Car is 1998 A4 B5 1.8 (R4/5V/ADR)
Right guys, I'll try to keep this simple as possible, two days ago, on my way home, the fuel light came on, with the normal beep, and i thought that's odd, I'm sure i should have more fuel left......
so I stop at a garage, throw 25 quid in, drive off, only to hear the familiar "beep" ???
I look down, and the gauge reads empty, lower in fact then its ever been.
When i get home, its too dark and cold to mess about looking at it, so i use the trip computer to keep a eye on the mileage/ Fuel so not to run out.
Today, i figure better stick some more in just to be sure, so i'll give it another 25 quids worth, and proceed home down the motorway, for a nice early finish.
About 10 miles down the motorway, the car cuts out, no warning lights etc, nothing.
I'll pull over, and try to restart, car turns over as normal, dash lights all as normal, but it wont start.
Makes a few calls and gets rescued by a mate, and gets towed home.
After a nice hot chocolate, I get the laptop out and run VAG-Com and get the following faults:
17916 - Idle Control Sys: Upper regulation limit reached P1508
Possible Causes
* Air Intake System blocked
Possible Solutions
* Check Air Intake System
Stripped all the intake side right back, no blockages or any sign of debris?
I've read somewhere that the speed sensor can fail, causing similar fault codes?
17967 - Throttle Body (J338): Fault in Basic Settings
Possible Causes
* Idle Switch Open or Open Circuit
* Throttle Valve sticks and won't close
* Speed Impulse from Engine Speed Sensor (G28) recognized
Possible Solutions
* Perform Throttle Body Adaptation
16500 - coolant temp sensor (g62) Implausible signal
Possible Causes
* Wiring and/or connections faulty
* Engine Coolant Sensor (G62) faulty
Possible Solutions
* Check wiring and connections
* Replace Engine Coolant Sensor (G62) - (I've found a few mentions of this around the web, seems they have a habit of failing quite regular, yet I've never had any overheating or temp problems before?, will it prevent the car from being started? or is this just part of my problems?)
00771 - Fuel Level Sensor (G) 30-00 - Open or short to B+
Possible Causes
* Wiring between Fuel Level Sensor (G) and Instrument Cluster: Open or Short Circuit
Possible Solutions
* Check wiring between Fuel Level Sensor (G) and Instrument Cluster
I've checked all the wiring, but cannot see any signs of damage, or where the cable may have shorted. Faulty sender perhaps?
Any of you guys know the correct procedure for "Throttle Body Adaptation" for the B5, as I've read a few different ones now?
Any ideas for anyone who's had these faults before?
