Results 1 to 18 of 18
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    o2 sensor CEL again, DAMN THIS SENSOR!
    so replaced bank2 with an old o2 sensor from my CASA, and now im getting
    bank2 s1, no activity
    bank2 s2, no acitivity
    bank2 probe heating blah blah blah, no working, what do you guys think it is, i put in a crappy o2 sensor in the driver side, and its bouching it up for me. when i clear the codes and drive the code doesnt come back, but when i turn the car off the code comes back, some quick help would be much appreciated.
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Re: o2 sensor CEL again, DAMN THIS SENSOR!
    Did you splice in the O2 sensor or use the whole unit with the plug and all from your other car? Also check the recieving end of the harness. (where the O2 plugs into) I had a bad wire there on mine, caused all kinds of weird stuff. If you spliced make sure connections are sound, i lnow this is a no brainer but other than that what can it be the ECU? or a bad sensor?
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Jan 21 2007
    01.5 Silver Avant
    dc
    I used the whole unit, so I didn't splice, buying a universal and splicing into it tomorrow. But don't see how that would make 3 codes say there is no activity
    Oct 31 2005
    Ashburn
    Quote Originally Posted by casawhites4 View Post
    Faulty wiring from harness to the ECU or faulty wiring from the harness to the Sensor.
    I thought you bought the sensor last week? You got me all confused
    - Instagram: @Sinister_rs5-
    Veteran Member Four Rings unknowna4's Avatar
    Oct 06 2005
    Soccer mom car
    South
    Hey casa ot but is your pm box full? If so pm with your email so I can grab that fender from you. Thanks
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    yeah, i'm confused also.
    Lets start from the beginning.
    What sensors were faulty? What did you replace them with? Why are you splicing?
    B5 S4 AWE Stage 3 - sold
    Jan 21 2007
    01.5 Silver Avant
    dc
    I got a universal one spliced that and put that in the passenger side, then I realized that I fixed the wrong one, so I had a CEL for bank 2 still on which I found out was driver side, and I went to swap that o2 sensor with a sensor from my Casa s4, put that sensor on and now I have the codes mentioned above, so there is no splicing or anything on drver side (bank2) sensor. What would cause all 3 bank 2 sensors to crap, do you thnk the o2 isn't tightened enough or that it's bad and somehow cause the other 2 to throw CELs. When I clear the codes and drive around the cel doesn't come on, but when I shut her down and crank her back on she throws the cel again
    Veteran Member Three Rings Ianxcom's Avatar
    Jul 30 2008
    Socal/Denver
    Which o2 sensor is the one at Bank2 S1?? Im looking on Purems and JHM and there are a few. Help?
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Ianxcom View Post
    Bank 2=Driver Side.
    S1= Primary upstream O2.
    08 S4- Stock SOLD
    Jul 30 2008
    Socal/Denver
    Quote Originally Posted by mholme View Post
    Bank 2=Driver Side.
    Thanks. Are these the right ones?
    http://www.jhmotorsports.com/shop/ca...b147bd26a5d110
    http://www.purems.com/products/product.php/II=1773
    Is there a difference or just priced different?
    Jan 29 2007
    08 S4 00 S4
    MD
    My computer isn't liking the purems website, but I would assume if it's just another picture of a front(primary) O2 sensor, then it's the same.
    08 S4- Stock SOLD
    Jul 30 2008
    Socal/Denver
    It describes it as this
    Oxygen Sensor
    Primary Sensor
    $149.95
    Regularly: $194.14
    Jan 29 2007
    08 S4 00 S4
    MD
    Then that's what it be, a front/primary, black harness, O2 sensor.
    08 S4- Stock SOLD
    Jul 30 2008
    Socal/Denver
    Anyone know if there is a difference in the 2. Besides $45
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    I would get the ones from VAST.
    Jul 30 2008
    Socal/Denver
    Quote Originally Posted by Evilevo View Post
    That one is more then the others, AND it looks to be the same as the JHM.
    EDIT: NVM. Thats per pair
    Jan 29 2007
    08 S4 00 S4
    MD
    One may be a Bosch while the other is OEM? I don't know, call or email them I guess.
    That's confusing, I should say the genuine VW/Audi part, not OEM.
    08 S4- Stock SOLD
    Jul 30 2008
    Socal/Denver
    I would assume they both work the same though. Eh. JHM sells quality products. Ill probably just go with them.
