Driving home tonight I went to pass a car and stomped the gas (kind of addictive in the S6). It accelerated hard and seemd fine but an orange light temporarily flashed (just once) on the dash cluster. It did it so fast I can't pinpoint which light it was but I think it was on the speedo side. (I was watching the road) My question is, does the EDL / ABS light flash if traction loss / wheelspin is detected or would that be the ESP light? or both? Temperature was around 33 degrees according to the in car display so I could have spun on a small ice patch. HAs anyone ever had the light just flash once?
When I got home I scanned everything (engine, trans, braking electronics). Only fault code was:
16826/P0442/001090 - EVAP Emission Control Sys: Small Leak
Possible Symptoms
• Malfunction Indicator Light (MIL) active
Possible Causes
• Evaporative Emission (EVAP) System leaking
Possible Solutions
• Check Evaporative Emission (EVAP) System Sealing
o Check Fuel Cap
I DO NOT have a CEL. I am anal about tightening the gas cap. Since I don't have a CEL this code could have been stored since before I got the car. Any specific area on the 4.2 to look at in the EVAP system?
I searched around and most people with that code find the gas cap was the problem........
