Results 1 to 21 of 21
Thread: Tire Pressure
    Veteran Member Four Rings anmagro's Avatar
    Sep 14 2008
    Tire Pressure
    Hey guys,
    My tires are gettin low. I think im saposed to look at the inside of the gas cap for the PSI for the tires. But theres like 12#'s in there. So for the 2.8L 30V 98 Quattro Manual on stock wheel and suspention setup, what tire pressure do you guys like to be at?
    Black On Black 98' Audi A4 2.8L 30V 5spd. Quattro "Esabell"
    BBS RK's - Zimmerman - Vogtland Sports - Thrush Welded Cat-Back - DDM 6000 - Reigar RS4 - K&N Spectre - EbaySS - SpeedTuning Stage I
    Sep 13 2008
    Western Chicago Burbs
    Re: Tire Pressure
    if you are using tires other than what was oem, look at the sidewall where it says MAX PRES. xxpsi cold
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    Re: Tire Pressure
    always 32 psi
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
    Sep 28 2006
    Lexington
    Re: Tire Pressure
    32-36 usually I put 40 in...Less contact with the road more MPG...HAHA!
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Re: Tire Pressure
    36 PSI on stock 16's with 225/50's works best for me.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    Re: Tire Pressure
    i stick around 35-40. 34 and lower looks so under inflated on my stock 205/55/16.
    If i were to go on a twisty drive i put them at 34 rear and 36 in front.
    I always have them at around 38-40 in front and 36 ish in the rear.
    NEVER set your tires at max psi, that is the stupidest thing iv ever heard.
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Veteran Member Four Rings Quattro 4 Life's Avatar
    Feb 05 2008
    '64 Pontiac Catalina
    Kenmore
    Re: Tire Pressure
    10% below max psi is the highest you should go, but most people run a little below that as 35ish is optimum for most passenger cars
    2013 Phantom Black C7 S6 Stage 3 | 2007 Ibis White B7 A4 Avant 3.2QM Titanium - 1 of 2 | 2013 Glacier White Metallic 4L Q7 3.0 TDI
    Past: 2003 Brilliant Black C5 S6 Avant | 2011 Quartz Grey C6.5 A6 3.0T Prestige | 2000 Silver C5 A6 2.7TQM | 1999 Laser Red B5 A4 1.8TQM PC-16
    IG: tyscalzone
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: Tire Pressure
    Max psi is for a fully loaded car at gross vehicle weight. Most go with 36-38 and I do for normal driving and in the winter. For road trips I'll bump them up to 40 for better mileage. They shouldn't be over 40 unless you are at an autocross event.
    Jim
    I Do Werk.
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Re: Tire Pressure
    46psi all round, 48 if loaded.
    Sep 28 2006
    Lexington
    Re: Tire Pressure
    Why so High?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Jan 09 2008
    United Kingdom
    Re: Tire Pressure
    Quote Originally Posted by AudiTurbo View Post
    Why so High?
    I'm running RS4 size - 255/35ZR18, and those are the recommended pressures.
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Re: Tire Pressure
    i use 35-40psi on my stock 16" sports. ive been trying to figure out a simple, universal tire pressure guide for all cars. this is what i have so far:
    wheel diameter= D
    (Dx2)+2= suggested psi.
    15" is 32psi, 16" is 34psi, 17" is 36psi, 18" is 38psi, 20" is 42psi, etc, etc...
    i know its not exact, and doesnt account for load and treadwear or anything, but it is average enough to work, and easy to remember for people who arent car buff's (wife, kids, friends, etc...)
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Jan 17 2007
    2001 A4 1.8TQM, 2009 GSX-R 1000, 1995 Dodge Dakota Sport, 2015 FFR 818
    Re: Tire Pressure
    If you are running small rims and big tires then low 30's (i.e. follow the gas cap).
    If you are running big rims and small tires then you need more pressure (not mentioned on the gas cap).
    Depending on the tire, I run between 40 and 45 (a bit high) when the max is 51 but that's with a 235/45 17. If you are using a 15" or 16" rim it should be less.
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    Re: Tire Pressure
    simplify your formulas man... that should be 2+D^2
    Sep 14 2008
    Re: Tire Pressure
    i just put them all at 40psi. its a little on the high side but it will help with gas mileage. and i dont drive like an ass so i dont really need that extra grip for winter or whatever. thanks alot guys. boy was that gas cap marking makin me mad standing in the cold bent over trying to figure out what its says. lol. yeah im on the stock 16s.
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Re: Tire Pressure
    38 in the summer, 32 in the winter.
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Re: Tire Pressure
    Quote Originally Posted by ghost6303 View Post
    lol your formula would kill every passenger vehicle tire!
    TEAM|AXION
    Mar 09 2004
    nw michigan.
    Re: Tire Pressure
    You've got 2 plus D squared. I think you meant 2+2D.
    Jim
    I Do Werk.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Tire Pressure
    38-40psi all year. 42psi for road trips.
    Stock 205/55R16
    Veteran Member Three Rings v1nyd's Avatar
    Jun 15 2008
    Long Island NY
    Re: Tire Pressure
    look at that max pressure on the tire and DO NOT go above that number try to stay at least 2psi under that number...I've seen tires blow from over filling ... buying a new tire isnt worth the maybe couple bucks you'll save on gas millage -_-
    Apr 06 2008
    Brandon, FL
    Re: Tire Pressure
    2D+2 ftw. and talk about overfilling, i saw a car 2 weeks ago with tire pressures like this:
    LF: 33
    RF: 31
    LR: 34
    RR: 73!!!!
    Current whip:
    RIP:
