Results 1 to 28 of 28
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    Update on Misfire
    So i got another cable and scanned the car, multiple misfires on cylinder 3 and 4. Erased the codes, scanned again, cylinder 4 misfire, erased codes,swapped coils, scanned again, cylinder 4 yet again...
    So my question is, what else could it be, im thinkin maybe the plugs which i am going to replace 2moro.
    Any thoughts
    thanks
    Miles
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Registered Member Two Rings
    Feb 07 2008
    04 A4 1.8t 6spd
    stratford ct
    Re: Misfiring problems, and its not the coils.
    get some new plugs and change valve cover gasket .. it solved problem in my car .. good luck
    Veteran Member Three Rings B5 SLPR's Avatar
    Dec 04 2007
    B7 S4 Avant
    So Cal/La Jolla
    try plugs
    "I like to party"
    VMR, Great Wheels, Great Company http://www.velocitymotoring.com/
    Feb 25 2008
    Cape May, NJ
    valve cover gasket was done about 3,000 miles ago....Gonna try the plugs tomorrow...
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Are these like constant misfires or intermittent?
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    If you know it's not the coils, then I would definitely go with plugs.
    Don't forget, when one coil goes bad, and you replace only the one that went bad, chances are that more of them will go bad right away. Hope that made sense, and if not, just change all 4 every time 1 goes out.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    MAF
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    same crap happening to me
    Feb 25 2008
    Cape May, NJ
    i replaced all 4 coils with the R's..., and its a constant misfire at idle as well as giving it gas..
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Veteran Member Four Rings Raus's Avatar
    Aug 18 2005
    B6 1.8TQM, Mk2 GTI
    Pull the sparkplug and see what it looks like
    Ich bin der Musikant mit Taschenrechner in der Hand
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    I didnt have the valve cover breather on all the way and mine missfired like a mofo. check for vacuum leaks.
    03' 1.8T Tiptronic
    Baileys DV, 15% tints
    Ziza yellow Fogs
    Blacked out grills/trim, De Badged
    Apikol snub mount, clear corner mod
    A6 engine mounts
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    How does your car idle?
    If you have changed your plugs, then it could be your MAF or primary wideband. Have you also changed your ECT sensor to a green unit? (ECT = Engine Coolant Temp, located behind the head). Either of these gone bad will cause this.
    Log block 003 to get the g/s readings at idle. Then look at your short-term and long-term fuel trims (blocks 032-034) to see if the ECU is pulling or adding fuel (lean or rich missfire).
    Dec 08 2007
    Easton,PA
    worst case scenario you have a bent or cracked valve thats what happened to me.
    2002 A4 1.8t 5 speed maunal-revo stage 2
    Feb 25 2008
    Cape May, NJ
    well i replaced the plugs, and it still is misfiring on 4...i pulled the plugs, all of em except 4 smelled like gas, 4 was very white and didnt smell...
    Im still pullin -20 vac...
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Nobody mentioned vacuum leak yet???
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Feb 25 2008
    Cape May, NJ
    yea, it was mentioned, but would that only make one cylinder misfire, i looked around and havn't found anything yet...also the fact that one plug (cylinder 4) didnt smell like fuel and was burnt white makes me think that an injector seal may of blown...
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Feb 25 2008
    Cape May, NJ
    So does anyone know where to get one genesis 380 fuel injector, they all come in sets, and im not spendin another 300 if i only need one..
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Jun 11 2005
    Multiple Cylinder Misfires indicates MAF. I'm more than 100% sure.
    But if it's only ONE cylinder, then it is likely something else.
    GL
    2003 1.8T
    Feb 25 2008
    Cape May, NJ
    ^^^ It was multiple, but now its just one cylinder, im not to sure what went down that night, shifted into first and it was fine, then went into 2nd let the clutch out,hit the gas and misfire city
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Dec 08 2007
    Easton,PA
    do a compression test on the cylinder that is misfiring
    Feb 25 2008
    Cape May, NJ
    Cool, will try that as well. When i get home from work 2night, im going to pull the fuel rail off and check the injector just to make sure the rings are still good.
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Dec 08 2007
    Easton,PA
    i had the same problem. i kept checking everything then i did a comression test and noticed one of my cylinders was alot lower than the others it turned out to be a cracked valve.
    Feb 25 2008
    Cape May, NJ
    ^^ damn, im hopn for somethin simple like a seal, bent valves are no good, thank god i have a truck to drive
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    this is probably not the case with you, but i had the same problem where i thought the car was misfiring and i thought it was the coilpacks so i changed 2 of them and no change, but it was misfiring also when after the gear was shifted while i was driving, so turns out my tranny was done, but if ur fine from that point its probably something else
    Feb 25 2008
    Cape May, NJ
    im still hopn its the injector, i gotta wait till friday because work is killing me with the hours right now... I will update asap to see what the deal is...
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Feb 25 2008
    Cape May, NJ
    Quick update, shot some brake cleaner around the injector to see if the idle smooths out, did not, so its not a seal...I checked the new plugs and all 3 cylinders, the plugs are soaked with fuel, but when i pulled the plug on cylinder 4, it was bone dry...no fuel
    So im gonna jump the injector 2moro and see if shes clicks, if no clicks, then does anyone know where to find one genesis injector...i have a feeling im going to have to buy 4 which sucks...
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Feb 25 2008
    Cape May, NJ
    Re: Update on Misfire
    UPDATE!!!!...Pulled the rail off checked the injectors, switched the one on Cylinder 4 to 3 and started it, ran like crap, checked codes, Misfire on 3...WOOOHOOO, bad injector...time for a new one.
    Thanks for help guys
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Senior Member Three Rings AMESSA4_NJ's Avatar
    Jan 12 2009
    03 A4 B6 1.8TQ , dirtbike & a bunch of rims
    exit 91 , NJ
    good stuff
    "life is nothing but fast cars & cashflow....at least for me"
    too many parts too list and too many parts on my mind to buy..
