    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    size of hose that the suction jet pump connects to?
    from there to the intake manifold? Just has a part number on it.
    GO KNIGHTS!
    Active Member One Ring mikefaudi's Avatar
    Dec 11 2008
    '04 A4 1.8T
    Lone Tree, CO
    Re: size of hose that the suction jet pump connects to?
    Not quite sure but if you take it to pretty much any auto parts store they can just match it for you.
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    not sure on the size but, just curious, did the purge valve that connects to the intake manifold through that hose bust? same happened to me and i ended up having to go to the dealer and it was quick in, quick out. classic audi in maitland, since you're around orlando
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
    Feb 21 2008
    Orlando, FL
    Well I didn't want to have to take the hose off before I swap it out. I do use Classic Audi but I wanna replace all the hoses that are that size while I'm replacing the purge valve that's connected to that hose.
    GO KNIGHTS!
    Feb 21 2008
    Orlando, FL
    FWIW, the hose ID is 1/2"
    GO KNIGHTS!
