Results 1 to 9 of 9
    Veteran Member Three Rings bronz's Avatar
    Sep 21 2006
    Lyons, IL
    quick help please
    started a car and all of a sudden blinking check engine light and rough idle. hookd up innova check engine light scanner and said cylinder 1 misfire. check engine keeps blinking. so im guessing blown coil? which cylinder is 1? the closest to the front? and is there a way to test ignition coil with a multimeter or something?
    2014 Audi S4 DSG
    Dec 05 2007
    Re: quick help please
    Cylinder 1 is closest to the front. I would say blown coil.
    Easiest way to check for blown coil is to change the ignition coil from cylinder 1 and 2. Scan again and if it moves to cylinder 2 it is the ignition coil. Replace as necessary.
    *sometimes, the scanner will still say the misfire is in the same cylinder. If that happens, clear codes, turn off car, start back up, rev till CEL starts to blink again (or if it comes on immedialtely), scan again (sometimes it happens again or it will say misfires in both cylinder 1 and 2. but this is not the case and it is def the ignition coil. upon another scan, it will def say it is the other cylinder), and replace as necessary.
    Senior Member Three Rings eurotecknik's Avatar
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Hey, been there myself. I am local to you, and I have two brand new and 2 stock in working condition. I can help you if you want to try them before you thow money on coils and find out that's not it. (most likely it is) and (I wish I was able to do that when I had that problem )
    01 A4 1.8T Quattro Manual - SOLD
    90 Audi 90 Quattro Manual - SOLD
    03 A4 1.8T Quattro Manual - SOLD
    B5 S4 Daily Driver - SOLD
    Current:
    06 A4 Quattro Auto
    Sep 21 2006
    Lyons, IL
    sweet, how far are you from orland park? i'd really apreciate it
    2014 Audi S4 DSG
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Irving & Harlem by norridge
    Current:
    06 A4 Quattro Auto
    Sep 21 2006
    Lyons, IL
    could you sell me one tonight?
    check your pm
    2014 Audi S4 DSG
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    You got it. I can meet you at Harlem & Irving at Just Tires parking lot. $30 and it is yours. I got it from ecstuning.com
    Current:
    06 A4 Quattro Auto
    Sep 21 2006
    Lyons, IL
    can i get your phone number so i can call you when im close by. it would be in about 45min-1hr. thanks
    2014 Audi S4 DSG
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Check you PM
    Current:
    06 A4 Quattro Auto
