Results 1 to 35 of 35
    Veteran Member Three Rings Pworld's Avatar
    Dec 19 2008
    L.A. Palm Tree's and Beaches
    Umm...Why am i getting Flashed/Highbeamed at least twice a night???
    I have a B7 with OEM Bi-Xenons (owner for only a few weeks)
    Everytime i start up, the lights do there little dancing sequence (so amusing to me) and seem to level just right. The cut off is about eye level 20 ft away and hood level about 5 feet away.
    I got the car about 3 weeks ago and finally drove it a bit this weekend, and today. I noticed at night i at least get flashed about 2-3 times a night. WTH!!
    I keep my lights on Auto, So im wondering if theres alot of city lights where im at that, they shut off. But i doubt it.
    My old car with HID aftermarket kit in a halogen housing and 6k lights with awful beam never got the flash treatment.
    Should i get use to this with OEM HID's?
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    Re: Umm...Why am i getting Flashed/Highbeamed at least twice a night???
    There just telling you how hot the car is :P
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    i've gotten the flash crazy amount of time especially when i have my yellow fogs on too. our lights are real bright that people think we have our brights on i guess
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    Quote Originally Posted by whitevdub View Post
    lol flash them back so they know you're not on high beam
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Veteran Member Four Rings adub's Avatar
    Nov 20 2008
    spiders
    Orange County
    Bust out your piece and light them up! Hahah, i don't know man, i had that problem but i don't get flashed that much anymore. I used to flash people back if they thought my high-beams were on but now i am just too lazy.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    does your headlight(s) flicker when driving? that may be a reason. Or your beams may be pointed too high. have a friend drive by and see what he thinks.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    i would assume it has something to do with the auto level feature. Because if you ever pay attention to newer audi/bmw/mercedes vehicles with this feature you'll notice from a distance the lights look very blue/purple but every time they hit a bump they change to a white/yellow color. And i've noticed that when they do this they look like they get brighter.
    The reasoning the headlights change color the way they do is because in order to maintain your headlights at the same level when your car dips, they raise, when it bounces up they lower thus changing the angle at which the light is being projected. And the projector is the reason the light may look a different color intensity than they are. Because i'm assuming you have factory HID's which are probably 4300k like most. Which would be a fairly white color temperature. But because the projector bends the light waves in the way it does, the color changes to the human eye.
    So maybe some idiots see the change in the light color (or flickering i guess it could be called) as you flashing your brights so they do it back... Where as your old HID's were most likely one solid color no matter what so it didn't look like there was any difference. That would be my guess.
    - Justin -
    Apr 18 2008
    Jacksonville, FL
    disclaimer: i have halogens
    based on this line:
    Quote Originally Posted by Pworld View Post
    i'd say your projectors are aimed too high. if your low beam cutoff rises the futher away from the car the target gets, that's wrong. the cutoff should get lower. head to your stealership and find another b7 with hids, park next to it, and compare beam patterns on the same wall.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Dec 19 2008
    cool im gonna check it out.
    when i first got the car i had a friend drive it home behind me, and i did noticed when the car hit bumps, the lights would flicker brighter, like most HID equipped cars do on the road that used to blind me.
    I just have never been on the dishing out end. Just the receiving end. I will have the dealer check it out when i take it in to fix a stupid rear bulb fault that only comes on when my AUTO lights activate.
    Jul 04 2008
    Seattle, Washington
    yeah so it's probably the auto level feature then like i thought. Cause i've gotten flashed too and i'm even lowered quite a bit haha. My lights are standard white, but from a distance and to an onlooker they are very purple, but again i have auto level so they do that "flicker" back and forth between colors. The worst are the new BMW's like the 745Li, they are really bright when they flicker because they also have adaptive headlights so they turn right and left depending on what way you turn the wheel, and they also go up and down during acceleration and deceleration and all that stuff.
    So i guess you can have the cutoff level looked at, but it's nothing to really worry about, your beam sounds about the right height. Might be a slight bit high though.
    - Justin -
    Veteran Member Three Rings sdjeff's Avatar
    Jun 04 2008
    B7 A4 2.0t, Dino 246 GT
    RSF san diego
    The flickering of blues and purples will happen regardless of auto leveling. The color comes from the cut off that the projector makes.. so when a car hits the bump it may show the range of the colors depending on where you are looking from. Take a look at bryson's thread to see how he made a sharper cut off that produces more colors using the stock 4300k Xenon's.
    Jul 04 2008
    Seattle, Washington
    i know you can enhance or thicken the cut off color and swap out TSX/S2K/TL projectors and such. But it has to do with the angle the light is being projected still and auto leveling can play a part in that because it changes the angle from which you are viewing the light.
    - Justin -
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    Quote Originally Posted by eskimopunk View Post
    That's what I do. S4 bi-xenon's FTW
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    Does it happen on hilly roads? You may be going up while the oncoming car is going down and sees directly into your lights and assumes you have brights on.
    Or, like after I installed my xenons, I realize I had to adjust their aiming as mine was aimed a bit high. One way to test is pull up behind a car, your cutoff line should be just above their bumper or so.
    2010 BMW 335i Sapphire Black + Black leather interior + Sport + Nav + PDC. Mods - Carbon Fiber wrapped interior - Gloss Black grill - 15% tint - more coming
    2006 A4 2.0T Quartz Grey + Black leather interior + Convenience. Mods - 19" VM RS4 reps - FK Silverline coilovers - APR 93 - Navigation - S4 mirror caps - S-Line E-Codes/Bi-Xenons - XenonMatch Hoen Fogs - RS4 sport pedals - LED License plate lights - black grill - 15% tint all around & More mods coming.
    Active Member Four Rings HOFFY11's Avatar
    Aug 01 2008
    Audi A6 4.2L Quattro
    forked river, NJ
    Quote Originally Posted by QTC View Post
    lol i do the same..just with my a6..then they get the point ha
    the mods..GIAC ECU chip, GIAC TIP chip, rear lip spoiler,mirror covers, H&R coilovers, Cold air intake, fog light grills painted to match and centers black, Debadged,19" EXE rims w/ falken tires, 2 10" polk subs in custom box,vinyled window trim, dynomat, painted calipers,custom cat back exhaust, cupra r splitter, window tint.....Full Widebody-installed ..soon to come tinted tails, maybe tinted headlights..Oh SO FRRESHHH
    Established Member Two Rings Alecd90's Avatar
    Jul 23 2008
    2008 audi a4 2.0tip s line/ti
    new york
    i only get the flasheys when i run the fogs, im pretty sure thats the reason but it was driving me crazy when i first got the car.
    Revo 93//awe diverter valve//carbonio cai//awe boost gauge//9500i
    soon to come:stasis exhaust and Street sports
    Deactivated Three Rings
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    My car also has bi-xenons, I also keep them on Auto, they do the same amusing dance at startup, and I never get flashed, no matter how dark the road.
    I suspect your lights need to be adjusted properly.
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Have you check how high they are. There is a white screw at the top of the headlights that make it go up and down.
    I thinks thats how they are supposed to look.
    Please correct me if I am wrong.
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Veteran Member Four Rings 1point8teeNW's Avatar
    Nov 11 2006
    North Webster, IN
    Best way to retaliate flashers....
    ....keep a small jar of pennies in your center consol and just give one or two a toss as you pass said flasher. If your aim is on target, they'll think twice next time....
    Current - 2004 Pontiac GTO 6M *FOR SALE*
    Looking for - B6/7 S4 TIP or 6M
    Veteran Member Three Rings golfvdude's Avatar
    Mar 11 2008
    2006 Audi A4 2.0T
    Abbeville, LA
    Quote Originally Posted by 1point8teeNW View Post
    That is so cruel........
    Nov 11 2006
    North Webster, IN
    Quote Originally Posted by golfvdude View Post
    Yet....surprisingly effective...
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    crack a windshield...
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    I've only gotten flashed once with my bi-xenons and I said to myself...those aren't my brights dumbass I just have a baller lights :)
    In all seriousness though, you should go into your dealer. They should have a wall that you can line up with markings on it so they can be adjusted properly.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    "Brown Chicken Brown Cow"
    Mods = 0
    Established Member Two Rings Eternalmind's Avatar
    Dec 31 2008
    B7 A4, 337
    Indy
    Quote Originally Posted by bcramer View Post
    true story. you (the OP) are not aimed properly. at 25-30 feet, the cutoff should in essense be the same height as the center of the projector when measured from the ground. the beams should NOT get higher on the wall the further you get from it.
    the fact that your beams are at *eye level* at 50 ft. is why people (who have your lights in their eyes) are flashing you
    Dec 31 2008
    B7 A4, 337
    Indy
    that's a pretty idiotic response if you're the one at fault
    Mar 03 2008
    Washington
    If you ever did I would be sure you would never be able to throw a penny again. Unless you can throw with your mouth...
    That is most ridiculous thing I've ever heard as a way to "get back" at people who flash their brights at you.
    It's not like they're being mean by doing so.
    Anyways, your obvious lack of immaturity is uncool.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    Mods = 0
    Nov 11 2006
    North Webster, IN
    Wow....
    ....anyone who would really do this please raise your E-hand.
    No one?
    Ok.
    Even I wouldn't do this. I was mearly stating a way to retaliate.
    Edit: "Lack" of "immaturity"???
    Soo I DO NOT have immaturity which would make me "mature" and being mature is uncool? I'm not harassing you about your sentence there, I just wanted to you be aware of your error. Unless of course I'm reading that wrong. If so, please enlighten me.
    Dec 19 2008
    checked it again thoroughly my beams are at proper height. when i pull behind a car its on there bumper. from 15-20 feet away its about hood level. not eye level.
    and the other night i got flashed and i noticed it was only after i i came around a slight bend in the road, and the last time i was flashed was right after i made a right turn. Somebody stated above that it is the angle of the projector when its "adjusting or adapting" around a corner. That what i think it is. I observed a few other cars like the new 3 series with HID and they seem to do the same thing to me. its super bright when they come around the corner.
    so im not worried.
    Mar 03 2008
    Washington
    Wow....
    No one?
    Ok.
    Sam Adams Winter Collection > Me
    The point is that there is no reason to "retaliate" to someone flashing their high beams at you.
    If you want to be nitpick my post... it's merely not "mearly"
    p.s. My hand is raised. I would make sure you never threw another penny again.
    p.p.s. You cannot have immaturity. You can be immature, but you cannot posses it. Sorry to disappoint you.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    Mods = 0
    Nov 11 2006
    North Webster, IN
    I was meaning for people to raise their E-hand if they would ever actually toss a penny out of their window. lol
    Also, it's actually "possess", but i'm not gonna hate on you for inadvertently missing an S.
    Registered Member Two Rings Down3yDJdud3's Avatar
    Nov 25 2008
    2006 A4 Dolphin Grey Sline/Con
    Downey
    Funny this thread should pop up. I got flipped off on Thursday night on some side street at a little light. I was in the pocket making a left and while waiting for the light to change to green the car directly across from who would be crossing the intersection blasts his high beams several times. So I was like dumb ass these are factory HID's, so I did the logical thing and flipped my high beams. Sure enough as he passes me, he had his hand framed in the window flipping me the bird. Part of me wants to think that he was just pissed because his 98 benz roller skate SUV didn't have Xenons, but I have gotten the high beams several times in the last week. I don't think my alignment is wrong, I just had the stealership replace the passenger side housing because the light was way out of line and the adjustment was defective.
    Makes me think I should switch to 6k bulbs. I will post a pic of my beam pattern!
    Dec 31 2008
    B7 A4, 337
    Indy
    don't assume you're aimed properly just because the dealer does it...they've done mine wrong 4 times in a row now.
    Senior Member Three Rings nSun's Avatar
    Mar 19 2007
    2008 TT 3.2q, 2010 Camaro 2SS
    vancouver
    our headlights aim too high coming outta the factory. i had them adjusted just because i got highbeamed by oncoming traffic everyday
    EVO9MR
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    I get flashed a lot too. I usually flash my bright very quickly to let them know, and they continue to flash theirs anyway dumbasses
    I have ZiZa yellow fogs, and like 50% of cars flash me when I have those on too.
    The best part is on the highway when my headlights are too bright for someone I'm about to pass, and they get really pissed and turn their brights on after I pass them. They're all angry trying to piss me off, but all of my mirrors are auto dimming so I just start laughing when my headliner gets brighter because I know they're trying to blind me suckers
    Ignorance is bliss.
    Apr 18 2008
    Jacksonville, FL
    heh, i get flashed a lot too...working for a bar band, you should see the ladies *snort* oh yeah
    ...wait...headlights...uh nevermind
    SOLD 10/2011
