Results 1 to 40 of 43
    Senior Member Two Rings GermanAudi's Avatar
    Jun 01 2008
    2003 Audi A4 1.8T Multitronic
    San Diego, CA
    Just got chipped and...
    I don't really feel very much of a difference. I have been told that there should be a 35 hp and 40 tq bump from stock.
    Do I need to rev to a minimum RPM to feel more zip? I thought getting chipped should improve throttle response too. I have CVT.
    Anyone? I am running GIAC stage 1.
    2003 1.8T Multitronic CVT, Canvas Beige Metallic
    GIAC Stage 1 || 710N TT Diverter Valve || 6000K Xenon HIDs || VMR Vent Boost Gauge || Eibach Pro/Bilstein Sport Suspension
    Senior Member Three Rings Hotel Guy's Avatar
    Oct 07 2007
    Chicago
    Re: Just got chipped and...
    takes a few days to get the full effect
    Senior Member Three Rings AMESSA4_NJ's Avatar
    Jan 12 2009
    03 A4 B6 1.8TQ , dirtbike & a bunch of rims
    exit 91 , NJ
    i felt the same way when i got mine chipped the first day a while back. switch it back to stock and you will actually see how much you gained by it. then go back to the program and youll feel the power
    "life is nothing but fast cars & cashflow....at least for me"
    too many parts too list and too many parts on my mind to buy..
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    The first day I had my APR Stage 1 I scared myself the first time I punched it - definitely noticeable. Do you have a boost gauge? That will help you know when you're exceeding pre-chip boost levels.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Senior Member Three Rings FourRingsB6's Avatar
    Oct 07 2008
    2005 A4(HIS), 1999 Jetta(HERS)
    Lancaster, PA
    I'm running GIAC software and I definitely noticed it. No the gains aren't huge, but should be noticable none the less.
    Stretched, poked, and slammed.
    Buncha motorcycles
    Memphis, TN
    dont expect a 100hp jump on the butt dyno but it will pull harder..... i was also dissapointed in my 1+
    APR Stage 2/AWE Intake
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    yeah, its not that big of a gain. you were probably expecting too much. but like they say, give it a few days for the ecu to adapt.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    Quote Originally Posted by kwimberly View Post
    what boost is expected after stg 1 chip?
    Veteran Member Four Rings KareemA4's Avatar
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    I have a CVT and it's REVO chipped and it pulls hard...
    Denim Blue FWD
    Power = REVO K04, VMR Test Pipe, Forge 004 BOV, TT225 Injectors and Custom Novitech-Tuning FMIC, Magnaflow Turbo-Back Exhaust, Podi, Zimmerman Rotors, Hawks HPS pads
    WHP??
    Looks = Top and bottom Blackout grills, Yellow fogs, ASA Rims
    Suspension = 02 sport suspension and riding low
    Jan 10 2007
    VA
    i was disappointed with GIAC stage 1. i noticed the power but it was so peaky that it really wasn't that useable. GIAC FX (injector file) was much much better IMO. It not only boosted more but also seemed to hold power longer. For the cost I was definitely not disappointed with the 1+ file.
    bottom line. if you chip your car, atleast go 1+. it doesn't cost much more and makes sizeable difference. A 1+ B6 1.8T boosts the same as a Stage 1 1.8T on other applications (GTI, GLI, Passat, ect). So IMO stage 1 on a B6 is sorta like 1/2 a chip.
    Senior Member Three Rings G-Bus's Avatar
    Aug 25 2008
    Montreal, Canada
    I also got disappointed. I think its mainly all the hype around it. People say it becomes a new car.. bullcrap! Anyhow, on VWs its more noticeable but on our cars there's a difference but it's not huge. It goes from fkin slow to really slow.
    May 03 2008
    Orlando
    Quote Originally Posted by forevraudi View Post
    Mine went from peaking at 9-10 psi to peaking at 18-19 (20 every now and then) and holding at 14-15.
    Kevin W.
    Registered Member Three Rings VagStaR's Avatar
    Oct 03 2008
    04 A4 tqm. 99 saab 93 2.0T 5sp
    York, PA
    I'm revo stg. 1 right now and it spikes at 20 and holds at 16, but my gauge is a little bit off.
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    when I first got my GIAC stage one, It was seriously night and day, I am scheduled for the +1 tomorrow at my shop in Dallas, so I'm excited about it. How much are the +1 boosting? and how much hp with +1, and full exhaust?
    02 A4 3.0Q6MT
    -chad
    Buncha motorcycles
    Memphis, TN
    keep in mind 1/1+ is losing power after 4.5k-5k as fast as the titantic sunk. a CVT runs higher RPMs so it is keeping you OUT of the powerband if anything....
    most tuners advertise 225-235chp for 1+, if its a fully supported 1+ with FMIC, exhaust/tp, TIP you might make 250chp but it peaks quick and is done
    Veteran Member Three Rings Monkey77's Avatar
    Oct 30 2007
    2005 Audi A4, Tiptronic.
    new jersey
    When I initially got my GiacFx file, I was at about those numbers as well. Id peak at 20 psi from time to time, but averaged about 15. It will def give the car some more pull, but don't be super hyped that you can take on the world. I still regret not going BT instead of the K04! For the price of the chip, it's a very good initial upgrade. You'll be pleased, no worries
    " You can't be lucky all the time, but you can be smart everyday."
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Check your DV, mine was bad and felt the same way. Replaced it with a Forge and WOW.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    it should be a kick in the pants.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Senior Member Two Rings OC1.8T's Avatar
    Jan 06 2009
    B6 A4 1.8T 5sp quattro
    Orlando, FL
    I was happy with my APR 1+ chip gain .
    Senior Member Three Rings Greek Yayo's Avatar
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    go unitronicccccc... i love itt instant differancee
    Established Member Two Rings randylam's Avatar
    Jul 23 2007
    Hong Kong
    I got revo stage 2+, try to use the +- shift and you will feel the difference.
    Jun 01 2008
    San Diego, CA
    Quote Originally Posted by diztek View Post
    I sure hope so. I would hate to realize that I just blew $500 for nothing.
    Jun 01 2008
    San Diego, CA
    I tried driving in Tiptronic mode and I did notice a difference in the higher RPMs, which made me wonder...do you have to basically floor it to feel the car pull? I know CVTs tend to keep the RPMs between 2000 and 3500.
    Oct 22 2005
    Reppin the Mitten.
    Sweet spot for a k03 is not in the upper RPM range. All your gain is basically at 2800rpm-4500rpm. You are still slow, but with a chip, you can def feel the difference between stock and chip.
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    Quote Originally Posted by chadb2434 View Post
    x2
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Sep 01 2008
    San Diego, CA
    check your dv
    Jun 01 2008
    San Diego, CA
    I am still running the stock DV, but I have a 710N that I will install soon.
    Dec 06 2007
    Quote Originally Posted by Papachristou View Post
    my APR 1+ Still after over a year does not disappoint it still pulls hard and is still a ton of fun.
    U with a fully built 1+ setup with a 0-60 in the mid to low 6s should not complain that's freakin quick for this car.
    -Kirk
    BetaAlphaTau Member #58
    Sep 26 2008
    '05 Audi A4 B6 1.8t CVT
    South FL
    Let us know how the new DV works out for you. I was/am in the same situation.. didn't notice even a tiny difference with my GIAC on my CVT. Can't get under 8 second 60 m.p.h... it's been months now and I've kind of accepted the chip was just a waste. I'd be so happy if it was just the DV.
    Veteran Member Three Rings cdn20valve's Avatar
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    Guys, original poster is CVT. Doesn't matter what chip. The CVT is awful. I've worked on and driven lots of A4's. I'm a former audi performance tech.
    Anyway, the problem with the CVT is when you punch it it doesn't rev like 5 speed/tiptronic cars. It has no gears. The revs instantly shoot up to about 4,500rpm and stay there while the car accelerates. The problem is that this is above peak torque of the 1.8T engine. K03s 1.8T's pull hardest between 3000 and 4000 rpm, and CVT's don't make good use of that powerband.
    May 19 2008
    2003 A4 1.8TQ, 2006 Cadillac CTS
    Bakersfield, CA
    My audi tech says the same...with the CVT car the traction control is always on, maybe its a glitch in the software to make the car accept the CVT whatever it is it sucks!!! No Certified Audi Tech will love the CVT.
    Sometimes our ECU's take a couple of driving cycles for it to go into affect. The ECU is trying to figure what to do with the new flash. My APR stage 1+ with stage 2 flash was a huge difference and very obvious right from the flash time. Now when I bypassed my N249 valve it took 3 driving cycles before my car woke up and got back to its fast self. Our ECU's are like a overly sensitive 18yr old girl who just got dumped for an uglier girl...
    May 03 2008
    Orlando
    Quote Originally Posted by dr. brian View Post
    Isn't traction control always on with all of our cars?
    What's a Stage 2 flash from APR?
    Kevin W.
    Active Member Two Rings Guzzivox's Avatar
    Jan 12 2009
    '05 A4 1.8T SE / '07 Q7 4.2
    Chicago, IL
    Hi all, I am new to Audizine, and enjoying the incredible amount of information available. Thanks! I recently did the APR 1+ and DV, and I have the CVT. Unlike others, I noticed a huge difference mainly when I drop to the "sport" mode, or if I use the tiptronic. I definitely feel the low end and powerband, then it tapers pretty quickly. It also took a few days for the ECU to adapt, and now I know I must be doing sub 7's at least.
    Oct 07 2008
    East Texas
    Just got my GIAC +1 done today! I'm enjoying it!
    02 A4 3.0Q6MT
    -chad
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    I planned on going 1+, but wanted to drive a few months on stage 1 just to re-experience the thrill of "chipping". Noticed a slight difference with GIAC stage 1. Really noticed a difference in the middle gears when I went stage 1+.
    For those looking to feel a real difference right away, spend the extra to go right to 1+.
    FS: Audi TT 225Q Roadster
    Jun 01 2008
    San Diego, CA
    Got my 710N installed today and I still don't really feel that much of a difference. I'm not sure what is going on. I tend to drive with the RPMs between 2500 and 3500 so the turbo should be at its optimum efficiency, right?
    Is it just the CVT? Or perhaps a boost leak?
    May 03 2008
    Orlando
    Quote Originally Posted by GermanAudi View Post
    I have to drive outside of my normal driving habits to feel the kick of my chip. It makes sense if you have a boost gauge - you can almost see two modes of driving. If I'm just doing lazy Sunday drives around town, my boost gauge shows normal stock levels of boost - less than 10 psi. I have to want to go beyond that for the "chip power" to kick in. The boost gauge has taught me what RPMs I need to be at, how long the 18 or 18 psi peak will hold etc.
    In short - get a boost gauge if you don't have one. I think it will really help you learn the parameters of your power.
    Kevin W.
    Veteran Member Three Rings A4_Mike's Avatar
    Apr 09 2007
    2014%20Audi%20A4%2C%202017%20Audi%20Q5
    Cary%2C%20NC
    I got a chance to drive my cousin's Mitsubishi Evolution VIII in December and it pretty much reaffirmed by thought of having two options - 1. stock 2. BT at a minimum. Unfortunately, I am stuck with option 1 because I now have to pay for my braces for the next two years (~$5000).
    The turbo on the Evo VIII kicks in so hard - the power is amazing.
    2014 Audi A4 2.0T quattro | Volcano Red | Chestnut Brown | Tip | P+ | Nav + | Sport | B&O
    2017 Audi Q5 2.0T quattro | Ibis White | Ebony | Tip | P
    Feb 06 2008
    03 a4 tip
    CAL, PA
    The addition of the chip should be able to be felt. Your cvt may react diffrently than my tiptronic but when I added stage 1+ it was like night and day. Great bang for the buck, no doubt. Check your DV and for heavens sake get a boost gauge.
    z
    Jun 01 2008
    San Diego, CA
    OK. So I got around to getting a boost gauge. I noticed that with normal acceleration, I get about 12 psi of boost and sometimes it peaks at around 15psi. Are these expected boost levels?
    Only mods I have are GIAC stage 1 and 710N DV.
