Results 1 to 14 of 14
    Registered Member One Ring NJAudi2009's Avatar
    Jan 12 2009
    New Jersey
    Transmission. Do I know how to drive?
    Hey, I just recently purchased a 2002 A4 3.0l Quattro, 6 speed manual. I have driven alot of manual cars and have never had one that acted like this. If you really get on it through first gear and clutch to shift near redline, the engine just keeps like fucking zooming and the revs take forever to drop. It doesn't sound good and it sounds like I don't know how to drive the car. I don't understand it, it makes it terribly hard to get a smooth 2nd gear going.
    Am I just stupid and don't know how to drive? Like I said I've driven many stick cars before and I've never had one that acted like this, really romping through 1st and throwing it into second. Can't do it in this car. Specifically I had a VW Jetta vr6 and 1st gear through 2nd gear felt nothing like this, it was smooth as butter even really flooring it.
    Any input appreciated
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: Transmission. Do I know how to drive?
    clutch slipping..just a guess
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Jan 12 2009
    New Jersey
    Thats a possibility. I've never driven a car with a slipping clutch so I wouldn't know.
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    to me it sounds like the opposite...like your clutch isn't fully disengaging thus your engine rpms are still staying high even with the clutch pedal depressed.
    If that is the case the main thing that comes to mind is the slave cyl is no longer doing it's job. Check your brake fluid (as the clutch slave cyl runs off the brake fluid). I'm by no means a expert in this area so maybe someone else will chime in.
    BTW with a slipping clutch when you are on the gas the RPMs will suddenly increase (how much depends on how much your clutch is worn) while your speed will stay the same or slightly increase...kind of like if you were to rev the engine in N while driving down the road.
    Jan 12 2009
    New Jersey
    Quote Originally Posted by jessefrank View Post
    Okay, then I'm pretty sure it's not slipping because I've never had that happen. Just this problem with first gear not dropping revs when the clutch is pushed. I'll look into this slave cylinder. Any more input?
    Feb 22 2008
    03 A4 3.0 6MT
    The Meadows, NV
    my 2003 3.0 does the same, so I "fixed" the problem by shifting to second at 5K rpm.
    I can't
    press clutch pedal -> shift to second -> let out clutch pedal
    coordinated and fast enough when letting the revs go too high.
    Jan 12 2009
    New Jersey
    The most annoying thing, is to get a smooth shift into second you have to like wait 2 seconds after depressing the clutch in high RPM first gear for the revs to drop a little bit. This can't be normal.
    Feb 22 2008
    03 A4 3.0 6MT
    The Meadows, NV
    it seems like it has very small window where everything goes smoothly...
    either the rpms are high compared to the accel pedal position and when you shift the engine bogs down (or dies in first gear :( )
    or accel pedal is too high compared to rpms and when you press the clutch pedal, the rpms go even higher
    I think its the drive-by-wire throttle messing with me. Couldn't possibly be my driving technique!
    Jan 12 2009
    New Jersey
    Well it's good to know mine isn't the only one that does it. Anyone else have one that is like this? I don't know it it's something wrong or not, but it just doesn't feel right. Especially for such a nice car, I don't understand why it acts like that. First gear is useless to me, and not revving past a certain RPM makes me feel like I can't beat a 4cyl stock honda off the launch.
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Heavy flywheel. Normal.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Active Member One Ring tafc1383's Avatar
    Nov 09 2008
    ct
    i guess i baby my car quite a bit i rarely shift past 4,000 rpm
    Jan 12 2009
    New Jersey
    Quote Originally Posted by Tgr_Clw View Post
    Would a lighter flywheel change this?
    Feb 22 2008
    03 A4 3.0 6MT
    The Meadows, NV
    Quote Originally Posted by NJAudi2009 View Post
    You're not going to beat that s2000 no matter what.
    Or were you referring to this travesty:
    "Four Cylinders of Silent Thunder!"
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    yes
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
