Results 1 to 16 of 16
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    List or pics of all oil / coolant lines needed for a GTRS install?
    I've been collecting parts for a GTRS kit over the past few months and when you buy used parts a lot of the time not everything that you need is included.
    That being said, I need to figure out what I need to buy to be able to install this without making a trip to the dealer or getting stuck ordering parts online. I've never taken apart a 1.8t except to swap the TB, so Im not familiar with the turbo's physical setup.
    So assuming you were going to install a GTRS, what lines will you need? What can be reused? Any aftermarket options? Length and thread pitches?
    I suppose it would be ideal to figure out the AN fittings and hose lengths needed for a full braided line setup.
    Any input? Thanks!
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: List or pics of all oil / coolant lines needed for a GTRS install?
    I think the factory oil lines can be re-used but you need an oil restrictor on the oil feed line.
    The coolant supply line coming from the upper hard line on the intake manifold needs to be lengthened and a banjo fitting added at the turbo.
    Can not remember if the factory coolant return line gets re-used.
    That is the cheapest approach. The primo approach is just get all new S/S lines: http://www.034motorsport.com/product...roducts_id=724 That is the transverse kit. I couldn't find the longitudinal kit with a quick scan. Might want to talk to Issam for the longi kit if interested.
    -Doug
    Apr 20 2007
    Lander, Wyoming
    Thanks Doug. I was under the impression that the oil restrictor was built into the turbo right where the oil inlet line attaches...
    I may need to call ATP about this.
    The 034 kit looks nice but $330? I may just undertake designing my own kit and save the money. It's not rocket science to measure hose length and thread pitch afterall. I was hoping that someone may have put something like this together in the past and would have the info ready... if not I suppose I'll be the first to DIY.
    Jon
    go > show
    Ich liebe mein Audi
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Others have done their own kits. The parts are not cheap so the cost of doing a full oil/coolant line kit with all the fittings/gaskets adds up quickly.
    If you want to cut costs, you can just do rubber hose for the coolant lines since the B6 uses a banjo fitting at the block and a hose clamp at the coolant hard pipe. That means you really only need to do a oil drain line with the fittings and get a oil restrictor for the oil feed line.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Mike,
    Does 034 have a line kit for the longitudinal configuration?
    Jon,
    The oil restrictor threads onto the turbo oil inlet fitting. It is not part of the turbo itself.
    -Doug
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Search for my name, I made this same thread and Shawn posted a list of all parts needed even with ATP part #'s. I gave the list to a local shop and it cost me $200 for everything. They're not braided ss though.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Saint Cloud, Fl
    you can use the the stock coolant return, I used the stock line on my kit
    instagram ------------> low_enforcement
    Jul 07 2004
    socal
    Mike,
    Jon,
    Yes and I sent you an PM.
    This is the B6 line that 034 put together for me using straight fittings for the coolant lines at the turbo.
    They also made the line kit that is on Jakes dad's car, this one uses banjo bolts for the coolant lines at the turbo.
    Apr 20 2007
    Lander, Wyoming
    Thanks for all the help guys. I'll have to see if the turbo has the restrictor still in it once it is shipped to me later this week. I think I'll still try to assemble the kit myself because it'll be a learning experience and better than just paying someone to do it.
    Killerteve that post was extremely helpful! Here is the link for anyone searching in the future:
    http://www.audizine.com/forum/showth...&highlight=oil
    Jon
    go > show
    Ich liebe mein Audi
    Senior Member Two Rings Alphazuzu's Avatar
    Oct 05 2008
    Holly Springs, North Carolina
    Thought I would bring this back. So I read this and the related thread and others I found in a search and cant come to a conclusion.
    What lines are absolutley reusable if you are using a GTRS elim kit with ATP Mani.
    What lines must you get?
    WHERE TO GET THEM?
    My turbo has barbed banjo fittings already on the turbo, what lines should I use so I don't have to buy new Banjo fittings (can I even use Braided SS with barbed fittings).
    Also Everyone is saying this is 300 plus dollars when im on the ATP site and they offer fairly cheap custom lines such as
    http://www.atpturbo.com/Merchant2/me...gory_Code=GTBB
    and
    let me know if im way out of the ball park here. I would rather someone say here is exactly what you will need and yes I would like to stay cost effective aka cheap.
    Established Member Two Rings Termin8r's Avatar
    Oct 15 2009
    03 audi a4q ,08 Evo x
    Ok I have to bring this thread back!
    So i've been trying figure out if I can reuse the oil feed line on my used Gtrs since it did not come with any lines. if I can reuse it what size is the oil restrictor fitting that I need?
    Another ? I have, what size banjo fittings do I need for the coolant return and is the coolant return outlet on the same side as the k03 ? TIA
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    If you choose to replace your feed/return lines, I have some that are new I'll sell dirt cheap.
    Oct 15 2009
    ^^ sweet!!! U got pm'd
    Dec 03 2009
    1991 RX-7
    Seattle/WA/USA
    I gotta bump this thread.
    Can I use the 034 kit with a stock location manifold? I want to just replace all the coolant + oil lines with SS. But I don't want SS that goes to AN fittings or SS that goes to rubber. Too many connections + places to fail. Plus it looks sloppy IMHO.
    Is there another kit that I can but that will have all the lines I need in SS?
    ohm mani padme hum
    Apr 12 2007
    Worcester, Ma
    Last edited by dan5171; 02-23-2012 at 01:14 AM. Reason: fat fingered the link...fixed now.
    Performance Cafe is a scam. You've been warned.
    04 1.8t 6 speed- Boxter front brakes, S4 rear, NS ss, RS4 rear sway, ST coilovers, CIM , Gruven Parts UCA's, AWE DV1, Eurogear door blades, Eurocode FMIC, B5 S4 clutch and some sweet floor mats.
    Dec 03 2009
    1991 RX-7
    Seattle/WA/USA
    Quote Originally Posted by dan5171 View Post
    +rep
    ohm mani padme hum
