Results 1 to 6 of 6
    Established Member Two Rings stealth_10's Avatar
    Dec 05 2008
    some Golf shoes
    IN THE DRIVER SEAT
    tail light turning on by itself?
    After i've bought my a4, every other night, my tail lights tend to turn on by itself...to shut it off, i just pump the brakes and it turns off. then, a couple of nights later same thing happens and i do the same to shut it off...is this problem fixable by me or do i have to get it pro-fixed?
    2018 SQ5 Stage 2 (Nia)
    2009 A4 HPA K04 (Maya)
    Sep 13 2008
    Western Chicago Burbs
    Re: tail light turning on by itself?
    check the connections and the fuses.
    why are you pumping your brakes. you have abs
    Veteran Member Three Rings kpatz's Avatar
    Nov 08 2006
    '02 Audi A4 B6, '06 Mazda6 wgn
    NH
    Your brake light switch is faulty or needs adjusting. Or something isn't right with your brakes, causing the pedal to sink and trigger the lights.
    I think he's referring to pumping the brake pedal to get the lights to go off. Presumably the car is parked at the time.
    2002 A4 1.8T Quattro, 5 Speed, Goodwood Green (rare color!)
    Current mods: APR Stage 1+, TT225, 710N, APR Snub, JH solid short-throw shifter, JH solid linkage upgrade, Sachs clutch, Euro shift knob/boot, 4300K HID D2S, 18" VMR RS4 reps w/General Exclaim UHP, hardwired Valentine 1 w/remote display
    Veteran Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    OR if you have a 3.0 with "coming home feature" the lights remain on to guide you along your way.. What ur doing is by opening the door and unlocking the car again is turning that feature off.. No pumping brake action required. Look in your car by the headlight switch... do you have this small round knob:
    If you dont have this feature, then it is what they say.. your brake switch is dead and needs replacement.. No big-e its a 30min job..
    - 2016 VW MK7 GTI Performance Pkg. DSG/Nav/Light pkg/cloth seats.
    - SOLD 2012 Audi TT 2.0T DSG Quattro RNS-E, S-Tronic, Volcano Red, 35% Tint, HID Fogs
    - SOLD 2005 BMW E46 330ci 6mt, K&N intake, //M3 strut brace, SS brake lines, ccfl angel eyes, Stoptech brakes... and more!
    - SOLD 2004 Audi A4 3.0LSport, Automatic CVT, RS4 Sway, Drilled and Slotted Brakes, SS brake lines, RNS-E, E-Codes, Hi-Flo Resonator, Tint 35%, S4 spoiler, HID Fogs, APR Snuby
    Dec 05 2008
    some Golf shoes
    IN THE DRIVER SEAT
    i do have the "coming home feature"...thanks guys...
    Feb 27 2008
    Quote Originally Posted by stealth_10 View Post
    Thats your problem.. if you turn it off the tail lights wont be on anymore when you open your door to get out and walk away.. BTW they turn off automatically so dont worry...
    ALSO you should notice that your Fogs are on too!
