Results 1 to 9 of 9
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    Coil Pack/s ?? FAIL
    So I was driving home tonight and I hit second... and the car starts missing! (sounds like a damn subaru haha) But... no CEL... Im thinking cp's but i would think I would get a CEL....???
    Thoughts please
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    Re: Coil Pack/s ?? FAIL
    most likely unless failure was intermittent. i'd would buy a couple ahead of time just incase , learned the hard way. my cat was glowing red when i got home
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    i remember one guy had the same problem. it was obvious that his coilpack went bad but he didnt have any CEL.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    Quote Originally Posted by FireWire View Post
    dont drive your car with a bad coilpack!!! it's VERY bad for the turbo and the cat!
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Aug 20 2007
    97 Jeep Wrangler
    they went out 1 block from my house so i just pulled in and shut her down.. scaned for codes this morning and there were no codes.. just ordered 4 cp's!
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    u can drive... but not for a long distance
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    likely coil packs, new plugs wouldn't hurt ether.
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    Quote Originally Posted by davidlizard View Post
    already know , i didn't have a choice. it was about 25 miles tops and in any case if my cat decides to take a dump i'll drop in a testpipe/hiflow state emissions laws
    2006 600RR
    my photos
    Veteran Member Four Rings DELUX's Avatar
    May 28 2004
    04 A4 USP 1.8TQ M6 Ultrasport
    Asheville, NC
    I had a similar thing going recently, my car was misfiring over 10psi. Felt like a coilpack (I've had a lot of the bremi (OEM) coils go before) except this time it wasn't getting gradually worse like it usually does with the coilpacks. I've also been running the Beru coils for 20k miles now.
    Soooo... I vag'd the car, got a cylinder 4 misfire. I swapped all 4 plugs and that was it. I tested it by doing a few 3rd gear pulls and it holds 18psi like a champ again. That means my Beru coilpacks are still holding strong at 20k miles :)
    That also means that I got nowhere near the advertised 25k miles out of the NGK Iridium plugs I last bought (I think closer to 10k?). All I had for a full set of plugs was a new set of OEM NGK plugs and so far they're running great, although I'll most likely swap in a set of copper plugs again when I do my big timing belt service, I'm looking at the Bosch plugs which a lot of people are speaking highly of but I may just go back to the BKR7E non iridium plug and go back to swapping them every 5000 miles.
    I highly recommend the Beru Coils to EVERYONE. I got mine from 034. With these coils, I don't worry about getting stranded anymore like I used to with the OEM bremi coils.
    USP CLUB MEMBER #3 - 2004 Audi A4 1.8TQ6
