Results 1 to 16 of 16
Thread: lost gears?
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    lost gears?
    My wife was out driving the A6, and calls saying it's broken.
    I head over to where she is, and the car won't go in first, second, or reverse. It goes into 3rd-6th with no problem.
    Since I've been adjusting my shifter, that was my first thought. I messed around with it for a while, but the best I've been able to accomplish is being able to get it in 1st and 2nd, but it feels like I'm pushing it in against a 50 lb. weight, and getting it back out of those gears involves pulling against that same weight.
    The car works great when it's IN gear, and doesn't pop out or anything.
    Thoughts? Is there anything that it can get hung up on under the car?
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: lost gears?
    Quote Originally Posted by pit viper View Post
    Since I've been adjusting my shifter, that was my first thought.........
    Sounds as if you have discovered the problem.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Re: lost gears?
    Quote Originally Posted by InTTruder View Post
    Possibly, but I went through and readjusted it, using the 3-and-7 degree angle setup, as well as a few other tricks I learned from JHM when I first installed it, and it's not at all like the "it won't go in gear" issues I had from an out-of-alignment shifter.
    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T 6MT Modded. Allroad 2.7T 6MT.
    LI,NY
    Re: lost gears?
    Or you may have discovered the infamous 1-2 shift collar problem... There is videos on JHM's site explaining how/why it goes bad. Very common issue on our trans..
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me, full weight, street tires, 29+lb wheels.
    Ran an 11.8 @ 119 at MIR - Sept 2008. FIRST A6 IN THE 11's!
    Also 04 Touareg 4.2 89k with 22x10s
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Re: lost gears?
    shit, that sounds EXACTLY like what's going on.
    Man, THAT is not a cheap fix, is it? Wow.
    Veteran Member Four Rings RomanA6's Avatar
    Mar 01 2005
    2007 Black VW Jetta GLI DSG
    Rochester, NY
    Re: lost gears?
    I had to get a new transmission
    lost R, 1, 2, occasional 3
    adjusting made some gears come back and others disappear
    good luck!
    May 04 2007
    LI,NY
    Re: lost gears?
    JHM makes a great rebuild kit. I know two people who did it so far. Mine is starting to act up, but I am not there yet. Both of them loved it. They kept the stock gearing, but JHM also offers an upgraded 6th gear (for add'l $) that lowers your cruising rpms and increases top speed you are geared for. They have two levels of improved 6th, and the more dramatic of the two brings your 80 mph cruise from 3k rpm to 2450 rpm. So gas mpg is very improved. That same set brings the top speed (hp allowing) you are geared for from 189 to 229
    The kit itself is not too bad cost wise for what you get. The cost adds up if your clutch & fly are old, because it would be dumb to not change them while its all apart.. My fly and clutch are both pretty new, so its just gonna be the kit when I do it.. Check it out-
    http://www.jhmotorsports.com/shop/ca...products_id=10
    http://jhmotorsports.com/products/do...ar_options.doc
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Re: lost gears?
    Yeah, I was checking that out. I just did the clutch and flywheel right before Christmas. I wish this would have failed first, to lump all that labor into one time.
    I'm waiting on pricing back from a locally recommended place, to see if they do it or I ship the tranny to JHM. If I had a garage, I'd be willing to take a shot at it, but I don't.
    May 04 2007
    LI,NY
    Re: lost gears?
    I hear that.. I had to replace a clutch twice in about 6-8 months.. Once when I went stage 3, then again when I cooked that clutch. Now it will be down again for the rebuild... Ugh!!
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Re: lost gears?
    pit viper - youve kinda had a few problems with that beast havent you? What were the other big items you fixed?
    Dont feel too bad I need a TQ
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    Re: lost gears?
    sounds like what mine was doing before she blew man
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Re: lost gears?
    Quote Originally Posted by audirs View Post
    what man did she blow?
    Mar 22 2005
    Kitchener, Ontario
    Re: lost gears?
    lol goddamnit viper
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Re: lost gears?
    So, I'm thinking this time I'm going to yank the engine & tranny, fix the tranny, and install the lesser-mileage motor with new turbos, timing belt, etc....
    So, count on not seeing any posts about my car running for a bit.
    Feb 13 2008
    Re: lost gears?
    Ouch. That's a bit of work. But, sounds like the right thing to do. Good luck man.
    Mar 22 2005
    Kitchener, Ontario
    Re: lost gears?
    sounds like fun. good luck man
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
