You want these ones. They're an 18mm short anti fouler pack. The packaging could be different so just match up the part #. And then you only want to drill out 1 of the anti foulers. The side that has the tiny hole on it so that when you screw the o2 sensor into it, it will actually fit. Then that anti fouler screws into the other one so the o2 sensor is essentially inside the other anti fouler. Then you screw that whole assembly into the o2 sensor's spot on the test pipe. And it will be the 2nd sensor (farthest from the turbo).
So essentially the combination of the sensor being spaced farther out and the little hole preventing more exhaust from getting to the sensor makes it think you have a catalytic converter. I did this on mine and it has been working for over 3k miles now.
And for reference it will look like this
