Results 1 to 30 of 30
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    JHM rotors installed, along with other stuff.
    As it says. I got the JHM lightweight rotors, along with ECS SS lines for front and back, Brembo 600F brake fluid, Hawk HPS Pads. OE rotors for the rears with Hawk HPS.
    Rotor construction looked excellent, as expected. I will be testing the brake combo this week. Obviously my brake pedal is a lot stiffer with the SS lines....noticed that immediately.
    First day...wasn't able to test them out really....it snowed so bad outside...the day i had them installed. All my car could do was slip across the pavement and conti2s didn't help the situation. The shop tried their best to seat the pads...but I will do it tomorrow morning.
    Throughout the week i will test the setup for braking on the highway as well as street. First day with the setup for what its worth felt nice. I'll report back with some testing on tomorrows drive into work.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Re: JHM rotors installed, along with other stuff.
    Great to see you got them on. Please let us know how it turns out. I am very happy with mine.
    Also I think after you mentioning it I might up grade my brake lines now. Thanks for the feed back
    If you don't have haters, then you're not kicking enough ass.
    JHM powered 12.2 On the JHM Tune With Launch Assist for the Automatic JHM Nitrous kit/JHM headers all this in a Automatic.
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    yeah the ss lines alone were a huge improvement over brake pedal feel.
    it stops pretty good.....i did a few 50-0 stops and even with it being wet out....it stops pretty good.
    on inspection of the rotors themselves....very very happy with the construction. they are lightweight. between the pads and the lines and rotors...i'm very happy with the combo.
    as for the revving up quicker because we cut 10lbs off each corner....can't say i notice that. nothing like when i ran an EFK...but that is pure drag on the motor. if i get a run in against my bro and something changes...i'll let you know.
    The RIDES:
    AMA Member
    JHMFTW!!
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Any pictures with the rotors installed?
    Veteran Member Three Rings nealRlett's Avatar
    Nov 27 2007
    B7 S4, '71 BMW R75/5
    pics?
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    They're nice rotors, but I don't think you're going to see an increase in speed from them. What you might notice is a little less gyroscopic effect on the front suspension over bumps and road irregularities. You've cut the unsprung weight, and that will reduce the rotating mass of the front wheel assemblies. That will allow the shocks to modulate the suspension movement more effectively.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    i'll take some pics for you.
    The RIDES:
    AMA Member
    JHMFTW!!
    Established Member Two Rings eweu's Avatar
    Aug 25 2008
    Silicon Valley, CA
    b00st, do you track your car at all? I'm curious as to how these might hold up to the heat and stress of the track.
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Quote Originally Posted by eweu View Post
    nope...i don't auto-x my cars. drag......and even then its been a while.
    its an excellent question.....with the giant vanes for venting...i'm sure they will do alright. worst case...you replace the ring. maybe a slotted for better venting and a track pad.
    my car is not setup for auto-x. stock suspension, stock tires. with the stock calipers.
    i don't think my upgrade would do horrible by any means but its a street setup, just as i like it. if i were to auto-x...i would want suspension upgrades and rim/tire combo plus brake kit. and braking in the turns....its about the caliper...i'd feel more comfortable at a 6 POT. along with the SS lines, good rotors and a high boiling point brake fluid. as my friends have told me...when he did his alcons on his b5 s4....it made a HUGE difference over his stock calipers with upgraded rotors and pads.
    but like i said....a 10 or 20 minute track event....worst case...you replace the rings at 150 which aint bad at all.
    The RIDES:
    AMA Member
    JHMFTW!!
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    i will get some pics up for you guys. with heavy snowfall this afternoon...i wasn't able to test the brakes any further. and probably won't even drive my car tomorrow if the snow continues.
    The RIDES:
    AMA Member
    JHMFTW!!
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    Quote Originally Posted by b00st View Post
    Quote Originally Posted by AudiOso View Post
    First off. PICS PLEASE!! Always need more pics for my site.
    As for acceleration, in a customers car currently in the shop and Justin's car we saw 10 to 15 RPM per second increase in acceleration throughout most of the powerband in third gear (2000 to 7000 rpm). We do these kinds of acceleration calculations whenver making and testing any new product to verify proof of concept. We also do it in small rpm increments to see which mods affect which part of the power band. These kinds of small gains can hardly be felt by the "butt dyno" if not at all. However as you slowly put all the pieces together for a nice combonation the end result is a fast car. Unfortunatly with a Naturally Aspirated car like this the performance gains are small and the correct ones need to be combined. This is part of the fun for an all motor car, slowly getting it quicker and quicker and eventually taking down some fast cars and surprising yourself, since your "butt dyno" can't tell the story. Bottom line: there is no magic bullet unfortunately like a boosted car (up the boost).
    Glad to see you are enjoying them thus far. Rears are in the works.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    just something to hold you guys over...these are iphone pics at 1:30am. i'm tired. i'll do real pics and post up with real camera.
    apparently the camera rotated them too. i'm just tired to fix. it snowed like a mofo here in chicago...i'll try and clean up the rims and take better pics for you jay! or at least clean one rims up
    The RIDES:
    AMA Member
    JHMFTW!!
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    my mods are light weight rotors and no spare
    soon...i'll do a light weight battery and then i'll work on vast piggies and undecided on the CB. then hopefully a JHM tune.
    with final touch of winston's CF interior.
    The RIDES:
    AMA Member
    JHMFTW!!
    Sep 16 2008
    B6 S4 Avant Nogaro 6-speed MT
    Normal, IL
    I just got my JHM lightweight rotors on too. Thought I would provide a review in your thread if you don't mind.
    I did not do anything but Hawk front HPS pads and the JHM rotors. Like boost, it feels like my car brakes a little better, but I haven't done any concrete testing. I do notice the pedal feel now that you mention it boost. Next time I go to do my rear pads I'm probably going to do SS lines and a good fluid too. I was 50/50 on that when I bought the rotors and decided to wait and see.
    Another thing, I'm not sure if I'm imagining this. Boost and Justin let me know if you noticed this... When I turn my car at low speeds now I notice more of a light steering input. I don't remember it ever being this light. I haven't really cornered hard yet because the weather sucks so bad right now. But I feel this even on very slow corner maneuvers. I have an Avant and it is super heavy. So I'm not sure if my car might be more noticeable when I drop unsprung weight in the front than a Sedan. I wouldn't think so, but maybe. In any event, it feels like they are doing something even at low speed.
    Stuff on the car right now:
    Driveline
    Apikol rear diff mount
    Apikol engine snub mount
    JHM extra SS
    JHM shift knob
    Suspension & brakes
    H-Sport RS4 swaybar kit (rear on low setting)
    Hawk HPS front brake pads
    JHM lightweight front rotors
    As far as vision appeal - these rotors are beautiful. Nicely built/manufactured product.
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Quote Originally Posted by Captain Insano View Post
    I spent quite some time on those center hats to make them look flawless. It makes it worth it when the end user appreciates it. Thanks
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Senior Member Two Rings ZONAWILDCATS4's Avatar
    Apr 14 2008
    996 Carrera 4s, 2018 F85 X5M
    WheatonIL
    No doubt they are top notch. They look beautiful. Now I just need some light weight wheels to further reduce the unsprung weight...
    I got the same setup as b00st...JHM LW rotors and Hawk pads along with SS brake lines. Gonna wait to get mine installed.
    My brother keeps copying what I do...I buy a B6 S4 and he buys a B6 S4. Now he is copying my mods too...
    Sep 16 2008
    Normal, IL
    Quote Originally Posted by Matt@JHM View Post
    Nice job man. I'm serious they are beautiful pieces of work.
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Quote Originally Posted by ZONAWILDCATS4 View Post
    sheeyit....you may have bought the car first....i had nothing pressing me to buy. but i was looking. you had to buy when you did. i got to take my time and get a steal.
    and i bought the brakes first AND installed them. actually i bought the first audi and you copied me.
    The RIDES:
    AMA Member
    JHMFTW!!
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    honestly...i can't say i noticed that. you mention it now...i don't want some placebo effect going in my head. i can't really corner hard either for the same obvious reasons. but when driving today i still felt that the steering input was the same.
    The RIDES:
    AMA Member
    JHMFTW!!
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    jay you should have your logo CNC'd in there on the hat. looks like there is room under the bolts to do it. just a thought. they look killer though.
    i'll get some good picks up when it stops snowing and effing up my car.
    The RIDES:
    AMA Member
    JHMFTW!!
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    Do the s/c and see if he copies that, haha, otherwise you'll def have him beat!
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    did all you guys install the rotors, lines and pads yourselves? 1-10 DIY, what is the difficulty?
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    Jul 24 2008
    chicago
    The lines will make it a little harder with the need to bleed the system. But without the lines on a scale from 1-10
    for the rotors=2
    for the pads.=3 you need to pay attention to the metal brake pad holder
    brake lines...=4 you will need to bleed the system. not including bleeding the system the actuall line replacement is a 2.5 but replaceing the line is not all that dificult there is a few things you will need to remove
    To make the pads easier to replace and taking the skill level back to a 2 for the install here is a tip.
    When getting ready to remove the caliper. Stop for a sec and go to your tool box. Find a socket that will fit between the brake pads. When removing the caliper insert the socket between the brake pads to stop the brake pads from collapsing during the removal. From there just make sure to put in the pads on the piston side first. Before you remove the pad from the piston side. If you can find a way to compress the piston back into the housing (with the brake pad (old) still on this will help when you put in the new one. Just make sure to keep the caliper piston compressed and put on the other out side pad and the clips. Then reinstall the caliper ontop of the new light weight Rotor and bolt her all back together. In the end the front is very easy to do
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Quote Originally Posted by whartung View Post
    i paid to have it done. the lines are what requires the time. install the rotors is nothing. a 1 in difficulty....take older rotor off...put new on.
    install pads is a 2. compress caliper...but pad in.
    lines are a PITA...it requires time. not so much skill but its time plus bleeding the brakes.
    The RIDES:
    AMA Member
    JHMFTW!!
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    and as i remember it...you were stuck on a TT. i wanted to buy the S4....just later and i did just that.
    The RIDES:
    AMA Member
    JHMFTW!!
    Dec 19 2007
    1988 Mercedes 300E, 2008 Triumph Speed Triple
    Colonie NY
    b00st - do they use salt in your area? If so watch your lines and see if you have any rust forming on the ends where it screws to the line. I know that sounds counter intuitive, but I recently put some on mine around Thanksgiving and am beginning to see signs of corrosion. Mine were purchased through Blauparts, I have had luck with them in the past but this makes me question the quality
    Brett
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    if you havent done it before, get a friend to help who knows whats up. the last thing you want is a a plugged or leaking brake line
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Quote Originally Posted by BADB5A4 View Post
    Brett
    aye....they do. lots of it...and when we run out as we do....sand.
    nice things about ecs lines....they are coated with red vinyl to protect it from the elements.
    The RIDES:
    AMA Member
    JHMFTW!!
    Dec 19 2007
    Colonie NY
    Yeah those do look nice. The ends are still exposed though and thats the part that I am suspecting. It will be interesting to see if they are affected like mine after some exposure. Hopefully not, but keep an eye out non the less.
    Brett
    Aug 24 2005
    Lathrop, CA
    Yeah, will probably do that on the next run of them. We just wanted to see how sales would go.
