Results 1 to 9 of 9
    Registered Member One Ring Madsen's Avatar
    Dec 31 2007
    Audi S4 2,7 Avant Facelift
    Norway
    Problem with FIS-unit
    Hey.
    In my S4 i have some problem with my FIS unit.
    Anybody that has some ideas about what it can be? I think i have to switch out the hole display, but maybe somebody know anything else i can try before?
    Fredrik
    Im adding a pic so you see my problem:
    Audi S4 2,7 Facelift
    Nissan King Cab 4X4
    (X)Audi S4 2,2T Avant
    Senior Member Two Rings African2.7T's Avatar
    Dec 18 2007
    B5 S4 Laser RED
    PA
    Re: Problem with FIS-unit
    the pixels are the problem. in order to fix that the whole cluster would have to be replaced as far as i know
    MK4 GLI Blue lagoon
    B5 S4 Laser RED
    Past Rides
    C5 A6 2.7T
    B5 S4 Santorin Blue
    MK4 JTI VR6 Money Green..lol
    Sep 13 2008
    Western Chicago Burbs
    happens to all b5ers
    Senior Member Three Rings B00sted20VUSP's Avatar
    Nov 11 2008
    Junk
    Chicago, IL
    needs cluster replaced
    /S4 25 Quattro #139 | JHM 93 Oct Tune | Fast Intentions Non-Res Exhaust | Trexturk Downpipes | VMR Staggered Gunmetal 710's | RS4 Grille | RS4 Pedals
    Dec 31 2007
    Norway
    Okay. The instrument panel is disassembled allready, so its going to be switch out;)
    Nissan King Cab 4X4
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Yes this is very common problem for audi's of all sorts. There are multiple posts on this problem you have a few options.
    One is to take cluster out of dash (really easy, 2 screws and slides right out after disconnecting rear connections) take cluster apart and try pressng the electrical connections tighter to board. There is write up on this and the effectiveness is very little. May improve a few pixels but more then likely not make a difference at all.
    http://forums.vwvortex.com/zerothread?id=3449343
    Second is replace entire cluster. You can buy new ones from various places, I think genuineaudiparts.com has the cheapest 692 bucks yes expensive. There may be other places too and will probably have to get milage reset for additional charge or just use mathamatics to know what your actual milage is.
    To me the other and best way to fix this is send your cluster in to certain sites that take origional screen out, and sodder new screen in. I think they offer 1 to 3 year warranty too. This is around 250 bucks give or take a few. I'd have to search again
    Here is a post about someone buying a bunch of screens to be put in:
    http://www.audizine.com/forum/showth...=speedo&page=5
    Here's another post about what to do:
    http://forums.audiworld.com/s4/msgs/2764285.phtml
    Here is a site the fixes clusters: its over sea's but I think there are sites here in US that fix them too:
    http://www.bba-reman.com/content.asp..._cluster_range
    So do some searches and find a place to get it fixed. thats what I would do. I would not buy a used one that claims to be perfect pixels because it probably will be a matter of time before they start fading too.
    At least this is what I want to do. Mine are fading a little but not bad just yet. Well truthfully putting the money to more important things. lol But I do want to get this fixed because it drives me crazy to have them fading.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Dec 31 2007
    Norway
    Thanks for lots off information:) Im not going to switch out the hole cluster, only the screen for the FIS. I tryed to search about it, but only tryed on the s/rs4 forum.
    Yes it it very annoying when it dosent work properly!
    Nissan King Cab 4X4
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Quote Originally Posted by Madsen View Post
    PM DxC he replaces the screen for $200 or will sell you the screen for $100.
    B5 S4 AWE Stage 3 - sold
    Dec 31 2007
    Norway
    Quote Originally Posted by Rajan147 View Post
    Are waiting for answer already;) thanks
    Nissan King Cab 4X4
