Results 1 to 16 of 16
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    Lean AFR after 5k
    My AFR goes from 10.5-11:1 to around 14.5:1 at 5k-up on my PC-16.
    i figured it was jusut the file, but any attempts to alter the MAF signal with an SAFC havent been able to richen the mixture.
    this leads me to believe i may have a fueling issue.
    Turning the FPR up to around 68psi got me where i needed to be at the top end, but of course i had a dip in the middle.
    anyone have any experience with this much of a lack of fuel? i was thinking maybe fuel filter or pump, but i wouldnt think the fuel pressure raising would be able to move more volume if it was clogged.
    Senior Member Two Rings Side-Step's Avatar
    Mar 05 2007
    Wife's 99.5 Avant,99 Dodge CTD,Wife's 05 S4 Avant
    Charleston, SC, East coast
    Re: Lean AFR after 5k
    What injectors and turbo are you running?
    What was the pressure set before you up'ed it to 68 @ WOT?
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    What's your injector duty cycle look like?
    Oct 17 2004
    Columbia, SC
    genesis 315's with the k04.
    pressure is supposed to be 3 bar. and thats not 68 @ WOT thats 68 at idle with vac line off
    and i have no idea what the duty cycle looks like, what block is that?
    Apr 10 2007
    Eastern PA
    It's block 002. Then you have to do this calculation:
    Injector Duty Cycle = Injector On Time / (2 Revolutions * (1 second / (RPM / 60 seconds) * 1000 ) * 100
    Also, I had to run 386 cc injectors at 4 bar with my GIAC Hammer file setup (on my 01). Maybe your injectors are too small? We'll see after you post your duty cycle I guess.
    Oct 17 2004
    Columbia, SC
    Quote Originally Posted by GetBoosted84 View Post
    i will have to wait until i get my new laptop, keg crushed the old VAG
    Oct 17 2004
    Columbia, SC
    i have a 16.32 ms at every rpm on block 002
    that formula comes out to a very small decimal.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    The PC16 file is tuned for 310cc injectors at around 2.7-2.8 bar. With the 3 bar FPR it runs pretty rich down low.
    It almost sounds like his fuel pump isn't moving enough fuel, this could be just a warn pump or his fuel filter might be clogged causing fuel pressure to drop at 5k+ rpm which means reduced fuel supply.
    Apr 10 2007
    Eastern PA
    Your Injector Duty Cycle comes out to this:
    RPM OT Duty
    3000 16.32 40.8
    3500 16.32 47.6
    4000 16.32 54.4
    4500 16.32 61.2
    5000 16.32 68
    5500 16.32 74.8
    6000 16.32 81.6
    6500 16.32 88.4
    * OT = Inj. On Time
    Mike is right, not your injectors... they are only getting to 88% by redline.
    Jul 07 2004
    socal
    Yeah I would start looking for something that is causing a fuel supply restriction on the car. This tune has been around for nearly 10 years so plenty of people have been runnnig it and still run it.
    Oct 17 2004
    Columbia, SC
    i am gonna try swapping pumps this afternoon.
    the filter is only 1 year old
    Senior Member Three Rings Jerstillman's Avatar
    Dec 21 2008
    2008 audi a4 2.0t Cabriolet
    San Luis Obispo, CA
    Yeah i personally would swap filters and go from there. Thats usually the problem with low fuel output at WOT
    Oct 17 2004
    Columbia, SC
    swapped filters last night, the fuel looked like jack daniels coming out of the old filter.
    in the first to runs to ~5600 rpm, the 02 voltages stayed in the mid .8's
    and i noticed my cold crank time decreased as well. i plan to get in a full run and see what the logs look like.
    Senior Member Three Rings jakecro's Avatar
    Feb 08 2007
    '00 S4 6MT 324K mi stock K03s
    Pittsburgh
    zOMG/oes noes, you didn't drink teh jack daniels did you?!
    -Jake
    [email protected]
    www.audidatabase.com <--feel free to contribute material
    new siggy
    710Ns|CC|VDO Vent Boost Gauge|Piggies|LW Crank Pulley|034 Snub|Hawk HPS|K&N|Continental ExtremeContact DW
    Oct 17 2004
    Columbia, SC
    no, but your mom did.
    buuuuuuuuuuuuurrrrrrrrrn.
    sizzle sizzle
    so if your AFR looks like this:
    <--dyno fail
    suspect your fuel filter.
    edit: BTW it put down 189 whp at 4200rpm before stopping due to the AFR. this is after more supporting mods to the PC-16 setup.
    namely a P&P mani and a VR6 OBDII throttle body
    Oct 17 2004
    Columbia, SC
    Update. Went to the dyno last month. Same crappy afr. The safc did alter the curve, but with the safc maxed rich, it was still waaaay lean. Then I noticed my fuel pressure was not rising with the boost as it should.
    Then I started thinking, I have had no residual pressure and long cold starts since I went pc-16. I immediately face palmed and realized I needed to try a different fpr. I just put 034's items at the bottom of the list of possible failures, especially because they are newer. Today I tried an old 4 bar fpr and hooked up a pressure pump and the pressure rose exactly 1:1. And no residual pressure dip after the engine shut off.
    Eagerly awaiting a new fpr now.
