Results 1 to 17 of 17
    Oct 22 2006
    Would bad tires cause me to sway in snow?
    Hey boys when i drive in heavy snow @ 100km/hr i find the car swaying a little not alot but enough that if i have pasengers they will hold on for life. I've had my winter tires for 3 season this being my third and last 2 snow seasons my car was lowered @ 24.5 , i raised it this winter to 25.5 but feel like tires have uneven tire wear, would this make me feel it in the snow?
    Sep 13 2008
    Western Chicago Burbs
    Re: Would bad tires cause me to sway in snow?
    Quote Originally Posted by karmad View Post
    unless you are a girl, you should not be starting a post with Hey boys
    as fopr the swaying, try rotating the tires and look at them to see if the wear is uneven. if it is then get an alignment.
    Jan 25 2006
    A4 2.0T
    MD
    Alignment.
    Oct 22 2006
    i got an alignment when i raised my car
    Veteran Member Three Rings a4937's Avatar
    Aug 14 2008
    Ohio%20
    Why would you need to go that fast in heavy snow anyway? Even with quattro it doesn't take much of a slip to send your car sideways.
    Dec 05 2007
    Maybe it is the treadware simple starting to show it's age. My snow tires I had for one season had maybe 1-3 more seasons left in them before/after being sold.
    Oct 22 2006
    Quote Originally Posted by a4937 View Post
    im pretty confident with my snow abilities
    Veteran Member Three Rings willowtreexx's Avatar
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    how bout tire postion as in the way its supposed to rotate? i know my know tires have to be facing a certain way or else it just keep pushing the snow back infront of the tires.
    just a thought... mine have arrows telling you which way they are supposed to rotate.
    sorry, thats all i have
    2000 A4 1.8TQ Auto tip
    Unitronics Stage 1 chip / H&R coilovers / 18x8.5 MRR GT1's/35% tint
    Veteran Member Three Rings Castor Troy's Avatar
    Dec 17 2008
    Billings, MT
    lolz why are you driving 62.2 mph in heavy snow
    Oct 22 2006
    Quote Originally Posted by Castor Troy View Post
    in heavy snow i mean like 5 - 10 cm
    Jun 26 2008
    Sounds like float, bald tires don't help and if your alignment is just slightly off it will be exacerbated.
    Get some new tires, preferable 195/65/15 and get your alignment rechecked.
    Think of it as trying to ski with no edges. Can’t turn, can’t stop.
    Dec 17 2008
    Billings, MT
    hankook w409's > *
    Jun 26 2008
    ^ x2
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    umm what? raised...
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Oct 22 2006
    Quote Originally Posted by Rhinop21 View Post
    umm what? raised...
    ummm coilovers
    Veteran Member Four Rings amd is the best's Avatar
    Oct 05 2007
    '91 200 20v, 01 A4 2.8 PES
    Manteca, CA
    Nokian Hakkapelitta's FTW!
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    8V Audi S3/RS3 Facebook Group
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    If the car is swaying enough to bother passengers then it is time to slow down. Directional stability is critical to staying on the road. If it won't stay straight then there isn't enough control available to correct a slide.
    Also check your tire pressures to make sure they are even. A low tire can cause the car to randomly sway. Had it happen to me on Friday when a tire had a slow leak.
    Jim
    I Do Werk.
