Originally Posted by
sumpsfast
Those goons over at Avalon
Specified boost request is 2300mb peak and at just past peak torque WGDC is maxed out through redline. There is a negative deviation between req and actual, apparently throwing a sporadic "boost pressure not reached" fault code. The pressure test will reveal whether a boost leak is causing the turbo to overspin to meet request otherwise steps will be taken to alleviate the issue.
22 psi is a heck of a lot on a K03 of any variety, and because the shaft must spin approx 1% faster per 500 ft elevation, there is no doubt its working its butt off and is out of breath approaching peak power. And yes, absolutely, running 95% duty cycle at 6000 ft is a great way to decrease the life of the turbo...
all sounds normal for APR 1+ file from what I have seen. Yes, 2300mb is a lot, but id rather see a log. peak doesn't interest me even a little, because on that turbo it holds for all of about 2 seconds. I have hours of both k03s and k04-15 115 logs showing nothing but negative deviations...just the nature of the beast up here unfortunately on that turbo. takes a tish longer to spin up, then shoots past request to peak, then tapers off close to, but somewhat under request through red-line at max duty cycle.
quick q: where is the range is the underboost code triggering? just out of curiosity
I ran a GIAC 1+ program unaltered with no intercooling upgrade for north of 20k miles and now it lives in another car and is still going strong 2 years later, so I am very confident in the reliability of the k03s turbo. failure rates are actually fairly small on those, even when overstressed. I'm not saying that up here the life couldn't potentially be decreased, and I am also betting there is a little cracking going on in the turbine housing (normal on k03s and k04-15), but an expected life of 10k miles seems excessively low. I honestly think after the hardware issue (assuming there is one...some APR b6 1.8t cars do throw under-boost codes up here...but they aren't harming or hindering anything) is diagnosed, the software will be fine. As much as I personally love GIAC, there are hundreds of 1.8t cars ranging from mk4 jetta to b5 passat to b5 and b6 a4 cars running APR software. B6 1.8t ME7 ECU was and still is one of APR's stronger files that has endured over the course of time....a lot longer then their original craptastic injectors for the 1+ file for sure.
not trying to start a debate or lash out by any means, just giving my .02c
nice to hear from you!
