Results 1 to 3 of 3
    Jan 13 2009
    Bad O2 sensor? which one is
    Hi I have a '02 A4 3.0 and getting this from Vagcom
    1 Fault Found:
    16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
    P0421 - 001 - Upper Limit Exceeded - Intermittent
    Does anyone knows if this its a bad O2 and which one is?
    Thanks
    Jan 13 2009
    Re: Bad O2 sensor? which one is
    up
    Jun 08 2008
    Calgary AB Canada
    not sure what side bank 1 is, call your dealer.
    my friend had his go and the code said B1S1, so it told you that it was the sensor before the cat, your code doesnt really tell you much...
