Results 1 to 4 of 4
    Established Member Two Rings _a6_'s Avatar
    Jul 21 2007
    00' Audi A6 2.8
    St. Paul/vermont
    having some problems
    ok to start off i have a 2000 a6 2.8 and a couple of days ago i noticed that my left rear shock was way down and pretty close to the tire but as i drove a little it lifted back to a normal height so figured it was ok. i was wrong, today i started my drive from mn to vt and along the i started to notice that the car would shake when i took off from the toll booths and then i realized that it only happened in 1st and 2nd gear at about 1/2 throttle, after that it was fine, so i dont know if its the shocks that are bad cause im coming up on 100k or that the car is pretty heavily loaded. any help would be greatly appreciated
    Gone: 2000 Audi A6 2.8 quattro
    Current: 2003 GMC Yukon XL
    C5 Union
    Jul 21 2007
    00' Audi A6 2.8
    St. Paul/vermont
    Re: having some problems
    well i took it to the local dealership and they said its my cats shaking cause they are "clogged" has anyone else ever had this problem and if so what was the fix. i know about just replacing them but want to know if there are any other ways to fix.
    C5 Union
    Veteran Member Three Rings V8weight's Avatar
    Nov 16 2008
    Hudson, WI
    There is no real way to fix a clogged catalyst other than replacement. technically they could be removed and drained, but not a real good fix. The worst part is, they are probably clogged because of an underlying problem. Usually caused by a misfire, then unburnt fuel causes the cats to overheat,
    Jul 21 2007
    00' Audi A6 2.8
    St. Paul/vermont
    Quote Originally Posted by V8weight View Post
    yea thats what i thought but my cats werent warming up was the problem.
    thank you for the help
    C5 Union
