 0
    79.26 2440 89.5 1170 1220 78.66 2120 82 7.79 34.56 78.96 0 0 0 0
    80.17 2960 72.2 960 1280 79.57 2640 86.5 7.79 41.58 79.87 0 0 0 0
    81.17 3280 46.6 960 1130 80.47 3080 60.2 5.33 30.33 80.87 0 0 0 0
    82.16 3400 39.1 960 1070 81.47 3320 44.4 4.1 28.44 81.77 0 0 0 0
    83.07 3400 35.3 960 1050 82.47 3440 37.6 3.69 24.61 82.77 0 0 0 0
    84.07 3360 46.6 960 1020 83.37 3400 35.3 3.28 22.67 83.77 0 0 0 0
    84.97 3440 51.1 960 1190 84.37 3400 64.7 6.15 45.42 84.67 0 0 0 0
    85.97 3520 39.1 960 1120 85.27 3480 46.6 4.1 30.28 85.67 0 0 0 0
    86.87 3520 26.3 960 1050 86.27 3520 34.6 2.87 22.08 86.56 0 0 0 0
    87.76 3360 13.5 960 1020 87.17 3480 27.1 2.46 17.97 87.47 0 0 0 0
    88.67 3240 19.5 960 990 88.06 3320 12.8 1.23 8.39 88.36 0 0 0 0
    89.56 3000 15.8 960 990 88.96 3160 20.3 2.05 12.36 89.26 0 0 0 0
    90.65 2200 13.5 960 980 89.86 2920 13.5 1.64 8.22 90.25 0 0 0 0
    91.55 1280 18 960 970 90.95 1960 14.3 0 3.25 91.25 0 0 0 0
    92.45 840 26.3 960 970 91.85 1040 21.1 2.46 4 92.15 0 0 0 0
    93.35 720 34.6 960 970 92.75 760 28.6 2.87 3.03 93.05 0 0 0 0
    94.25 720 35.3 960 960 93.65 720 34.6 2.87 3.25 93.95 0 0 0 0
    95.15 720 34.6 960 960 94.55 720 35.3 2.87 3.25 94.85 0 0 0 0
    96.05 800 27.1 960 960 95.45 760 34.6 2.87 3.5 95.75 0 0 0 0
    97.05 1240 45.9 960 960 96.45 720 39.8 4.51 8.56 96.75 0 0 0 0
    97.95 1280 65.4 1010 970 97.35 1200 49.6 4.1 12.69 97.65 0 0 0 0
    98.85 2080 70.7 960 1020 98.25 1560 66.2 5.74 21.28 98.55 0 0 0 0
    99.86 2840 57.9 1000 1200 99.15 2280 84.2 8.2 37.25 99.46 0 0 0 0
    100.76 3920 95.5 1090 1340 100.16 3200 98.5 9.43 65.08 100.46 0 0 0 0
    101.66 4960 83.5 960 1330 101.06 4280 88 8.2 71.97 101.36 0 0 0 0
    102.56 4360 8.3 960 1120 101.96 5200 61.7 5.74 58.36 102.26 0 0 0 0
    103.46 3280 35.3 960 980 102.85 3920 9.8 1.23 3.64 103.16 0 0 0 0
    104.35 2560 97 1760 1180 103.75 2760 63.2 6.56 38.86 104.05 0 0 0 0
    105.25 2960 137.6 1840 1620 104.66 2680 107.5 9.84 58.36 104.95 0 0 0 0
    106.16 3440 144.4 1840 1830 105.55 3080 150.4 13.94 90.5 105.86 0 0 0 0
    107.16 4000 143.6 1720 1800 106.46 3600 143.6 12.71 99.42 106.76 3 0 0 0
    108.16 4480 127.1 1560 1570 107.46 4160 137.6 12.3 106.78 107.86 3 0 0 0
    109.06 4800 85.7 1210 1400 108.46 4600 109 9.43 89.36 108.76 2.3 0 0 0
    109.96 4960 50.4 960 1230 109.36 4880 82.7 7.38 81.33 109.65 2.3 0 0 0
    110.85 5000 26.3 960 1210 110.25 5000 52.6 4.51 48.75 110.55 0 0 0 0
    111.75 3880 9.8 960 1030 111.15 4760 9 1.23 3.36 111.45 0 0 0 0
    112.84 2920 25.6 960 980 112.14 3360 12 1.23 6.22 112.54 0 0 0 0
    113.75 2920 42.9 960 1000 113.14 2920 34.6 3.28 22.36 113.44 0 0 0 0
    114.64 2920 15.8 960 1080 114.05 2960 68.4 6.15 41.89 114.34 0 0 0 0
    115.54 2920 11.3 960 1010 114.94 2920 14.3 0 4.94 115.24 0 0 0 0
    116.44 2840 10.5 960 990 115.84 2880 11.3 0 4.06 116.14 0 0 0 0
    117.34 2760 8.3 960 980 116.74 2800 10.5 0 4.14 117.04 0 0 0 0
    118.24 2720 7.5 960 980 117.64 2760 7.5 0 4.06 117.94 0 0 0 0
    119.14 2640 7.5 960 980 118.54 2720 7.5 0 4.17 118.84 0 0 0 0
    120.04 2120 9 960 980 119.44 2640 8.3 0 4.22 119.74 0 0 0 0
    120.94 1280 11.3 960 970 120.34 1800 9.8 1.64 4.22 120.64 0 0 0 0
    121.84 920 21.8 960 970 121.24 1120 12 1.23 3.28 121.54 0 0 0 0
    122.84 720 34.6 960 970 122.14 800 25.6 2.46 2.89 122.44 0 0 0 0
    123.74 720 34.6 960 970 123.14 720 33.8 2.87 3.28 123.44 0 0 0 0
    124.64 720 33.8 960 970 124.04 720 34.6 2.87 3.31 124.34 0 0 0 0
    125.54 760 28.6 960 970 124.94 720 33.8 2.87 3.28 125.24 0 0 0 0
    126.44 760 25.6 960 970 125.84 760 25.6 2.05 3.81 126.14 0 0 0 0
    127.34 760 24.1 960 970 126.74 760 25.6 2.05 3.83 127.04 0 0 0 0
    128.34 760 23.3 960 970 127.74 760 24.1 2.05 3.69 128.04 0 0 0 0
    129.24 760 22.6 960 970 128.64 760 23.3 2.05 3.56 128.94 0 0 0 0
    130.14 760 21.8 960 960 129.54 760 23.3 2.05 3.56 129.84 0 0 0 0
    131.04 760 21.8 960 970 130.44 760 21.8 2.05 3.33 130.73 0 0 0 0
    131.94 760 21.8 960 960 131.33 760 21.8 2.05 3.25 131.63 0 0 0 0
    132.93 760 21.8 960 970 132.23 760 21.8 2.05 3.25 132.63 0 0 0 0
    133.83 760 21.8 960 960 133.23 760 21.8 2.05 3.19 133.53 0 0 0 0
    134.73 760 21.1 960 960 134.13 760 21.1 2.05 3.08 134.43 0 0 0 0
    135.63 760 21.1 960 960 135.03 760 21.1 2.05 3.14 135.33 0 0 0 0
    136.53 760 21.1 960 960 135.93 760 21.1 2.05 3.06 136.23 0 0 0 0
    137.43 760 20.3 960 970 136.83 760 20.3 2.05 3.06 137.13 0 0 0 0
    138.43 680 21.1 960 960 137.73 720 20.3 2.05 3.03 138.03 0 0 0 0
    139.43 680 39.8 960 970 138.83 680 31.6 3.69 3.94 139.13 0 0 0 0
    140.33 720 39.8 960 970 139.73 680 41.4 4.1 4.03 140.03 0 0 0 0
    141.23 800 37.6 960 970 140.63 720 39.8 3.69 4.28 140.93 0 0 0 0
    142.13 1600 23.3 960 970 141.53 1120 33.1 2.46 5.44 141.83 0 0 0 0
    143.03 1560 18.8 960 970 142.43 1640 21.8 1.64 5.08 142.73 0 0 0 0
    144.03 1320 18.8 960 970 143.33 1480 18.8 1.64 3.81 143.73 0 0 0 0
    144.93 1400 17.3 960 970 144.33 1360 15.8 1.23 3.89 144.63 0 0 0 0
    145.83 1480 39.8 960 960 145.23 1400 18.8 2.05 3.44 145.53 0 0 0 0
    146.73 1600 42.1 960 970 146.13 1560 39.8 3.69 11.31 146.43 0 0 0 0
    147.63 1760 62.4 960 980 147.03 1640 45.1 4.1 15.14 147.33 0 0 0 0
    148.63 1880 43.6 960 1020 147.94 1800 55.6 4.92 17.56 148.33 0 0 0 0
    149.53 1960 60.2 960 990 148.93 1920 37.6 3.28 13.69 149.23 0 0 0 0
    150.43 2080 37.6 960 1030 149.84 2000 51.1 4.1 16.33 150.13 0 0 0 0
    151.33 1960 21.1 960 1000 150.73 2040 24.8 2.05 6.06 151.03 0 0 0 0
    152.23 1880 17.3 960 980 151.62 1920 17.3 1.64 3.92 151.92 0 0 0 0
    153.12 1200 18 960 970 152.52 1720 15.8 1.23 3.61 152.82 0 0 0 0
    154.02 840 25.6 960 970 153.42 1040 21.8 1.64 3.19 153.72 0 0 0 0
    154.92 680 33.1 960 970 154.32 720 27.8 2.05 2.67 154.62 0 0 0 0
    155.82 720 34.6 960 970 155.22 720 33.8 2.46 3.17 155.52 0 0 0 0
    156.72 720 36.1 960 970 156.12 720 35.3 2.46 3.31 156.42 0 0 0 0
    157.62 720 39.8 960 970 157.02 720 39.1 3.28 5.64 157.32 0 0 0 0
    158.52 760 39.1 960 970 157.92 720 47.4 3.28 7.83 158.22 0 0 0 0
    159.52 720 35.3 960 970 158.92 760 35.3 2.46 3.53 159.22 0 0 0 0
    160.42 720 41.4 960 970 159.82 720 38.3 2.87 6.08 160.12 0 0 0 0
    161.32 720 41.4 960 970 160.72 720 39.1 2.87 4.81 161.02 0 0 0 0
    162.22 760 39.1 960 970 161.62 760 41.4 3.28 4.94 161.92 0 0 0 0
    163.12 720 34.6 960 970 162.52 800 38.3 2.87 4.53 162.82 0 0 0 0
    164.12 720 35.3 960 970 163.42 720 35.3 2.46 3.5 163.82 0 0 0 0
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: Loping in Idle
    Whoa! Lot of data there.
    I'd start simple:
    - MAF (common on a 7-8 y/o TT): try unlugging it at idle and see if it runs better. If so, get some MAF/Contact cleaner, shoot it, let dry, reassemble, and reevaluate with the plug connected.
    - Trim vacuum lines (also common at that age): they get brittle and develop hairline cracks which cause surging or loping (good word!). See if you can pull the LTF/STF (long-term/short-term fuel trim) values. This can help pinpoint the trim lines as the culprit.
    BTW-
    I and Cherokee Chapter of ACNA are very active in the area. We have a RingTec Tuesday night at RingTec Atlanta. Usually 4-8 of us G2G to poke into the cars. You might drop by, say hi, and we'll see whasup. Paul Meredith will usually do a gratis code check/reset and advise whether it's DIY or you need professional (his or other) help.
    TED
    Cherokee Chapter ACNA
    Welcome to the TT club! You'll love it!
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: Loping in Idle
    PS- I'm also on AW in the Southeast Forum. Lots of over there. You alos pposted this to the AW TT Forum, right?
    Jan 11 2009
    Alpharetta, GA
    Re: Loping in Idle
    yes I posted it on both forums. I went to autozone on lunch and cleaned the MAF and replaced the air filter. The air filter was pretty dirty so in a few days I will pull the codes again and see if that worked. I love my new little tt! I am definately interested in some local groups. It took me a year to find someone selling the color combo that I wanted. This has been my favorite car ever since I first saw one back in 2000.
    Jan 11 2009
    Alpharetta, GA
    Re: Loping in Idle
    Okay, so it didnt lope at all since we cleaned the MAF. Ran the codes at lunch and nothing has come back.
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: Loping in Idle
    Good to hear. If you're rnning a K&N filter, keep it clean. If your replacement is paper, cleaning the MAF is good PM every now and then. You still might want to look at the PCV system.
