Originally Posted by
Spirare
I did the timing belt, valve cover gaskets (you must if you do the job correctly), water pump (cast impeller not plastic), all rollers, valave cover gaskets and tensioner on my 3.0L this past weekend.
I got the kit at Blauparts.com and it also came with 6 liters of Pentosin G-12. $453
I also rented the specialty tool kit form them which is... worth it for the cam lockers.
It took me about 7 hours.
I would do it for $250 labor if you supplied the parts... and airfare ;)
got my AVK-3.0 done 2 monthes ago.
bought exact same TB kit as yours from Blauparts.com.
(bonus two free valve cover gasket + free Accessory belt)
a VW technican did it for me for $250.
by the way, the normal price for AVK-3.0 TB job is around $1300-1700 in Audi Dealerships.
There has been a thread about AVK-3.0's TB cost at dealership before.
someone said $3000 and scared people away. Unfortunately, he did NOT provide any proof nor telling which audi dealership quoted for $3000. However, a lot of people actually did it and called in for quote ended up being around $1500.
personally I called in 3 different audi dealerships to confirm the price of TB on AVK-3.0 and all of them quoted from $1300-1500. One of the audi dealership is No.1 Canada West Coast's Audi dealership.
- OEM Audi TB parts from dealership (including waterpump, all 3 idlers/tensioners/ coolant/ belt etc) are less than $700.
- Bentley Manual sugguest labour of 7 hours. ($120x7=$840)
(Audi technicans usually finish this within 5 hours.)
This $1500 range is how the AVK-3.0's TB should fall in normally.
Unless you have extra job to be done besides regular TB such as the "other miscellaneous things." as you mentioned.
for Thermostat, it is NOT necessarily required to be replaced at TB.
it usually lasts two TB interval period and is different job than TB, and audi technican told me they only replace those when it fails.
if you want to get this job done cheaper, find some reputable local euro shop. Usually craigslist has people specialzing TB on VW/Audi for a lot cheaper labour than Stealership. Most of them are half price of the stealership. $60 vs $120 hourly rate.
anwayz, good luck man.
