Results 1 to 3 of 3
    Senior Member Two Rings EuRoSp1c's Avatar
    Nov 04 2008
    Jersey
    what size is charge pipe hose?
    im going to pa to do my fmic.... what size is the charge pipe hose o.d.. my piping is 2.5 in.. so im thinking i need to get an adapter to be able to put it into the hose that comes off the turbo on passenger side... does any one know if its 2.25 or 2 inches? thanks in advance
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    Re: what size is charge pipe hose?
    the stock turbo is 2 inch. you want to run 2" piping from turbo to IC, then if your IC is 2.5", run 2.5" piping from IC to TB
    Nov 04 2008
    Jersey
    thanksss
