Results 1 to 4 of 4
    Registered Member Two Rings Rokit5's Avatar
    Oct 18 2008
    Virginia
    low boost problem?
    I just installed a vdo boost gauge last week and its showing that im only boosting aroung 5-6 psi. another thing is that my turbo seems a little louder than my friends who has a 1.8t gti. could this mean theres a leak or do i just need to replace a sensor or somthing?
    98 a4 1.8t pearl 120,000 miles
    Dec 05 2007
    Re: low boost problem?
    If you have a pre-facelift (AEB), I think your peak will be 7 psi. So, 5-6 is rather normal and at the same time diassapointing. My car goes to 11psi peak stock. This is a reason many call the chip/flashed ECU best bang for the buck as it can easily raise your boost to 17+psi. I would still perform a boost leak test anyways (good to know if you have any leaks) and try and get the full potential out of the stock turbo as you can. And also may want to consider upgrading your ECU (AZ classifieds has used ECUs that are already chipped all the time).
    Oct 18 2008
    Virginia
    thanks man, that is pretty sad that this is normal for my car. i will definitely look into getting an apr or giac chip now.
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    Another option for chipping is SpeedTuning, I've heard only good things from them, and they only cost $200.
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
