"The moment of inertia of an object about a given axis describes how difficult it is to change its angular motion about that axis. For example, consider two discs (A and B) of the same mass. Disc A has a larger radius than disc B. Assuming that there is uniform thickness and mass distribution, it requires more effort to accelerate disc A (change its angular velocity) because its mass is distributed further from its axis of rotation: mass that is further out from that axis must, for a given angular velocity, move more quickly than mass closer in. In this case, disc A has a larger moment of inertia than disc B."
Now that i have your attention. In your own words based on experiences or you ability to perform more difficult scientific equations than I...please elaborate on what will happen if i go from a size 18x8 wheel weighing, lets say 26 lbs to a 19x8 wheel weighing, lets say 21 lbs. Both weights are sans tires.
Will the extra inch in diameter counterbalance/counteract the reduction in weight? i.e. will my car be quicker or slower with the larger rims? Steering more responsive or less? More nimble or sluggish?
Thank you in advance.
