    Veteran Member Four Rings nein-reis's Avatar
    Feb 01 2008
    MK6 GTI, MK1 GTI 1.8T, B7 A4 TE Avant
    SLC, Utah
    12V switched circuit
    I need a quick answer. I'm installing a smart cord for my passport X50. I have it all ready to go except I need to tap into switched circuit 12V. (one which is on when the car is on and off when the car is off). The wire is not long enough to run back up to the sunroof that a lot of the DIY's use. I need to use one under the dash by the fuse box. Any recommendations down there?
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: 12V switched circuit
    Use the Homelink fuse (if you have it).
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Feb 01 2008
    SLC, Utah
    I need a wire to tap into. Does homelink have a exposed wire I can tap into somewhere in there?
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Use the fuel pump fuse in the fuse box. That turns on with the car, and off. Just use an add-a-fuse and you'll be good.
    May 03 2008
    Orlando
    Quote Originally Posted by nein-reis View Post
    I used an add-a-fuse to tap the circuit.
    Kevin W.
