Results 1 to 9 of 9
    Oct 12 2008
    2002 S4
    San Jose
    Two minor/quick problems
    Ok I'll make this quick. 2002 s4. Was involved in an accident about 2 months ago, I've had the car back for a week. Everything runs great, sounds great, seems perfect. However there are 2 issues:
    1) Check engine light is constantly on (it came on the second after the collision, and has remained on even after repairs) and starts to blink when I go above 60mph (roughly). I assume I just have to take it to audi to get this reset?
    2) Stereo just says "SAFE" on it and CD-IN (even tho there is no cd in it). I cannot use any functions on it, it just says SAFE. So yeah, I'm driving without music (lame). I assume when I take it to audi they can fix this, but is there any way I can do it before having to take my car in?
    Thanks everyone
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Re: Two minor/quick problems
    CEL could be a lot of things. It could be a sensor or snesor plug that was damaged in the collision. Only way to know is to check for codes. Autozone can read them for you. The SAFE mode is an anti theft feature in the radio. The code should be in your owners manual. If not then the dealership will have to get it for you. Go to Autozone and have the codes read first. If you need the dealership for any work they may do the radio for free while it's there. good luck
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    ^ good advice.
    You should really have a vag-com though, such a worthwhile tool to have.
    For the radio, as mentioned, the 4 digit code is written in your STEREO owners manual.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    The check engine light sounds like you are having misfires. I would pressure test. Also I'm over here in Los Gatos if you need access to a vag com.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Oct 12 2008
    2002 S4
    San Jose
    Quote Originally Posted by RolledMySTi View Post
    Thanks everyone for all the help.
    About the misfires, is this actively causing damage/harm to my motor (aka should I stop driving my car?)
    also, will this cable work?
    http://cgi.ebay.com/ebaymotors/Vag-C...motiveQ5fTools
    sorry I'm kind of new to all of this
    Oct 12 2008
    2002 S4
    San Jose
    Quote Originally Posted by obijohn22 View Post
    What exactly do you mean by 'codes' -- get it hooked up to a vag-com?
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Quote Originally Posted by golfman44 View Post
    Yeah that cable will work. Just download Vag-Com from Ross-tech and you;ll be able to read the codes.
    If the check engine light starts flashing, you really should stop driving the car, especially seeing you dont know what the codes are .
    The radio code can be obtained from the dealer for a ridiculous sum of cash.
    B5 S4 AWE Stage 3 - sold
    Oct 12 2008
    2002 S4
    San Jose
    Quote Originally Posted by Rajan147 View Post
    Any estimate on this 'sum of cash'?
    If it is expensive I might as well throw in a new headunit...I've been wanting to do it for a while now.
    Jan 29 2007
    08 S4 00 S4
    MD
    If you can pull the radio, you can get the AUZ number on top of it and they can generate the code with that and the VIN. This is usually why they charge you labor for the code. *Maybe* if you go in there with the AUZ number and your registration, they'll look it up for free, depends on the dealer..*Maybe*
    08 S4- Stock SOLD
