Results 1 to 10 of 10
Thread: Rod Bearings
    Oct 06 2008
    GTI 1.8T
    Chicago
    Question Rod Bearings
    are they hard to replace on a 1.8t 2003 gti ?
    **--Euro Crew Chicago's VW/AUDI/BMW club-**-
    Www.EuroCrewOnline.coM
    VOLKSWAGENS.... They're like the hot girlfriend who isn't good to you and has all sorts of nervous
    breakdowns and you really should get rid of her.... but damn she's hot!!!
    Account Terminated Four Rings
    Feb 18 2008
    A4 Avant 1.8TQM
    Downers Grove
    Re: Rod Bearings
    Quote Originally Posted by Euro Crew View Post
    you gotta basiically take apart the entire motor......so ull need new rings too..and engine gaskets...
    short answer: yes.
    Oct 06 2008
    GTI 1.8T
    Chicago
    Re: Rod Bearings
    from what i know u can change rod bearings just by takeing off your oil pan all i need to know is do i need any special tools or change any bolts after takeing them off
    Feb 18 2008
    A4 Avant 1.8TQM
    Downers Grove
    Re: Rod Bearings
    ....if u half ass it yeah u can do it that way. get a torque wrench and new bolts!!
    Jan 19 2008
    Re: Rod Bearings
    Quote Originally Posted by Koselowiec View Post
    you can...but you gotta drop ur crank too...a torque wrench and thats it really...why are u changing them?
    Why do you need to drop your crank? Can't you just undo a rod and slip out the rod bearing and put new ones in? If piston to valve clearance is an issue, can't you just rotate the crank?
    Feb 18 2008
    A4 Avant 1.8TQM
    Downers Grove
    Re: Rod Bearings
    Quote Originally Posted by T3hD0gg View Post
    what im thinking is that if the bearings went bad id inspect the piston sleeve and the crank....ive seen piston slap with bad bearings. usually when those bearings go bad the motor has seen alot so other things will be worn?
    Jan 19 2008
    Re: Rod Bearings
    Ah, you said that because other things may need to be checked.
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Re: Rod Bearings
    Why?
    You could half ass it and pull the oil pan and pull the connecting rods that way, but you will be likely to pull the piston down out of the cylinder that way causing you to remove engine cyl head and having to inevitably do what you should do to begin with. If you have no mechanical experience, this is NOT a job for you. And by your question you asked you have very limited experience. So I say leave it to an expert, in the long run you'll be better off.
    PS wtf does this have to do with the mid west?
    Feb 18 2008
    A4 Avant 1.8TQM
    Downers Grove
    Re: Rod Bearings
    Quote Originally Posted by gmann View Post
    Why?
    lol. if you need work done......pms are accepted.
    Jan 12 2008
    Re: Rod Bearings
    I do the work, too.
