Results 1 to 40 of 42
    Senior Member Two Rings TN2004S4's Avatar
    Jun 18 2008
    B6S4, 07ODYSSEY(KIDS)
    Fairfax, VA
    Help....wheels Problem?????
    [I BOUGHT A SET I FORGED AERO FROM A DUDE FROM SOUTH FLORIDA HIS SCREEN NAME IS ADDICTED2SPEED. WAS ON THE VERGE OF KILLING THIS DUDE, BUT MY BETTER SENSES TOLD ME NOT TOO. IN ANY CASE I NEED THE COMMUNITIES HELP AGAIN. I FIXED EVERYTHING THAT WAS WRONG WITH THE WHEEL. MY MECHANIC MOUNT THE WHEELS ON MY CAR YESTERDAY AND HE TOLD ME THAT SPINDLE OF MY CAR IS TOO SMALL FOR THE HOLE ON THE WHEELS. HE TOLD ME THAT I NEED A SPACER . I'VE NEVER HEARD THIS BEFORE. I LIVE IN THE WASHINGTON METROPOLITAN AREA. CAN SOMEONE PLEASE LET ME KNOW WHAT SIZE AND WHERE TO GO INORDER TO BUY THIS THING IF IT EXIST. I HAVE A 2004 S4. THE WHEEL SIZE IS 19" IFORGED AERO. . HAVEN'T DRIVEN MY CAR IN THREE MONTHS. STUCK IN MOMAS CAR FOR NOW 2006 HONDA ODYSSEY.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: Help....wheels Problem?????
    I can't even begin to comment on your post, even though you want help you could at least help us help you. You didn't provide measurements for the wheels.
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Turn the caps off and tell us what the offset is of your wheels.
    We can recommend a spacer size that will be fitting to your application.
    Dec 28 2005
    NY/NJ
    more info would be helpful.. size of wheels? 19 by what? 8.5? offset? bolt pattern?
    what car were these wheels originally mounted on?
    Current: 2024 SQ7, 2021 RS5
    Jun 18 2008
    Fairfax, VA
    Quote Originally Posted by nsmith12 View Post
    LOL... SAW THAT COMING FROM A MILE AWAY. I'M NOT MECHANICALLY INCLINE IN THE WHEELS AREAS. JUST DID NOT KNOW THE PROPER TERMINOLOGY. I JUST CALLED MY MECHANIC AND ASK HIM WHAT THE OFFSET OF THE WHEELS ARE. HE WILL TAKE THE MEASUREMENT FOR ME
    AND I WILL REPOST. THIS IS GOOD NEWS THAN. SO THEY DO MAKE A SPACER FOR STUFF LIKE THIS. AND WHO SELLS THEM?
    Senior Member Four Rings ...Mark...'s Avatar
    Oct 03 2008
    Murdered out 04 S4..
    Atlanta BITCHES!!!
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by ...Mark... View Post
    Amen
    Just look at the wheel for the measurements, width and offset are what we would need to help you.
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Funny shit.
    Jun 18 2008
    Fairfax, VA
    lmao...the wheels is 19 by 8.5. he is taking the wheels off now to get me the off set.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    ok, that's what you need
    Jun 18 2008
    Fairfax, VA
    [QUOTE=nsmith12;3247577]ok, that's what you need[/QUOTE
    thanks... Hope you guys beat those Ravens bro. I live in Fairfax, but i work in the Baltimore areas.... Baltimore fans. ENOUGH SAID.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Alright I have to give you some credit back, and yes Ravens fans are horrible
    Jun 18 2008
    Fairfax, VA
    hahahahaha. All my damn employees are Ravens fans. I have to deal with them everyday.
    Jun 18 2008
    Fairfax, VA
    Just in case. If the guy come back and told me that he doesn't know what the offset of the wheel is. for precautionary reason to save time, I can pick up one of the wheels and take to an NTB store. Will they be able to tell me what the offset to the wheels are. Or is it printed on wheel itself somewhere?
    Oct 03 2008
    Atlanta BITCHES!!!
    Quote Originally Posted by TN2004S4 View Post
    I know my RS4 reps came w/ the offset and size stamped on the inside of the rim spokes. One spoke had 5x112 another had 18X8. Did you look inside the rim?
    Jun 18 2008
    Fairfax, VA
    i don't have the wheels with me right now, but i will have it tonight. I'm pretty sure that the mechanic can figure it out. I'll check for those numbers anyhow. Thanks so much.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    No that wouldn't help, you need to check the wheel. Its going to be between 30 and 45 in case he doesn't know what to look for.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I just looked up the sellers listing and if that is the correctly set, the wheels have a 32et offset, while those can fit you might need a small 3-5mm spacer.
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Sounds like you just need a hub ring. Or get a spacer that is hub/wheel centric.
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    ET32 is perfectly flush. If he puts a spacer he is going to poke and rub if lowered.
    Im surprised the seller didnt supply the hub ring.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Yeah my bad, I mean't he doesn't need it so he's got the wrong problem. It must be hub rings
    Dec 05 2006
    So. Cal.
    That's not correct. A +32 offset is the absolute most aggressive offset that one can put on the S4 B6 and B7 body. So a +32 is the lowest that you can go with a +38 on an 8.5" width being the perfect size.
    No spacer should be used.
    But your problem isn't spacers, its hub rings and you can get those from the manufacturer for a few bucks. It's ana easy fix and the seller is not really responsible to supply these when he sells his wheels as he doesn't know what car they will be going on.
    Oct 03 2008
    Atlanta BITCHES!!!
    That’s what I was thinking..
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I know, that's why I corrected myself above. I was confused for a moment.
    Senior Member Three Rings Rodknock's Avatar
    Jun 25 2008
    The Dirty T, WA
    Sound to me like you need a hub centric ring.
    Jun 18 2008
    Fairfax, VA
    yep just stop by my shop. it is the hub ring that i need. i called ATB which is a tire distributor that we have an account with, and they don't have it in that size. the hub on the car is 1.25" and the one on the wheels is 2 13/16". The person at ATB suggest that I go to a custome wheel shop. If anyone knows where I can get my hands on this within the washington metropolitan area please let me know. thank you for all your help.
    Jun 18 2008
    Fairfax, VA
    This is not why I was mad at him. On his add he had stated that the wheels was not bent or scratch. when I recieved the wheels, three of them were bent and they were all scratched up. that was the reason why i was so pissed. it has nothing to do with the fitment. I swallowed my lost for not doing the research about the seller on my end..... In any case, I appreciate all of your guys help so far and sorry for the confusion.
    Dec 28 2005
    NY/NJ
    Call Iforged for the correct hub ring size and then order metal rings from this site..
    http://www.1010tires.com/hubrings.as...FQxKGgodF3-0nA
    Jun 18 2008
    Fairfax, VA
    Definitely missed this quote. Does anybody knows the phone number to Iforged or the number to any of their distributors that is local within the Washington Metropolitan areas? I wonder if Tirerack carries these hub ring.
    Jun 18 2008
    Fairfax, VA
    Quote Originally Posted by Kyokio View Post
    Thank you so much. It never fails. Everytime I need help on my car Audizine always come thru. Thank you again peeps. Will keep you guys posted on when everything is done.
    Jun 18 2008
    Fairfax, VA
    just called iforged and they carry the hub ring at the same price as 1010tires. The rings should be at my front door in 4-5days from today.
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Since you already own the wheels then check out wheelsamerica.com They can redo your wheels for $130 a pop. I had my S4 Avus' redone and they looked like they were new. You can see pics of them on my Avant in my photo gallery.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Jun 18 2008
    Fairfax, VA
    Quote Originally Posted by AudiOso View Post
    I did have them redone and they do look like new now. I saw the ad that addicted2speed had posted on the wheels and I like it, but once I received the wheels they don't look anything like the picture that he had posted. Anyhow, thanks for your advice.
    Jun 18 2008
    Fairfax, VA
    updates..... The hub rings are mounted and the wheels are in. There is a slight vibration at about 110mph. I think I need a high speed ballance. Anyone knows any shop around the washington metropolitan area that does this. Thanks for all your help so far guys.
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    How often do you travel at 110 mph?
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Veteran Member Four Rings d.p's Avatar
    Nov 08 2006
    F80 M3
    Annapolis MD
    Quote Originally Posted by SuperAvant View Post
    L-o-fucking-L. Come on dude you don't drive 110 all day everyday?
    Veteran Member Four Rings serumk's Avatar
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    LOL
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    We do have a feedback forum. You should always check that before buying...
    Glad you got it to work out - we have a place in Michigan called Belle Tire. I bought plastic rings for $8.50, a lot less than the $15 at Discount Tire. Just in case anyone else needs any.
    FS: Audi TT 225Q Roadster
    May 30 2007
    MA
    Quote Originally Posted by d.p View Post
    Only through school zones... other than that I have this WICKED annoying vibe at 147. Still trying to source the problem.
    2014 R8 V10 - Gated
    Jun 18 2008
    Fairfax, VA
    That's funny. I don't do it that often, but i do drive 60 miles each way to work. Fairfax to Baltimore and back. I don't drive my car often, but when I do on certain strecth of the beltway coming home I will take it her up there. lol that was funny. I just want her to be smooth all the way through.
