Results 1 to 21 of 21
    Nov 23 2006
    "I'LL SHOW YE GARAGE!"
    Soooouuullllll Cal!
    In a bind right now. Need help. Asap
    Guys Im coming home from work and the the CEL is flash on and off. I hooked up the OBD II reader and its giving me this codes.
    PO141 02 sensor heater circuit Malf. Bank 1 sensor
    PO302 Cylinder 2 misfire detected.
    Anybody now what's the problem?
    Right now in the gas station.
    I'm using phone Internet
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: In a bind right now. Need help. Asap
    cylinder 2 coilpack is probably bad
    -Sami-
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Probably just a coil pack. If the CEL was blinking, that means significant misfires. Regardless, I wouldn't drive any further. Do a few tests, by removing coil packs one at a time, while the engine is running, to find out if that's your problem.
    Nov 23 2006
    Soooouuullllll Cal!
    Crap. Is it safe to drive home? I'm not near my house?
    Jun 21 2008
    I wouldn't drive if I were you. You have too much to risk.
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    How far are you from home? Where are you at and where do you live?
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Feb 19 2007
    Charleston, SC
    you will damage the catalytic converter if you run on a misfiring cylinder because raw fuel will dump straight into the cat.
    What you COULD do is find out which is the bad coiplack (#2) and just unplug its corresponding injector. I have done that before.
    just dont hit boost. How far do you have to drive? 5,10,20 or like 50 miles?
    edit** if you have a test pipe (no cats) than just cruise
    -Sami-
    Nov 23 2006
    Soooouuullllll Cal!
    fubar.
    Okay so which is cylinder 2?
    Established Member Two Rings JD3's Avatar
    Dec 31 2008
    E92 M3
    Columbus OH
    I wouldn't suggest driving, esp if it's blinking, you'll get gas in your cats. This happened to my s4 and I would suggest just replacing all the coils b/c if one or two go bad, the others will too. Not sure how many your ride has, but it isn't a big deal to just replace them all.
    Jun 21 2008
    Pull the coilpacks like I said earlier. That's how you find out for sure. Whichever one doesn't have any impact on the misfiring motor is the bad one.
    Cylinder 2, from the one closest to you, should be the second one out.
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by pandaudi View Post
    fubar.
    In this order if you are watching over the engine bay with the hood open:
    BATTERY
    4
    3
    2
    1
    RADIATOR
    -Sami-
    Jun 29 2008
    Do you have an extra coilpack?
    -Damon-
    Nov 23 2006
    Soooouuullllll Cal!
    No CP extra, screw it I'll take my chances.
    Senior Member Three Rings AMESSA4_NJ's Avatar
    Jan 12 2009
    03 A4 B6 1.8TQ , dirtbike & a bunch of rims
    exit 91 , NJ
    drive er' home. replace all 4 with hitachi "E" coilpacks, dont waste your time with the OEM ones. there non german made junk.
    "life is nothing but fast cars & cashflow....at least for me"
    too many parts too list and too many parts on my mind to buy..
    Jun 08 2008
    Calgary AB Canada
    unplug the injector like said earlier
    Dec 06 2007
    u guys are scaring the guy u can drive as long as u don't hit boost, i did for 20 miles a couple times no worries i even went WOT a couple times during this period, just be easy on it and u'll be fine, 1 CP wont destroy ur engine. He doesn't even have a cat so no worries.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Three Rings Kerschera4's Avatar
    Jun 21 2007
    DC
    Quote Originally Posted by AMESSA4_NJ View Post
    hitachi is far from german
    Nov 23 2006
    Soooouuullllll Cal!
    fuck yeah, made it. I wanna give a big thanks for the help.
    Veteran Member Four Rings Raus's Avatar
    Aug 18 2005
    B6 1.8TQM, Mk2 GTI
    OEM Bremi is German made. You hear "Hitachi" and think German?
    Ich bin der Musikant mit Taschenrechner in der Hand
    Nov 23 2006
    Soooouuullllll Cal!
    Re:I made it, problem will be solved tomorrow. (In a bind right now. Need help. Asap)
    Thanks to the people who posted their help and advices. You guys are awesome.
    Senior Member Three Rings Sp3C14L 3D's Avatar
    Aug 17 2008
    2005 A4 1.8T Ultrasport
    I had a cylinder 3 misfire, same flashing CEL and it was just a coil!
    USPCLUB MEMBER#724
