Results 1 to 10 of 10
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Turn Signals keep on going out?! + (new member pics)
    Well recently my mom picked up an 05 Brilliant Black USP. I love the car myself and am pretty jealous. Its been a couple weeks since she has had it and the turn signal says it is out. I went to replace the front parking passenger side light and after a day, it said it was out again? And then a couple days later, it says one on the front and now the rear are out. Is this a general problem with the B6? And how can it be solved? Something just doesnt seem right. I searched but didnt really find anything.
    Chris
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Turn Signals keep on going out?! + (new member pics)
    Sounds like a poor connection at the bulb, or the wrong bulb.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Sep 13 2008
    Western Chicago Burbs
    your b5 is sooo clean
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Wow the B6 looks really fat there...
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    I've had a similar issue...from the front turn signals...marker lights to the rear tail lights. Like has been stated, most likely a bad connection. I just had to remove the bulb clean up the connectors (@ bulb and housing) with a wire brush and put some electrical connector gel in there. I had 3 bulbs that needed this. I acutally just started having issues with my front pass turn again after doing the cleaning some 30k ago....but I'm sure it only needs cleaned again as if I tap on the housing it comes back on.
    ...Nice set of Black cars BTW
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    my jetta did this. It seems like every bulb decided to go out in the matter of 3 weeks at about 70k miles. It should be ok after you change them all. lol
    02 A4 3.0Q6MT
    -chad
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    Clean b5 and please tell your mom to lower her b6
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    NICE USP
    Veteran Member Three Rings dpatel's Avatar
    Oct 03 2005
    Atlanta, GA
    It's most likely the connectors. Seem to be a common problem with B6 turn light bulbs.
    - 3.0 Quattro
    - Milltek Exhaust with 4" Tips
    - Hyperflow Intake
    - Caracter Front bumper
    - Eibach Pro Kit + Bilstein Sport Shocks and S4 Rear Sway
    - Sportec 18" wheels
    - Stoptech Slotted Rotors with Ceramic Pads
    - Level 10 VB & APR Snub Mount
    - G3 SuPeRcHaRgEr
    VP of 3.0 CLuB
    Registered Member Two Rings wiscaudi's Avatar
    Aug 03 2007
    Milwaukee, Wisconsin
    Just logged in here to post the same exact problem.... Front passenger turn signal, left rear light and right rear light, all out within a matter of a month. I really couldn't believe it was a dirty connection issue seeing as they all went out so close together. I will clean up and report back.
    Those are some fantastic looking A4's
    2003 B6 A4 1.8T Quattro 5 Speed
