Results 1 to 27 of 27
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    BAT guys... what high impedence injector is there in the 700cc+ range?
    We want to up the injector size but I'm having problems finding a flow match set in the 700cc+ range.
    TIA for any info.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: BAT guys... what high impedence injector is there in the 700cc+ range?
    Bosch 1000cc's
    Jun 11 2005
    Vancouver, BC
    I don't want to run a resistor box at this time.
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Ask the boys at USRT
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Apr 16 2007
    Queens
    2003 A4 1.8TQM
    Oct 27 2007
    In the lab
    Quote Originally Posted by [email protected] View Post
    I know, that's why I was talking about these http://www.t1raceparts.com/1000cc_Bo...r_p/b1000s.htm
    I wouldn't give you a low Z injector
    Sep 17 2005
    Fremont, California
    TIA for any info.
    We offer this 780cc injector:
    Jun 11 2005
    Vancouver, BC
    Is that a Delphi injector?
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Lucas injector
    Basically the same as an RC Engineering injector.
    Jun 30 2007
    Raleigh, NC
    there's racetronix 850's.... I'll look for the link - I have it saved somewhere
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Jun 30 2007
    Raleigh, NC
    The Awesome™
    Jun 11 2005
    Vancouver, BC
    Thanks.
    I'll check it out.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    I am suprised Winston that you haven't been paying attention to the thead of Jakes dad's B6 that is running those 780cc(75lbs) injectors which put down 417whp on 93 and now 465whp on 100.
    Jun 11 2005
    Vancouver, BC
    I've read that thread and congratulate his Dad for cracking the 400hp mark.
    Gives me hope that I can too as well.
    Oct 29 2005
    10speed
    San Francisco, CA
    Winston, why dont you want to run the resistor box?
    - Clint
    Jun 11 2005
    Vancouver, BC
    Why? To keep things simple.
    I don't like to introduce things into a system when they are not required.
    Jul 07 2004
    socal
    Because there isn't really a need to do it seeing that there are plenty of high imp injectors that will work fine for what he needs.
    Jan 25 2006
    A4 2.0T
    MD
    Indeed skip the resistors.....
    Oct 29 2005
    10speed
    San Francisco, CA
    fair enough, they work, they're cheaper, and Tapp has a file for them but whatevs
    - Clint
    Jul 07 2004
    socal
    Cheaper then what?
    034 site
    75 lbs high imp injector = $76/each
    75 lbs low imp injector = $73/each
    96 llbs low imp injector = $75/each
    So how is buying low imp injectors and Resistor packs cheaper then buying the 75 lbs high imp injectors? Well unless those resistor packs are less then $1 each.
    Oct 29 2005
    10speed
    San Francisco, CA
    Cheaper then what?
    034 site
    The only ones I would get are the Bosch 1000cc, which are ~$100 each
    - Clint
    Jan 25 2006
    A4 2.0T
    MD
    Winston isn't setup or looking to make as much power as you.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Don Supreme View Post
    muaahhahaha, if I ever do
    - Clint
    Jun 11 2005
    Vancouver, BC
    Actually Winston wants to maintain a nice idle!
    Oct 27 2007
    In the lab
    I idle better on 1000's than I did on 630's... The high-z 1000's are awesome
    Jul 07 2004
    socal
    Quote Originally Posted by 317ssayzarc View Post
    You cant really compare that messed up tune you had with the 630's. Your car bearly ran at all with it.
    Oct 27 2007
    In the lab
    Car idled great always... The new car idles lower and smoother
