Results 1 to 6 of 6
    Registered Member Two Rings
    Dec 02 2008
    canada
    Cat removal on 2.7t s4
    i was thinking to take off my 2 cat from my s4
    now i got a code p0420:catalyst system low bank 1 efficiency
    if i take off the 2 cat,should it read again a check engine ?
    do i need to place the o2 sensor on another place ?
    Jul 26 2008
    Jersey
    Re: Cat removal on 2.7t s4
    If you remove your cats your rear O2's will always throw a CEL.
    Although most tuners can delete the rear 02's which prevents the CEL.
    Dec 02 2008
    canada
    how can i delete it ..just take it off and clear cel light with vag-com
    and my cel light is already taking off ....
    and remove the downpipe and take the shit off inside.
    so what i want to do is
    remove everything inside cat and remove the 2 cat ..
    should my car run good after and no code or epc.cel light ?
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    If you just clear the CEL with vag, it will only come back 5 miles down the road.
    You have to physically delete the line of code that throws that specific CEL. That's something the tuner would have to do.
    The rear O2 sensors won't make your motor fuck up. The front ones however will.
    Dec 02 2008
    canada
    Good thanks
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    i dont think this topic has ever been discussed
    B5 S4 AWE Stage 3 - sold
