Results 1 to 30 of 30
    Veteran Member Three Rings braker15's Avatar
    Nov 15 2008
    2000 S4 Nogaro Blue
    S.Florida
    Lightbulb what is neccesary for stage 1+?
    hey folks, Iam thinking of going 1+, so I was wondering what would be a must upgrade on the car, besides the injectors?
    or am I all set? So far I got apr1, forge007 and magnaflow exhaust.
    thanks
    Jun 08 2008
    Calgary AB Canada
    Re: what is neccesary for stage 1+?
    good to go.
    Nov 15 2008
    2000 S4 Nogaro Blue
    S.Florida
    Quote Originally Posted by onceover View Post
    good to go.
    wouldn't it hurt my turbo and overall performance without an intercooler or
    a testpipe/downpipe?
    Jun 08 2008
    Calgary AB Canada
    wont hurt, but yes, both will help.
    especially in florida youll notice a lot of heatsoak with the stock SMIC.
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    FMIC, HFC or Testpipe, Exhast, DV, Metal TIP. Fool proof 1+ setup. Also good foundations if you ever decide to up the power. Think long run if you plan to do more.
    CT4952
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    The Apikol SMIC ($550) could also be an option, if you don't want to spend too much.
    -Siggie, will you be running a TP or HFC?
    Veteran Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2008 Rs4
    Testpipe,downpipe, cat back exhaust, front mount intercooler, software(apr,revo,giac,unitronics,ect.) and appropriate injectors. Snub mount, motor and tranny mounts prob wouldnt be bad this to change while your doing the work though!
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    spare coil packs are also necessary
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Buncha motorcycles
    Memphis, TN
    bulletproof 1+
    hitachi E's Coilpacks
    FMIC (not apikol SMIC either, they only saw a 20-30 degree reduction in IATs whereas a racetec will drop them 80-100 degrees) i saw the biggest gain in power with my FMIC, not exhaust or test pipe
    test pipe is great for keeping your EGTs down and letting the car cool down much quicker. 1+ runs 950+ EGTs
    TIP (forge or winston SS tip)
    new DV
    keep in mind anytime you double your factory boost, it will expose any weak points in the car (clutch, CPs etc)
    APR Stage 2/AWE Intake
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Skip on the Apikol SMIC. Not worth the price tag IMO. I bought it and then ended up going to a FMIC a month later because it wasn't providing enough cooling. The car still heat soaked after a run or two. For the price, you'll spend a little more for better cooling. $550 vs $825, less than a $300 difference...worth the gain IMO. Now with the RaceTec, it'll pull and pull without heat soaking.
    Apikol lowered the IAT about 20 degrees over stock. 190 F vs 170 F
    RaceTec lowered the IAT about 77 degress over stock. 190 F vs 113 F
    The Apikol unit is nice and all but still doesn't get the job done right, especially for the price.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Oct 22 2005
    Reppin the Mitten.
    money.
    Aug 23 2008
    2008 Rs4
    Fmic if you are looking for a bulletproof no heatsock problems way to go.....I forgot to mention a good dv too!
    Jacob
    USPCLUBMEMBER#190
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by gdawg'05a4 View Post
    good info
    people rag on me because i push the FMIC so much on 1+ but it really makes it a new car again
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    You need HUGE brakes, like a Boeing 747 big
    02 A4 3.0Q6MT
    -chad
    May 19 2008
    2003 A4 1.8TQ, 2006 Cadillac CTS
    Bakersfield, CA
    Your Racetek showed a 80-100 degree drop in IAT's?? Holy sh@t that's awesome and close to water meth injection IAT reduction.
    May 19 2008
    Bakersfield, CA
    Whats the difference then from Racetek vs. Racewerks competition other than cost obviously???
    EvolutionRacewerks Competition FMIC 2002-05 A4 1.8T
    Now: $1,595.00 - $1,695.00
    Eurocode Tuning
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Quote Originally Posted by dr. brian View Post
    Eurocode Tuning
    The ER competition FMIC is meant for larger Gt28 series turbos and would be overkill for a 1+ setup. The Racetek is the way to go.
    Off topic: Dr. Brian, what field are you in?
    Cheers
    Buncha motorcycles
    Memphis, TN
    pretty much what he said.. the racetec is 380 cu in and the er comp is 600 cu in plus it has to have a new bumper rebar to fit and comes with a PS cooler... but i bought a 4x8 tranny cooler from advanced auto for $19.99. its the same thing that comes with the er comp
    BTW my racetec fit without having to trim the bumper at all
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    Quote Originally Posted by FourRings80 View Post
    I'm running the eurocode testpipe right now. My EGT is tapped into the testpipe right after the turbo. I might consider moving to a HFC the one 034 makes
    CT4952
    Mar 20 2006
    I would skip the testpipe. For a 1+ setup or even a K04, the testpipe isn't necessary. Get a HFC if you are really concerned, but you aren't going to make enough power with that setup to warrant going to a straight exhaust. Get an ATP manifold before you go for a testpipe.
    Trust me, you didn't buy an Audi so you could smell like gas fumes while idling at a red light.
    EDIT: All the software flashes are coded to run with a cat anyway, so why go to a straight pipe? Look, even with a 1+ you're only going to make 50 FtLbs more torque...Hardly earth shattering.
    Mar 20 2006
    Quote Originally Posted by Papachristou View Post
    That's the way to do it
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by KPC1.8TQuat View Post
    those are great points but honestly i dont smell any gas while out in the open with my car (or i could be used to it ) and i think the test pipe actually does more for the health of the turbo/manifold/oil because the lack of a cat allows all those hot gasses to escape instead of being held back by the cat. my TP lowered my EGTs and my car used to take 5 minutes to return to normal operating temps (around 400c EGTs) plus my cat, turbo and manifold would be glowing red after driving (this was stock too BTW) now with 1+ it barely gets red and returns to 400 in about 1-2 minutes depending on if i drove it easy the last few miles.
    just my two cents on it, only you can decide whats right for you
    Mar 20 2006
    Yeah, Papa you are totaly spot on about the EGT's. It's physics really. Less restriction, better low, of course it will lower temps. I also never looked it it this way, but you're right, it probably is better for the condition or lifespan of the turbo and mannifold.
    As for the gas smell, I've never had a car with a TP. My friend had a B5 A4 with one however, and it was absolutely toxic for city driving. I'm sure everyone has different experiences though.
    Side Story Time:
    In my friend's B5, bombing around some country roads at like 11pm, get nicked by a cop. He comes to the window and says, "You passed me doing 90 with flames shooting out of your tailpipe..." No lie, hands to my chest truth my friend goes, "flames? really? awesome!"
    $300+ ticket for speeding and for the illegal exhaust.
    Buncha motorcycles
    Memphis, TN
    oh thats a nice story! ive never been told that i shoot flames lol!
    i can smell it a little when the car first starts up but its in a garage, when its running and warmed up its not as bad.. its worth it IMO... i cant get the mani/turbo/TP as red with apr 1+ as i used to get the mani/turbo/cat with stock programming
    Mar 20 2006
    Papa, all good things bro.
    You have to deal with emissions testing? NH is usually pretty light on laws in general but for some reason they take emissions wicked seriously.
    Live free or die.....as long as you have a stock exhaust.
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    ^i'm running one and you don't smell it while in the car. Sometimes when i get out of the car i could smell it. Also i've never been behind my own car so i can't tell how bad it is for the person behind me. +EGTs yeah they definately have gone down. With a HFC+3"dp you could reduce EGTs as well.
    i have to get an E-test this coming year so... i'll have to slap the old cat back on or i might just got HFC.
    CT4952
    May 03 2005
    Boston
    good info
    Yup, it really does make a huge difference. In the Winter time, it makes a difference too even though it's already cold outside.
    EPL S2 + TCU
    Previous Cars:
    Veteran Member Three Rings B8Buckeye's Avatar
    Mar 14 2005
    2011 Audi A5 Cabriolet - Ibis White and 2016 Mercedes Benx Metris conversion van - Obsidian Black
    NW Ohio
    good info
    i'm with you papachristou. the FMIC is a MUST for anything above a standard stage 1. people tend to think only of added power. just as important is retained power. what good is a mod that add 50hp if it only lasts one or 2 runs? with the right cooling, you can have that added benefit on every run. it makes sense to pay for the cooling now so you can enjoy all the added power later.
    2011 A4 Avant 2.0T Quattro ZF8 - Brilliant Black - Sport & Cold Weather Packages
    Magma S4 Seats & Door Cards with Brushed Aluminum Trim, B8.5 S-line Auto Shift Knob, RSNav S3 10.25", 19" OEM 5-Arm Cutters, RS4-style Honeycomb Center & Fog Grilles, deAutoLED Turns & Fogs, OEM B8.5 Euro LED Tails, OEM S-line Stone Guards & Rear Valence, IE HFC/DP, Milltek CBE, UM Stage 2, ECS Coilovers
    Buncha motorcycles
    Memphis, TN
    lol, yeah some of the northern states are getting crazy high speeding fines now i heard too, like $1-2k... i live just outside Memphis actually in Arkansas and they dont check anything here.. so many rednecks are running around in pickups with straight pipes, no one bothers to check one little audi if i was in a strict state, i would try to do a relocated HFC to get the cat farther away from the turbo.
    nothing like a hard pull on the interstate with a FMIC in winter it pulls so much harder than before!
    Quote Originally Posted by B6Buckeye View Post
    very very true... i think even from the get go, i am making more power because of the cooled air, especially when its nice and cool in the morning or winter. Overall my favorite power mod so far besides the chip/injectors of course..... after running logs before and after i realized how important it was. i was hitting 175-180F IATs in 85F weather. After putting on the Racetec i couldnt get my IATs above 95F
    Oct 07 2008
    East Texas
    I just got my GIAC Stage1+ done Tuesday and I am VERY happy with the gain I got from just the 1. I don't have a FMIC right now but I plan on that and a TIP to be my next mods when when tax return/Obama's Stimulus checks come out!
    02 A4 3.0Q6MT
    -chad
