Results 1 to 16 of 16
    Senior Member Two Rings xmoox's Avatar
    Aug 11 2008
    2000 audi s4
    Portland OR
    so... only 15lbs of boost
    Okay so I'll try to be as descriptive as possible. It all started when my car started to shake on the highway. I was getting a misfire in cylinder 5. Then I went to a shop and they moved my coil packs around and the misfires stopped. so i drove it home and the car pulled 19lbs of boost for 2 days then the shuddering started to happen again. Went back to the shop and they replaced the coil pack it was in the same cylinder. Car was fine for 2 days pulled 19lbs of boost then it shuddered again. After that i was like hmm. So i replaced the spark plugs with ngk iridium's. Car pulls at 15lbs and and 14lbs. I went to the shop got the codes cleared still pulls 15lbs. (mabie the ecu is in limp mode)
    So Im wondering if my ecu is still in limp mode its requested boost is 19lbs of boost. Cause when i went there and the loged the car it was pulling 19lbs on the computer and my boost gauge. I had the check engine light turned off.
    Or
    are my coil packs going bad and its just runs now because the iridium's might be easier for my coil packs to spark.
    or
    Did my n75 valve somehow go bad?
    I don't want to replace the coil packs that 300 bucks
    Veteran Member Four Rings jstdoit1112's Avatar
    Aug 13 2007
    2006 MRKIV GTI& 2000 AUDI S4
    ORLANDO, FLORIDA
    Re: so... only 15lbs of boost
    have you replaced both DVs ?
    Dont ban me bro! LOL
    Jan 29 2007
    08 S4 00 S4
    MD
    What codes did they clear
    08 S4- Stock SOLD
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    what codes and what software are you running? 19lbs on a stg 1,2,3 ect?
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Aug 11 2008
    2000 audi s4
    Portland OR
    im running and epl tune stage 2+ (mabie running 15lbs is a good thing) forge 007 not quite sure on the codes though. told them to clear codes and now my check engine light is off.
    Jan 29 2007
    08 S4 00 S4
    MD
    If your CEL was on, it's not just misfires. Without knowing those codes, it's just guess work. Is it on your invoice maybe?
    08 S4- Stock SOLD
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    cool, I as well run EPL software good stuff. the killer is you need to know the codes to get remote. Dos eteh car run good know or just weak? you may have a boost leak starting to act up.
    Aug 11 2008
    2000 audi s4
    Portland OR
    my car runs great. I was in a hury when i left the shop so they just cleared the codes and stuff maybe they didn't clear them the right way and its still in limp mode. when i first when there when they logged it and cleared my first codes of my misfires and switched my coil packs my car hit 19lbs of boost. Ill have to see if theirs a person here in Corvallis who can vag-com my car or just drive back to Portland. And my codes the shop told me misfires in a cylinder and my throttle had trouble resetting but the second time it rest itself. My cel was flashing also and that caused the cel to come on. Its been 2 days now and no cel
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by xmoox View Post
    Flashing CEL is multiple misfires. I've never seen a steady CEL with just misfire codes. Yeah, see if you can't recreate the issue with someone with a VAG-COM.
    08 S4- Stock SOLD
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    first off learn how to spell maybe
    it sounds like you have a bad coil pak. and fyi limp mode is 0 boost. not 15, not 10 psi. and im also not sure why you just replaced the plugs.. did they really need to be replaced? you just threw another question into the equation; were the plugs you installed gapped properly?
    Aug 11 2008
    2000 audi s4
    Portland OR
    The ngk iridium's were pre gaped to .26. My car would shake violently with the old plugs which were the ngk7re they had 7k miles on them so they were due for a change. After i changed the plugs the car instantly went to 15lbs of boost with the CEL on. Ill see if i can get the codes from the invoice. Currently i have no misfires so would that still mean i have a bad coil pack. Also another thing Ive been wondering about is if its the ICM's.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    The ngk iridium's were pre gaped to .26. My car would shake violently with the old plugs which were the ngk7re. After i changed the plugs the car instantly went to 15lbs of boost with the CEL on.
    .26 is probably too small of gap. increase to .28-.30 im gapped to .25 and i misfire until my engine warms up but im stage 3 with a 8 (colder) heat range plug
    Aug 11 2008
    2000 audi s4
    Portland OR
    Quote Originally Posted by ThirdStrike View Post
    should i gap the iridium's. I was told not too that they would break.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    yes. regap them to .28
    you have a 7 heat range plug. hotter plug more gap. colder plug less gap.
    also be sure ALL your plugs are gapped exactly to .28 mm
    i still think you have a bad coil pak. dont go replacing all of them. just do the one thats bad
    lol who told you it would break the plug to change the gap? you may not want to listen to that person anymore
    Aug 11 2008
    2000 audi s4
    Portland OR
    k ill try to find a shop here in Corvallis if i can't ill drive down to Portland and go to matrix. And thanks for all your quick responses.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    1. get the codes from your CEL
    2. confirm your coils are all good
    3. make sure you dont have a leak
    4. log and see if spec boost = actual boost (unless you really trust your gauge)
    5. regap plugs
