    Aug 06 2008
    Canadia
    smells wild in here
    I just finished a pan service for my S4, had to replace the pan gasket because the POS rubber one was leaking. The only way i could get a paper gasket was with a filter, so i ended up changing that too.
    anyway, i splurged on some valvoline max-life ATF (the fluid that meets every single transmission requirment known to man except type-F) for the fact that logically it must be at least a semi-synthetic and it was only $17 for 5 litres. But man, this stuff smells like whale oil, that nasty stuff ford adds to LSD differentials, now my garage smells like it. Its certainly not as intrusive as the LSD additive on its own but its enough.
    I'm off to do a road test to see if it helped any, i'll let you know how it goes.
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: smells wild in here
    Tranny fluid smells awful. I replaced mind recently and it stunk up the garage as well.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    atf isnt as bad as gear oil. my garage smelled like gear oil for a year. it sucked ass
    Aug 06 2008
    Canadia
    Quote Originally Posted by RolledMySTi View Post
    this stuff takes it to a whole other level, lol.
    Worst smell that you will have a hell of a time getting rid of is carburetor cleaner, its like 80% xylene which is the main ingredient in brake clean (the stuff that does the bulk of the disolving). It works like the cats ass, but it will disolve your nitrate gloves in no time.
    I got a can of it in my garage, I only use it in the summer when i can take it outside. If i use it in the garage, the whole house will stink.
    Veteran Member Four Rings Big Boost's Avatar
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    To make a long story short....I was in my Yukon XL after a snowstorm and I thought I was Rhys Millen so I "drifted" into our parking lot and the truck hit something. It was a f'ing boulder that was covered up with snow!! It sheared the axle right off. The disc brake face and the wheel studs were still attached to the wheel laying off to the side of the truck. I had to buy a new wheel, axle, disc brake, and two quarts of gear oil and we did at at work. The shop still stinks after three weeks. Mind you, the shop is over 3500sq. ft. They HATE me at work. It smells like a bums ass on a hot summer day, allegorically speaking of course.
    2015 Audi A3 Stage 3+
    2001.5 Audi S4 VRT
