Results 1 to 18 of 18
    Established Member Two Rings banger2392t1's Avatar
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    Question I need to refinish wheels
    I just bought an S4 and got a good deal because of some minor body imperfections and the rims are scuffed. My neighbour is a body man and will fix that for me for a case of beer but i need to refinish my rims. There are only surface scratches on the rims, so can i fill in the scuffs or do i have to refinish the whole rim? How easy it it to do and for me to do or should i just pay someone to do it right? If i need to pay someone where can i go to get mine refinished? THANKS FOR ANYONE WHO HELPS ME
    New s4 > Old A6
    2001 Silver b5 s4 250hp
    2004 Black Ski-doo MXZ 600 120hp
    2008 Red Sea-doo Super Charged RXP 255hp
    Fearless in winter
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    Re: I need to refinish wheels
    I like the result with the way I did it. It is by no means professional but I think it looks fine. If you don't' like the results you can always have it painted professionally later.
    By the way I used to be a complete noob when it came to cars (I still am but know a few more things) so I pretty much had NO idea what I was getting myself into when I started this project.
    http://www.youtube.com/watch?v=q5eK5...eature=related
    http://www.youtube.com/watch?v=4bh8hzwC2TA
    ^ Two guides I used
    http://www.youtube.com/watch?v=fLT1d...e=channel_page
    My friends and I painting
    http://audiforums.com/forum/showthread.php?t=78203
    Used parts of that guide
    Quick Steps:
    Clean and sand your wheels down
    Etching primer
    Filler Primer
    Duplicolor (insert color here) wheel paint
    Clear coat
    How my rims came out (I didn't use clearcoat but I HIGHLY recommend it).
    Audi A6 2.7T : 6MT : 88K Miles : GIAC Chip : 2.5" Catback : Hotchkis F+R Sways : AWE DTS
    Dec 02 2008
    nowhere
    Oh btw if you make enough money you're taking time off from work to do this, you could probably work to make the money and have a professional do it.
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    its a easy afternoon/ 2 day project, i did mine a few months ago for the same reason, go to an auto zone or some auto store look by the rattle cans and you should be able to find a color of duplicolor wheel paint. as for the scuffs i wet sanded the wheels with 1000 grit w/d paper then shot em with a dulpicolor primer filler, seamed to do the job well
    here is how it turned out
    '00 Nogaro Blue S4
    Registered Member Two Rings ingolstadt's Avatar
    Jan 14 2007
    '06 E53 X5 4.4i
    Folsom, CA
    Are we talking stock Avus' here?
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    Ya stock wheels...my car is silver and i'am also debating whether they should be black or stay silver
    New s4 > Old A6
    Fearless in winter
    Dec 02 2008
    nowhere
    I'm a big fan of the gunmetal grey. I beleive duplicolor has 4 colors.
    Silver
    Gunmetal Grey (Graphite)
    Black Gloss
    Black Matte
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    Nogarowonda what colour did you use? i dont mind that gunmetal colour, if that what's yours is. what type of duplicolour do you need high heat, autobody paint...etc??
    New s4 > Old A6
    Fearless in winter
    Jun 13 2008
    Rocky Mountains
    it was the only gunmetal grey duplicolor wheel paint at my autozone, here is a link
    http://store.summitracing.com/partde...art=shw-hwp101
    its the darker grey one looks just like the color of my wheels
    '00 Nogaro Blue S4
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Here's mine. DupliColour Matte Black with Clear Coat. Still holding up fine through the winter.
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    I went to canadian tire and was looking at the paint and not wanting to refinish all the wheels in the winter decided to wait it out untill the spring. BUT is there something i can do to repaint the scuffs on my rims untill i do refinish them. If i can what company and paint colour matches the S4 rim colour???
    BTW i like the black alot control one
    New s4 > Old A6
    Fearless in winter
    Dec 02 2008
    nowhere
    I used the graphite can for my wheels. Anyways when you paint your wheels make sure its kind of warm out (not below I guess 50 degrees because the properties of metal and the spraypaint at that temp aren't as good so it may not finish as well).
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    Good to know...thanks
    New s4 > Old A6
    Fearless in winter
    Veteran Member Three Rings TRANS4M's Avatar
    02 Imola S4
    VA
    Quote Originally Posted by CONTROL ONE View Post
    How did you keep the rings silver? Does it pop off the center cap or did you mask it off?
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    Quote Originally Posted by TRANS4M View Post
    x2
    New s4 > Old A6
    Fearless in winter
    Sep 19 2008
    Toronto, Canada
    They pop out. That was my favourite touch
    Active Member Two Rings cocom4zzy's Avatar
    Feb 12 2009
    RIP: 2004 A4 3.0 USP
    San Diego, CA
    control one, your rims look super clean. what kind of clear coat are you using?
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Graphite Duplicolor with 2 layers of clear on them.
    It's about 7 bucks per can.
    you need 2 cans of primer
    2 cans of color
    2 ans of clear
    800 girt and 1000 grit sand paper
    so I wet sanded with 800 first.
    2 coats of filler primer (10 min dry between them).
    wet sand with 800 again lightly, a little more on the areas that were scratched. (at this point there was a deeper scratch so i sprayed a bit more filler primer on that area, dry, and sand down again).
    1 light coat of graphite, 1 coat to make sure all nooks are covered, and one final light over coat to make sure all is even (10 mins between coats).
    I then waited 20 min to have the paint dry well, then did a VERY VERY light sanding of the graphite coat with the 1000 girt. Seems that the graphite has a lot of flake in it so i smoothed it out a little. Get a rag and dust off all excess.
    2 light coats of clear (10 mins between, didn't want them glossy so light coats).
    Let dry overnight.
    I then got some rubbing compound and did a light buff on make them look even.
    Biggest tip:
    Don't over spray! Multiple light coats is WAY better than one wet spot. I had a wet spot and I just had to wait about 15 mins to dry it then just do the light sanding, clean off, and do a light over coat. The texture of the graphite will cover it up.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
