Results 1 to 6 of 6
    Veteran Member Three Rings Fink_tha_Audi's Avatar
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    Middletown, Delaware
    limp mode on AEB engine?
    I have a 99.5 A4 with a apr tune and was wondering does my car have a limp mode,since the throttle is connected thru a cable. I hit 17psi all day. Does limp exist in 2000 to 2001 models? I not sure.
    99.5 A4 1.8 TQM
    Eliminator GT2871R, UNITRONIC "440cc" tune, FMIC, 2.5" exhaust, SB Stg 4, Gutted LaBree, B&M short shifter, 034 Snub Mount, AWE DTS, LLTEK FR Strut Bar, Synapse DV, SCAT Rods, 034 HF Exhaust Manifold
    Feb 27 2005
    North Wales, PA
    Re: limp mode on AEB engine?
    limp mode on DBW usually means overboosting and limp on DBC usually means MAF from my experience.
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    Yes it does
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    Quote Originally Posted by Poopie View Post
    What do you mean usually the MAF? How does that affect the car?
    99.5 A4 1.8 TQM
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    When you are Dbc you have limp mode with your n75 giving you 5psi of boost but if you have a MBC you wont get it.
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    limp mode can be caused by a few things in a nDBW car.
    throttle is a usual suspect
