Results 1 to 4 of 4
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    spacer + differential
    i got a flat tire and put back my 5 spoke oem wheel back on. but i couldnt take off the 15mm spacer off of the old cracked wheel. so now im driving with only one spacers in rear. it drives fine, i actually drove for 400 miles like that. but the steering wheel is a bit messed up. its not shaking or anything, just not straight anymore :(
    so is it ok to drive like that for a bit?
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: spacer + differential
    Wheel is aluminum.
    Spacer is most likely aluminum.
    Oxide was formed and the two are now 'welded' together. Get a rubber mallet and give the spacer a few good hits and it'll come off the wheel.
    You might prematurely wear your tires down seeing as one side in the rear is sitting closer to the hub and the other side is sitting further away. This changes the handling characteristics of your sedan. I would try to drive as little as possible to avoid excessive tire wear and unsafe handling of the vehicle.
    -Doug
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Wheel is aluminum.
    thanks. i had nothing like a rubber mallet with me when it happened.
    like i said car drives FINE, feels smooth, just the steering wheel is looking on a left more than it should be.
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    when you reinstall use some anti-sieze between the hub, spacer, and wheel.
