Results 1 to 18 of 18
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Big crankcase vacuume leak
    Let's try this here since i didnt get any help elswhere. Everyone else must be lost just like me on this one. First off i checked all the hoses, switched my old PCV valve with new and nothing. When i open my oil cap or pull my oil dipstick it sucks air like crazy. Today i took my F hose off and it's sucking air through there like crazy is that normal?
    I dont know the 2.7t motor very good but whatever needs to be replaced i can do it. Could bad intake cam follower do this? Im lost at this point and have no clue what else to look at.
    Here is a vid i made.
    Jul 26 2008
    Jersey
    Re: Big crankcase vacuume leak
    I asked my friend and he said you have a hose hooked up backwards somewhere.
    I'll try to get him to look at the video for you.
    Jan 03 2008
    Iowa
    Quote Originally Posted by spinny View Post
    Please do man i need this fixed. I dont really wanna drive the car til this gets resolved. I looked over the hoses and cant see anything wrong. I wish someone had an S4 in my area so i can look at the engine bay.
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Yeah, sounds like you have a manifold vacuum line running to your crankcase. Pressurizing your crankcase = BAD IDEA. so you're doing the right thing by keeping it parked until you get it fixed.
    Side not for any smart ass comments to come: pressurizing your crankcase is completely different from pressurizing your cylinder.
    Jul 26 2008
    Jersey
    I had mentioned something about it to him briefly and he said "yeah he has a hose backwards"
    I THINK I remember him saying something about possibly the brake vacume hose, or something "back there"
    Get a schematic, and double check your work.
    Jan 03 2008
    Iowa
    I believe when i pulled the motor Brake booster hose stayed on and i didnt touch it just unpluged it from the booster but i will double check everything.
    Thanks.
    Jan 03 2008
    Iowa
    Quote Originally Posted by gmann View Post
    Bad part is i already drove the car for about 60 miles It will not move until it's fixed for sure now.
    Jan 03 2008
    Iowa
    I used this diagram to check everything over.
    below is a pic when my motor was out.
    What else could it be if all the hoses are connected right? Intake followers? Anything internaly. I dont think so but you never know with these cars.
    Jul 26 2008
    Jersey
    Quote Originally Posted by GetAwayFromMe View Post
    I had my buddy take a look at this post real quick.
    here's what he said
    i would be willing to bet a large amount of money that the big "spider " set of crankcase ventilation is on backwards , wrong , or broken.
    He also said there's no way it's the cam followers.
    Also if you could post up some really close pics of the rear of the motor where the 'spider' crankcase ventilation is he could look at it for you.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    there is a check valve on the back of the engine that people replace backwards and causes problems, forgot what one it is.
    Jan 03 2008
    Iowa
    It's impossible to put the spyder hose backwards on this car. Just look at the pic above and you will see. I will try and get a close pic of the back when i get the car back from the exhaust shop.
    I had some time to look at it more and it seems that some hose is hooked to a place where is doesnt belong all the crankcase hoses are in where they should be. Another thing is that turbo hoses might be hooked up wrong causing the vacuume to the manifold and going to the crankcase.
    Jan 03 2008
    Iowa
    Quote Originally Posted by infinkc View Post
    Hmm... Whitch one? I didnt remove any check valves when i removed the manifold i left them on. What's the chance i mixed up one of the turbo lines? How much vacuume do turbos produce anyway? I wish i had access to some nice diagrams of all the hoses that would help alot.
    Jul 26 2008
    Jersey
    Please update the thread - I know you fixed the issue.
    Just in case anyone else has this issue, the search function will help them.
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    who uses search?
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Jul 26 2008
    Jersey
    Quote Originally Posted by wdbdy2000s4 View Post
    who uses search?
    People who aren't toolbags? non n00bs?
    Oct 08 2008
    MA
    ::looks around and realizes these people hardly exist on audizine::
    Senior Member Three Rings lowered97a4's Avatar
    Mar 08 2007
    08 turbo busa 09 nissan Gtr
    ct
    lol ya thats true but maybe those few will find it id like to know what it was its pretty fucked up
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    JHM/AMC trans rebuild
    03 Rs6
    Wagner intercoolers carbon fiber shrouds
    Ecu/Tcu tune
    Cats Removed
    Jan 03 2008
    Iowa
    Well.... The vacuume was comming from the intake manifold right by the throthle body going to the F hose. I never fixed it i just capped the pipe and the f hose and called it a day. I Pressure tested it and found a check valve to be cracked somehow, i replaced that since but i dont thing that's what caused my problem.
    I dont think i should say that i fixed it but i dont have a vacuume leak anymore and the car runs just fine. I can boost 22psi no problem. Before it wouldnt go over 14psi.
    -02 F'in Silver. GT2560/s AWE, ER/s RS3 Wheels, KW/s and every other typical S4 upgrade.
