Results 1 to 4 of 4
    Established Member Two Rings cmagalis's Avatar
    Aug 01 2008
    2000 B5 S4 & 1997 B5 2.8Q A4
    Lakeville Mn
    General Vag Com Question
    I was just wondering if someone could take a minute and get me up to speed with Vag Com. I've never done a scan with anything other than a few free times at auto stores.
    My main question is where to purchase the right software. I know that you can buy the obd2 to usb cables on ebay for $10. What I would like to do is a throttle body adaption on my 97 2.8Q.
    Any suggestions would be greatly appreciated! Thanks
    - CM
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    Re: General Vag Com Question
    Audi A6 2.7T : 6MT : 88K Miles : GIAC Chip : 2.5" Catback : Hotchkis F+R Sways : AWE DTS
    Senior Member Three Rings TverRus69's Avatar
    Sep 02 2008
    98.5 2.8 A4 QM
    NYC, Penn State, Tver Russia
    yea youre going to have to buy the real version from ross tech for 100 bucks to do a TBA. I had to do it, and the free software they got doesn't let you do it. Good luck. However im not sure that the 800 version of the software works with the ebay cables.
    Dec 05 2007
    I don't know about the 2.8, but I can do the throttle body adapt without VAG com on my 1.8t. I actually only found out maybe a month ago it can be done with VAG com. But for the 1.8t, simply remove the negative cable from the battery for 15-20 min (for good measure), place negative cable back on, place key in starting position without cranking for 15 min (again, for good measure).
    As for Vag Com, it would be suggested to get the actual Ross-Tech cable from the website. The registration key is on the USB cable (as far as how I think it goes) and you simply download the software from Ross-Tech and go to work. The Ross-Tech cable vs the Ebay cable (you will need to download software and you can use the software without purchasing the registration key, but you will not be permitted certain functions such as logging) is that w/the Ross-Tech cable I read threads you will be able to do more capabilities than with the ebay cable/registration key. Plus it can work with a wider variety of vehicles.
    As for myself, I have the ebay cable w/registration key. But I bought a laptop from an Audizine member with it already. This route can always be taken, but I would suggest to get the actual Ross-Tech key vs the Ebay cable/registration key. But if you do decide to go the ebay route, you would go to Ross-Tech.com, download the newest version (you can use it with the ebay cable without purchasing license key, but you will be denied certain functions), then purchase the registration key for $100 (I can not recall price of the Ross-Tech cable. I think around $200 or so).
    Edit: Look what I found. http://www.audizine.com/classifieds/...p?product=7491
